Old 01-09-2013, 09:10 AM   #15331
sallydog
no more Green KLR
sallydog's Avatar
Oddometer: 4,650
I've done 40 miles on reserve a several times
Its not who dies with the most toys.. Its who wears out the most toys
Just dip me in beer and toss me in the drunk chicks.
if you havent grown up by age 50 you dont have to
Heaven's the place where all the dogs you've ever loved come to greet you
parting out an 84 & 86 magna
sallydog is offline   Reply With Quote
Old 01-09-2013, 10:11 AM   #15332
Gundy
Oddometer: 553
Originally Posted by simmons1 View Post
I am normally at 4.5 when the light starts blinking as well. I don't think you can put a full 6 gallons in the tank. The fuel pump takes up some volume and you can't top off the tank with out poking some holes in the filler neck.
+1. Bike usually takes 4.5 gallons when the reserve light has been on for 10-15 miles...
Current: BMW Sertao "Gizelle"
Past: 2012 Super Tenere, 2009 WR250X/R, 2004 Triumph Tiger 955i, 2009 KLR 685, 2006 DRZ400S, 2006 TW200, 2001 KTM 250 EXC
Gundy is offline   Reply With Quote
Old 01-09-2013, 10:18 AM   #15333
markjenn
Oddometer: 9,698
I get the flashing reserve light at about 180 miles where it will typically take 4.4 gals or so. Reserve is worth another 50 miles or so where it will take 5.7-5.8 to the bottom of the filler neck. (I have run the bike dry to check.) Yamaha advertises 6.0 or 6.08 depending on which docs you read, but I can't get this in unless I burp the tank full above the filler neck which Yamaha says not to do - the consequences are minor for a 49-state bike (possibly fuel overflow to the ground), but more serious for a CA bike (raw fuel into the carbon canister).
- Mark
Old 01-09-2013, 12:08 PM   #15334
NicolasR
NicolasR's Avatar
Oddometer: 37
Originally Posted by Flydream View Post
I did 4500 km in Morocco and never notice anything different in my bike.
I did it twice during my last trip. It just ran a bit hotter. When cruising at same speed my temperature varies between 73 - 77 celsius degrees. When running on low octane fuel it just does not get below 80 Celsius degrees.
I like to set my dash most of the time on the coolant temperature, so I could tell it definitely runs hotter.
NicolasR is offline   Reply With Quote
Old 01-09-2013, 06:26 PM   #15335
GrahamD
GrahamD's Avatar
Oddometer: 3,814
"It's better to ride a boring bike than push an interesting one" ... Canuman
The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA.
GrahamD is offline   Reply With Quote
Old 01-09-2013, 06:45 PM   #15336
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,131
Laugh Aceee-Dceee...
Originally Posted by GrahamD View Post
Something tells me that's a skid plate...
Dallara
You never see a motorcycle parked outside a psychiatrist's office
Dallara is offline   Reply With Quote
Old 01-09-2013, 07:03 PM   #15337
GrahamD
GrahamD's Avatar
Oddometer: 3,814
With added features...
Old 01-09-2013, 07:21 PM   #15338
Dallara
Dallara's Avatar
Oddometer: 1,131
Laugh I know this will be fun...
You got 'em to add the onboard beer cooler?
Cool!
Dallara
Old 01-09-2013, 09:03 PM   #15339
TH
There and Here
TH's Avatar
Oddometer: 754
Cool!
Dallara
You can go farther on some nice bourbon! And it more effective, on an ounce by ounce basis!
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 01-09-2013, 09:12 PM   #15340
Dallara
Dallara's Avatar
Oddometer: 1,131
Cool2 I dunno'...
I don't think bourbon is as readily available there in GrahamD's Australia as it is here in the States... And I know those Aussies like their beer!
Me, I vastly prefer a good single malt scotch to either. That bourbon is just a tad too sweet for my palate. That said, if nothing else is available, bourbon will do!
Dallara
Old 01-10-2013, 12:28 AM   #15341
drbig
Solo Sailor
Oddometer: 145
reserve
Mine gives 80 Km on reserve and then it's huffing and puffing and pushing and begging
Running out of gas on an S10. I managed to pull that trick about a week ago. I made it 240 miles or 386 km. I was on reserve for approximately 50 miles or about 80 km. I routinely get about 42 to 44 mpg. I figure, unless I'm really pushing it, to have at least 40 miles once I hit reserve. When I fill up, just after it hits reserve, I'm usually putting in about 4.5 US gallons.
drbig is offline   Reply With Quote
Old 01-10-2013, 03:47 AM   #15342
IainMac
Fast side of farty
IainMac's Avatar
Oddometer: 216
Originally Posted by NicolasR View Post
Hi to all, and happy new year by the way!!!
I got back from a 3500 km trip on mi S10 trough Colombia. What a trip!!!
Last night I reviewed all the notes regarding fuel consumption and I averaged 77,2 Km per U.S gallon of fuel. Not bad at all. However, my doubt is the full range with a full-filled gas tank. I am asking because I always refueled the bike when the reserve indicator started blinking but it would only take 3,8 or 4 U.S gallons max. and that happened at the 320 kilometers-mark from full.
I checked and our S10 have a 6,08 U.S gal tank, which means that I could get around 450 km from a full tank.
Why the reserve comes at 320 around Km??
How long can you drive with the reserve??
According to my maths, the reserve is of about 2 U.S gallons. Is that correct??
The longest I have ridden my bike with the reserve on is for about 40 Km. I havent tried to get more kms for not harming the fuel pump when going dry, but apparently I could get even more before that happens.
I see you are now talking about fuel quality. Well, I had to buy low octane fuel twice and it made the bike runs about 5 degrees hotter.
You've probably got the ghist of reserve range limits by now but thought I chuck my pennethworth in . I have tested the range on my UK S10 to dry on a couple of occasions (both with separate reserve fuel). On long distance reasonable pace riding I got over 60miles on reserve to the 1st stutter, but on local commute traffic it was spot on 50miles and that resulted in an engine cut out. So I'd say if you ride with reasonable care you should make 50miles on reserve but if the road/conditions are arduous figure on less.
XT1200Z day to day workhorse. 888 strada (license buster in waiting), 900 superlight (sleeping for the winter whilst I think about a wheel swap/tyres)
IainMac is offline   Reply With Quote
Old 01-10-2013, 12:14 PM   #15343
jaumev
jaumev's Avatar
Oddometer: 917
More stickers to jaumev
Here ya' go...
http://www.ebay.com/itm/NEW-Fuel-Pum...-/300562096240
Of course, we're taking US numbers here.
Dallara
jaumev is offline   Reply With Quote
Old 01-10-2013, 12:16 PM   #15344
jaumev
jaumev's Avatar
Oddometer: 917
Originally Posted by twinrider View Post
Lugging: When an internal combustion engine is run at overly low RPMs for the load being applied to it.
Understood!!
Old 01-10-2013, 12:21 PM   #15345
jaumev
jaumev's Avatar
Oddometer: 917
Be careful… there is a bit of history on it
Enjoy!!
jaumev screwed with this post 01-10-2013 at 03:26 PM
Times are GMT -7.   It's 07:23 AM.
