Old 01-14-2013, 03:59 PM   #15421
cug
Oddometer: 4,968
Originally Posted by pluric View Post
I gave up my FJR after owning the Tenere for 6 months. I'm pretty sure the FJR would give your Multi a nice rear view.
I'm not so certain about that one. Maybe the same way as the Tenere gives the Camhead GS the rear view?
The Multi is light. Very light. And it pulls like crazy. That engine is a total beast. Totally possible that I'm wrong here but I would put my money on the Multi for "showing the rear". Especially if we are not talking straight line. But even there I'm not certain.
cug is online now   Reply With Quote
Old 01-14-2013, 04:22 PM   #15422
Specterx
Specterx's Avatar
Oddometer: 62
Heated handle grip
Thought I would share. the cheap mans variable temperature handle grip heaters. I got some tusk handle grip heaters and a cheap 12v PWM modulator and aluminum case. Just finished testing and it works like a champ. I did have to cut the case down to make it fit the PWM.
PWM $13.99
http://www.ebay.com/itm/281027916416...84.m1497.l2649
Case $7.27
http://www.ebay.com/itm/380461406262...84.m1497.l2649
also you will need a set of grip heaters (tusk brand work great). At 100% they are too hot for me.
Specterx is offline   Reply With Quote
Old 01-14-2013, 04:34 PM   #15423
Domromer
Desert Rat
Domromer's Avatar
Oddometer: 1,091
http://scootercanada.weebly.com/
Across Canada two up on a 50cc scooter.
If all you ever do is all you’ve ever done, then all you’ll ever get is all you ever got.
http://advrider.com/forums/showthread.php?t=851060 ... A desert rat explores the south.
Domromer is offline   Reply With Quote
Old 01-14-2013, 04:35 PM   #15424
creggur
There are no curves here.
creggur's Avatar
Location: Jacksonville, Fl. aka Flatandstraightsandistan...
Oddometer: 277
Underpowered? Compared to a Multi...sure.
Pulls like a freight train? Not really - but as the bike breaks in it does feel much smoother and more powerful.
Plenty of juice to tour two-up? Oh yeah, and damn comfortable in the process.
Fast? Yeah - me and a buddy following me on his Street Triple strolled along at a buck-twenty-five indicated for a number of miles (closed course ;) ). The Big Blue Girl had no issues!
It's a great bike, but if you want to get a real feel for it, find one for a test-ride that has 8,000 miles or more on the clock. The engine is so tight out of the box it takes a few K to really work in. I swear mine (8,600 miles) feels stronger and smoother every time I ride it.
Clutch Switch mod or reflash is a must to get rid of the silly emissions-based restrictions in the first three gears. I could also tell a difference when I installed the Akra pipe as well - the engine needs to breathe.
_________________________
Blue '12 Tenere
Originally Posted by scottie boy View Post
If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle.
creggur is offline   Reply With Quote
Old 01-14-2013, 05:27 PM   #15425
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,246
Well a quick google shows the bikes within tenths of a second on the 1/4 mile.
FJR tops out at 154. I admit I'm biased to my memory when the FJR hit it's sweet
spot 3rd gear on. Sometimes things seemed to happen too fast.
I think you know my experience with late model GS humiliation. I will say they have
a very visable tail light.
pluric is online now   Reply With Quote
Old 01-14-2013, 05:46 PM   #15426
Specterx
Specterx's Avatar
Oddometer: 62
Tenere and power...
My bike before the Tenere was a 2003 Yamaha R1, before that an FZ1. They would utterly crush and kill the tenere on the road in any situation requiring speed or handling. That applies to my wifes R6 too.
But who buys a tenere to run like a sport bike? Nobody I hope.
The difference is in power delivery. The tenere has a very nice flat torque curve. It doesn't produce most of its power on the top end like a sport bike. But distributes that power over a much larger RPM range. It is designed to have power available under any circumstance. And that comes at a cost. Top end won't be there. But at the same time, it blows away the FZ1 for 2 up riding. There is less of an impact on performance on the Tenere. I can hardly tell when I have a rider on back. On the FZ1 the bike felt like it was being held back at lower RPMs (not so much at high). For 2 up riding, the Tenere is the king. The tenere is more of a tractor than a dragster. It is a purpose built bike.
going from an R1 to a Tenere... I love the Tenere and would never go back to the R1. You can ride on a Tenere for 10 hours in a day with very little discomfort (assuming breaks). It goes off road. you can load it down with gear and a passenger and you can barely tell you loaded the bike up. The bike is simply a joy to ride.
Teneres for everyone!
Old 01-14-2013, 05:49 PM   #15427
roarin calhoun
Oddometer: 385
Right Pluric, GS's have tailights....that work.....sometimes. I used my GS12 on dirt most of the time & dirt clogged switches on that kraut ABS system often.When it did, the tail light went out. Headlight burned out OFTEN. Thank gawd for my Tenere. It just goes,period. 2 up,long distance on the Tenere? The wife likes the Tenere TONNES better than that stinkie German thing.
roarin calhoun is offline   Reply With Quote
Old 01-14-2013, 05:59 PM   #15428
cug
Oddometer: 4,968
I think you know my experience with late model GS humiliation. I will say they have a very visable tail light.
I actually have no clue whether a Multi will be quicker than a FJR - I rode a Multi and my impression was "Holy shit!!!". Some bikes might be just as fast or faster, maybe not as abrupt or whatever, it was just that the Multi really left an impression of accelerating really fast while many others didn't. Though that might have to do with the fact that the 2010 Multi I rode ran like shit below 4k, so I was already in the sweet spot for power, while on a smooth and nice running engine I tend to be ride in a much lower rev range.
Regarding visible tail light: I love this mod and will try to add it to all my bikes in the future:
http://www.youtube.com/watch?v=JMFHy...layer_embedded
Unfortunately I didn't help me scaring that stupid deer from the road ... need a weapon to blast things out of my way ...
Old 01-14-2013, 06:08 PM   #15429
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
Other than drag racing, straight line performance differences between the GS and S10 (or pretty much any bikes in a similar class) are pretty meaningless. When the road turns twisty the better rider will be out front.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is online now   Reply With Quote
Old 01-14-2013, 08:03 PM   #15430
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,886
I see my "freight train" comment went over like a fart in church.
I used to track and dyno test turbo 'Busas...which, coincidently, some of the riders described as pulling "like a freight train". That description (for the 'Busas) was wrong, in my very humble opinion. To me, they always pulled more like a cruise missile.
I never saw a freight train spin any of its wheels at 100+ MPH. I have, however, seen a buttload of turbo bikes do that. To me, you haven't lived until the bike you're riding turns its rear tire into a ball of smoke, at over triple digits. Talk about "ass pucker"...
Anyhow, back to the ST...
In my not-so-eloquent way, I was trying to dote on the flat torque curve of the it. I was trying to get the exact point across that Specterx did such a fine job of...
Originally Posted by Specterx View Post
...The difference is in power delivery. The tenere has a very nice flat torque curve. It doesn't produce most of its power on the top end like a sport bike. But distributes that power over a much larger RPM range. It is designed to have power available under any circumstance. And that comes at a cost. Top end won't be there. But at the same time, it blows away the FZ1 for 2 up riding. There is less of an impact on performance on the Tenere. I can hardly tell when I have a rider on back. On the FZ1 the bike felt like it was being held back at lower RPMs (not so much at high). For 2 up riding, the Tenere is the king. The tenere is more of a tractor than a dragster. It is a purpose built bike...
And, my initial post came only because I had the same "WTF?" reaction as Domromer...
Originally Posted by Domromer View Post
I swear to Christ I will lose my shit if I hear anyone worrying about a 1000cc bike not having enough power for touring two up...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 01-14-2013, 08:13 PM   #15431
GrahamD
GrahamD's Avatar
Oddometer: 5,400
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 01-14-2013, 08:18 PM   #15432
WARRIORPRINCEJJ
Oddometer: 9,886
Originally Posted by freeflow View Post
take your time and squeeze more in a little splash at a time to get up and around the expansion area of the tank...
and if you push it like that...carry one of these...= 10 miles of ride...but for you, we better say 8 miles ...
...fits perfect in one of these....
Have we met? The reason I ask is that it seems like you know me.
It never fails; If everyone else is averaging 55 MPG, I'll be getting about 40. If they're gettin' 45, I'm gettin' about 35. It's been that way for about as long as I can remember.
My ST is averaging 35, right now (haven't reset the meter since the bike came-out of the crate)...
After my little aerobic ordeal, the other night, I was thinkin' about grabbin' one of those MSRs or Primuses. Right now, I'm wonderin' if it'll mount under the OEM panniers.
Thanks for the reply...
Old 01-14-2013, 08:59 PM   #15433
snakebitten
Small Town Hick
Oddometer: 980
If I told my wife I was tradin the Tenere in for a "better" 2-up ride, she would surely ask why.
The one answer I could NOT give her is "it's underpowered".
She has looked over my shoulder and seen 95-100 mph SO MANY TIMES as we made our way around folks that weren't properly taking advantage of the 75mph speed limits around Texas. :)
Loaded to max GVW, this bike is unburdened gobbling up miles.
It is more like an F350 than a F150 in how it puts the power down. But I rather like that.
Come to think about it though, I'm not sure how I could answer her "why" and be convincing. She loves being on the back of this thing. She'll go anywhere with me now. First bike in 30 years of trying. I'm not gonna mess with that.
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 01-14-2013, 10:22 PM   #15434
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,246
"Tower to blue Tenere. You are cleared for landing on runway two"
Old 01-15-2013, 12:09 AM   #15435
Xeroo
sweeet!
Xeroo's Avatar
Oddometer: 22
is that the New time machine ??
i need to get back to the future!!
Fun fun fun
Xeroo is offline   Reply With Quote
Times are GMT -7.   It's 07:16 AM.
