Old 09-28-2004, 02:57 PM   #1
Ray of Sunshine OP
Meat Donut 2 Some
Ray of Sunshine's Avatar
Oddometer: 16,859
Swapping forks
I hate the ATE caliper on my R75/6. I am not to cooncerned with keeping the ike a non bitsa, I'd ideally like to change over to a brembo set up from a later R100. Has anyone done this? Any tips?
TIA
Ed
For the love of Baldy, would someone please buy my bikes?
Life is better, but why not?
Ray of Sunshine is offline   Reply With Quote
Old 09-28-2004, 04:37 PM   #2
norton73
drinkin'
norton73's Avatar
Oddometer: 8,306
instead of swapping forks, you might try replacing the master cylinder. The stocker is located under the gas tank where it's currently leaking all over your frame top tube and rusting it out. The cable from the lever to the M/C is spongy, and doesn't help with the feel any. Get a handlebar mounted Magura M/C from any dealer that sells Parts Unlimited and a braided line, and you will be much happier with your brake.
I did this on a R90S I owned years ago, and it made a world of difference.
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 09-28-2004, 06:07 PM   #3
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
yup. a mag should run you about 100 plus maybe 50 for the goods to plumb it to the calipers.
dead
Chopperman is offline   Reply With Quote
Old 09-28-2004, 06:13 PM   #4
Ray of Sunshine OP
Meat Donut 2 Some
Oddometer: 16,859
Thanks, guys. I forgot about the m/c swap. I am doing some other work on th eold girl this winter and that'll be on my list.
Ed
Old 09-28-2004, 06:24 PM   #5
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
If yer gonna swap forks - take 'em off a K100. (yes they use the same bearings you only have to worry about lengths) Much better. You do realise that the old /5 forks had very long travel .. what you will get with the newer fork is mucho reduced travel.
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 09-28-2004, 07:26 PM   #6
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,938
Be careful
If you swap out the master cylinder you may lose the abs or cbs effect. Well okay not antilock but can't be locked brakes.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Times are GMT -7.   It's 04:58 PM.
