Old 01-07-2013, 11:42 PM   #15286
jaumev
jaumev's Avatar
Oddometer: 1,487
I know this people, they work very well, nice stuff.
My only concern is if the rear brake calliper can hi in it when the suspension is fully compressed. I had to shortened the None exhaust because this… but probably they tested…
jaumev is offline   Reply With Quote
Old 01-08-2013, 12:45 AM   #15287
Happy Snapper
GOMOB.
Happy Snapper's Avatar
Oddometer: 2,112
Mounting LED light bars on the S10
Hi all and greetings...
For those inmates who have mounted LED light bars under the headlight on their S10.. what did you "hang" them off?
Did you use the 4 plastic "lug / loops" under the headlight?
If you did.. have they stood up to vibrations off road.
And if you didn't.. how did you mount them?
Happy Snapper
Never trust atoms.... they make up everything!
Read my Blog: http://snapshotsfrommark.blogspot.com.au
Happy Snapper is offline   Reply With Quote
Old 01-08-2013, 08:12 AM   #15288
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,745
Question Another coupla' questions
For those of you who have pushed a mini-fuse into the clutch switch...
-Which one did you use? I've read 7.5, 10, 15, and 20 amp.
-When I go to O'Reilly's or AutoZone, do I just ask for a "mini-fuse"?; Will they know what I'm talkin'-about?
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 01-08-2013, 08:18 AM   #15289
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,792
Amp rating does not matter, there is probably only mere miliamps actually going through the switch.
Its an "ATO mini" blade type fuse.
Fuck Bill de Blasio
MeefZah is offline   Reply With Quote
Old 01-08-2013, 08:30 AM   #15290
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,578
There are two 10mm head bolts. Each just under the headlight. I can not see
a factory use for the bolts. I used those to hold the light bar bracket. So far so good.
The bike was used in Moab on the White Rim Trail and some other more mild off road.
pluric is online now   Reply With Quote
Old 01-08-2013, 08:32 AM   #15291
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,578
Remember to twist the blades sideways first.
Old 01-08-2013, 08:34 AM   #15292
fredz43
Location: Illinois- land of straight, flat, boring roads.
Oddometer: 623
If you shove the fuse in from the wire side you do not have to twist the blades. You don't even have to unplug the connector if you do it from that side.
fredz43 is offline   Reply With Quote
Old 01-08-2013, 08:39 AM   #15293
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,578
Well sure, if you want to be a hack about it.
Old 01-08-2013, 08:56 AM   #15294
ArmyMedic
Flyin' Elvis, UT Chapter
ArmyMedic's Avatar
Oddometer: 491
Pluric,
What LED light are you running under there?
2012 Victory Vision Tour
2012 Yamaha XT1200 Super Tenere
RecoveryThreads.com
ArmyMedic is offline   Reply With Quote
Old 01-08-2013, 09:34 AM   #15295
WARRIORPRINCEJJ
Oddometer: 9,745
Thanks for the responses, Gentlemen (especially MeefZah, for the quick response).
Well, I guess I'm gonna' be doin' it the "hack" way, as I will be using the method that is spread all over the i-net (I hope GB doesn't mind me using his pic)...
Originally Posted by GB View Post
It's raining, in San Antone, today. And, the streets inside of Loop 410 will be like greased owl shit. So, I'm thinkin' that today is not the day to re-learn the "new" throttle on my ST.
So, I will probably try it on a drier day...
Old 01-08-2013, 09:48 AM   #15296
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,578
Originally Posted by ArmyMedic View Post
Pluric,
http://advrider.com/forums/showthrea...92384&page=184
Post #2758 on....
Old 01-08-2013, 12:05 PM   #15297
freeflow
get in or go in
freeflow's Avatar
Oddometer: 15,601
my STen is blue, so I got a blue one.... 15 amp
freeflow is offline   Reply With Quote
Old 01-08-2013, 12:47 PM   #15298
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,411
Originally Posted by simmons1 View Post
I find the O2 sensor info interesting. I have a US bike with an ECUnleashed flash. My O2 sensors are in a box out in my shed. AF1 racing told me that after the flash they were not used and that the software was tweaked so there would be no error codes after removing them. I have ridden thousands of miles with them removed. I know that Jaxon has removed his also. YMMV
OK...now I am confused
No change there then !
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 01-08-2013, 12:49 PM   #15299
WARRIORPRINCEJJ
Oddometer: 9,745
One does want a hint of color...
Old 01-08-2013, 12:50 PM   #15300
WARRIORPRINCEJJ
Oddometer: 9,745
Wait. What did I just post?
That sounds like something the owner of a black ST would post... :ymca
Times are GMT -7.   It's 01:34 PM.
