Closed Thread
Old 03-22-2012, 02:43 PM   #1651
DandyDoug
Oddometer: 378
Thanks for the tip.
I'm just getting over bronchitis and hope to be trusted with tools and other sharp implements in a day or so
So i am doing my research on line.
My motorcycle developed a slight knock in the drive line before i left for Daytona, by the time i got there it was more noticeable. Rode it home ok and checked it frequently for any heat build up or fluid loss, nothing obvious.
Now when i put the bike on the center stand in neutral and rotate the wheel forward or back the noise is not there
I had several BMW riders with a lot more knowledge than me listen to it while down there. The consensus was a bad U joint.
Doug
DandyDoug is offline
Old 03-23-2012, 09:35 PM   #1652
Jvanvuren
Jvanvuren's Avatar
Oddometer: 85
Cb900c
Posted this over in the flea market, figured it might be appreciated here:
http://www.advrider.com/forums/showthread.php?t=775455
Edit: Sold
Jvanvuren screwed with this post 03-25-2012 at 08:58 AM
Jvanvuren is offline
Old 03-24-2012, 06:16 AM   #1653
danedg
Horizontally Opposed
Oddometer: 6,678
Originally Posted by DandyDoug View Post
Thanks for the tip.
Doug
Doug,
Please check the four bolts attaching the driveshaft to the transmission output flange. Make sure they are tight. Loose bolts would make the sound you describe...
danedg is online now
Old 03-24-2012, 03:44 PM   #1654
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,711
Originally Posted by danedg View Post
Doug,
If they are loose you should replace them ASAP. Use the short bolts, no washers. They are supposed to be changed anytime they are removed. I don't think everybody does that though, I do.
---Albert Einstein
disston is offline
Old 03-25-2012, 12:54 PM   #1655
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,677
Looking for 2 ATE 40mm calipers in decent shape. Silver or black.
Have 3 38mm ATE calipers, 1 black 2 silver, if you want to trade 3 for 2.
Also interested in out right purchase.
Boon Booni is offline
Old 03-25-2012, 02:21 PM   #1656
danedg
Oddometer: 6,678
Yup!
That too!
Old 03-25-2012, 02:29 PM   #1657
DandyDoug
Oddometer: 378
Puled the boot back and checked the bolts = all tight.
We could find no slop in the U Joint, and for some odd reason cannot replicate the knocking noise now ??
We tried it in all 5 gears static on the center stand, started the engine and ran it through the gears, tried holding the rear brake on tight and loading the drive train , all we heard was some minor clutch chatter ??
Stumped at this point , so we decided to tear the whole drive line apart this next week. Something is not right for sure .
Will report back what we find .
Doug
Old 03-28-2012, 07:36 AM   #1658
blaine.hale
blaine.hale's Avatar
Oddometer: 3,171
Anyone have a spare set of the 2 screws and weird clamp/clasp things that hole the tail light lens on a /6 ?
I can't seem to keep those blasted things around long.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline
Old 03-28-2012, 07:57 AM   #1659
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,711
Doug
Maybe some people will have to pull this apart because it once made a noise. Not me. If the noise went away I'm moving on. You could find nothing. You looked at the four bolts. It fixed itself.
Of course if the noise comes back then start looking again.
---Albert Einstein
disston is offline
Old 03-28-2012, 03:44 PM   #1660
TimTuff
Metal Hip
Oddometer: 7
http://www.advrider.com/forums/showthread.php?t=776806
battery side covers for r75/6 and others
TimTuff is offline
Old 03-28-2012, 05:51 PM   #1661
Precis
Maladroit malcontent
Precis's Avatar
Oddometer: 3,697
Wheel bearings?
"I would like to die on Mars; just not on impact." Elon Musk
Precis is offline
Old 03-29-2012, 10:30 AM   #1662
Dillon@ZenMoto
falls down too much
Dillon@ZenMoto's Avatar
Oddometer: 305
FS bmw r100GSPD parabellum touring windscreen 20"
for sale 20" parabellum touring windscreen off of my 1990 r100gspd,
located in mesa az
price $100+shipping
zenmotostore.com
Dillon@ZenMoto is offline
Old 03-29-2012, 01:50 PM   #1663
jsullivan
jsullivan's Avatar
Oddometer: 115
Misc airhead stuff
Chrome krauser bag racks removed from a 79 r100rt. They also fit my r90/6, FWIW. $75 shipped
Big /6 tank w/ petcocks and gas cap. This thing's pretty crusty all around. Straight other than the dent pictured on the right side. Good rehab candidate. $75 shipped
Black r80g/s r100gs slipstream deflector. No cracks, but some wear. ***SOLD***
Black r100gs low fender. $100 shipped
jsullivan screwed with this post 04-04-2012 at 08:03 AM
jsullivan is offline
Old 03-29-2012, 03:06 PM   #1664
mfp4073
mfp4073's Avatar
Oddometer: 2,455
Wanted
Airhead TRIP ODO, not the regular one, but the resetable one.
Mine does not sync up its numbers, so I have to manually roll the numbers back one mile at a time. Sucks!!
Anyone have an extra laying around for cheap?
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline
Old 03-29-2012, 05:42 PM   #1665
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
Dibs on JSullivan's /6 Tank.
After seeing the pix I withdrew my dibs. It's much crustier than it appears.
Wirespokes screwed with this post 03-29-2012 at 07:07 PM
Wirespokes is offline
Closed Thread
Times are GMT -7.   It's 01:57 PM.
