01-28-2010, 11:49 AM
#1 |
Oddometer: 12
Zumo 660, Scala Rider Q2 and MP3 music
I have a Zumo 660 and the Cardo SCALA RIDER® Q2™. MP3 music sounds fine from the Zumo using a hardwire, but when I play music wireless via bluetooth it sounds awful, with a lot of static. I understand that this may be due to the fact that the Scala Rider Q2 doesn't have A2DP so the music comes in as mono. But why the static?. Does no A2DP mean static music? I tried it at different volumes and I still get static. On top of that, in order to listen to music with the hardwire I need to turn off bluetooth. Without bluetooth I can't receive incoming phone calls or listen to GPS commands. Is this just the way it is with my current setup or am I doing something wrong? Do I have to go all wired or all wireless?
Wireless via bluetooth is obviously the way I'd like to go and everything works fine with that (phone, gps, intercom) except for music. |
01-29-2010, 04:48 PM
#2 |
Riding is my passion
I've pumped music from my 2820 over BT to the Scala. It sounds pretty bad because its trying to send the music over the BT headset profile. I don't remember hearing static, but more then a couple of minutes of it would drive me nuts.
Does the Zumo 660 support the BT A2DP profile? If so, you could get one of those BT receivers that basically receives the BT signal over A2DP and then sends that signal through a headphone plug. I think you might be able to accomplish that with this Sony DRCBT15 device. Its supposed to be where you plug in your favorite headphones and it turns them into a BT receiver, but there should be no reason why you couldn't use a standard male to male plug and use this receiver to get the music over BT and transfer it via a wire in the MP3 port on the Scala. Just keep this little Sony thing in a pocket on your or something and the wire running to the Scala. Even though you'd have that small wire, it would be on you and not hooked to a device on the bike which would be good. Now, the only issue I see is if you can get the Zumo to connect to both the built in BT of the Scala to listen to directions & talk on the phone and simultaneously get the A2DP part to connect to this Sony device? That might not be possible, but I guess it depends on how the Zumo handles multiple BT devices?
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
01-29-2010, 09:25 PM
#3 |
Oddometer: 12
BlueLghtning: the Zumo 660 does support the BT A2DP profile. Using the Sony DRCBT15 Receiver/Transmitter you're suggesting to bypass the BT on the Scala altogether, is that right? That's an interesting idea. I could then potentially use any earphone/mic headset. I wonder if anybody else has tried the Sony DRCBT15 with a GPS, or specifically the Zumo 660?
01-30-2010, 04:09 PM
#4 | |
I would think if the Zumo supports the A2DP profile, then it shouldn't have any trouble transmitting music to that Sony DRCBT15 receiver?
01-30-2010, 04:13 PM
#5 |
I know you already have the Scala, but I recently started taking a look at the BT Interehpone F4 which does receive BT A2DP plus it can pair with 3 simultaneous connections and it remembers up to 8 BT devices in its memory!
They also give it very high rankings and say the sound quality over the Scala's is awesome which is pretty amazing as I think the Scala's sound pretty good for talking and stuff. When our Scala's die, I think the Interphone F4 will be one of the top contenders on our list for a replacement and get that A2DP BT that we are looking for.
02-03-2010, 01:00 PM
#6 | |
Oddometer: 12
![]() I'm thinking about getting another helmet. If I do I may just get the Interphone F4, if I can swing it. Right now that sounds like the best way to go. Are there others that you would consider? |
02-03-2010, 06:53 PM
#7 | |
What a crock. Who wants to worry about their $250 headset dying in a rain storm. Our Q2's have been through some serious rain and have never missed a beat. The F4 says its waterproof or weather proof or something, but looks much better built then the G4's. I really like our Q2's, but I think the Interphone F4's have the Cardo Scala G4's beat by a long shot. .
02-09-2010, 01:10 PM
#8 |
Oddometer: 3
Well, scratch one for Cardo. (Or Garmin.) I got the new Scala G4 yesterday, and went to pair it to my Zumo 660 (latest 3.5 software), eagerly awaiting all the A2DP stereoy goodness to come.
Short version: No dice. Doesn't matter whether I try to pair the 660 to the G4 as a "GPS" or as an "MP3 player", at the end of the day it's still connecting to the headset with only the craptastic mono audio profile. I did try pairing it with my Windows Mobile 6.1 phone, and with that I was able to successfully get much higher quality A2DP audio, but of course that's not my media player, it's my phone! I also went to see if any of their new vaunted firmware upgrades were available on the Scala site that perhaps might deal with this, but there's nothing there yet. I left messages for both Cardo and Garmin tech support, but have had no response thus far. Needless to say, I'm pretty disappointed with the lack of A2DP connection. So far as weatherproofing goes, the G4 looks pretty good, maybe not quite as good as the Q2 I'm replacing/supplementing, but I'm not worried about it having serious moisture issues at this point. I just want my stereo audio! |
02-09-2010, 09:40 PM
#9 | |
Oddometer: 12
02-10-2010, 10:08 AM
#10 |
Oddometer: 3
Anytime you talk about bidirectional communications like Bluetooth, I don't think you can really rule out either side. It could be the Garmin failing to determine that the recipient supports A2DP correctly, or it could be some oddity about the headset that causes it to reject an A2DP connection from the Garmin (but not from the phone), or who knows. It's not just a simple one-way transmission from the GPS.
So far I haven't heard back from Cardo, but Garmin's help so far has only been the expected "make sure you have the latest firmware on the GPS" which I just verified back to them that I do, performed a hard reset, cleared all user data, repaired, etc., and still have the problem. More updates as they come in. :-) |
