Old 01-27-2013, 10:50 AM   #15616
~TABASCO~
www.rideonadv.com
~TABASCO~'s Avatar
Oddometer: 372
I will add to this just a little... I had a slightly weak battery in my FJR several weeks ago.. It would turn over just fine but would not fire up. Guess what, when I opened the throttle wide open it would fire... The battery was old on it so I knew it was just an old battery, but sounds like you guys with the Teneres..... After I put a new battery in, the FJR fired right up and good as new... As several of you have said, I wounder if its a voltage "issue".... For the people that are having start up issues, what electronic farkels do you have on the bike ? It might be a common "part" for the guys having issues...... just a thought
www.rideonadv.com
We are ADV, everyday.
~TABASCO~ screwed with this post 01-27-2013 at 03:40 PM
~TABASCO~ is offline   Reply With Quote
Old 01-27-2013, 12:42 PM   #15617
sidetrack one
Chief Tiddler
sidetrack one's Avatar
Oddometer: 5,552
Two batteries was the answer for me, I wrote it up over in the Aussie Ten 12 thread
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
Where are my pants?
www.buyabale.com.au.. Our farmers thank you!
sidetrack one is offline   Reply With Quote
Old 01-27-2013, 12:49 PM   #15618
GrahamD
GrahamD's Avatar
Oddometer: 5,319
Now that's what real outback adventurers do. 4x4 have been doing it for years
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 01-27-2013, 01:30 PM   #15619
~TABASCO~
www.rideonadv.com
~TABASCO~'s Avatar
Oddometer: 372
Can you post the link to your write up?
www.rideonadv.com
Old 01-27-2013, 02:32 PM   #15620
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,632
Electrical system on my bike is like this:
Battery -> Eastern Beaver fuse block -> Clearwater lights on switched circuit, Garmin Zumo 550 GPS mount on un-switched circuit
I'm going to track stuff down some time this week. Not today though.
Anticyclone is online now   Reply With Quote
Old 01-27-2013, 03:03 PM   #15621
Dirty bike
Eval Innovations Inc
Dirty bike's Avatar
Oddometer: 853
This is the issue. The 550 has an internal battery, there is no reason to have it on un-switched power. Even off, it's likely drawing current.
Dirty bike is offline   Reply With Quote
Old 01-27-2013, 04:00 PM   #15622
Anticyclone
Oddometer: 5,632
GPS was not on the bike for any of this time. But I suspect you're right, the cradle may have a short somewhere. However, the same style cradle on my DRZ does not drain its little battery and it sits for a month at a time without being ridden.
Old 01-27-2013, 05:16 PM   #15623
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,817
Question Shinko 705s...
I know there's an entire thread dedicated to these tires. However, I wanted to hear from only ST owners...
Is anyone running the 705s?
How do you like 'em?
For those who have had more than one set, what kinda' mileage did you get out of 'em?
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is online now   Reply With Quote
Old 01-27-2013, 05:19 PM   #15624
simmons1
simmons1's Avatar
Oddometer: 1,526
I am using one on the front right now. 7,000 miles and it looks great still. I would buy another one.
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is offline   Reply With Quote
Old 01-27-2013, 05:21 PM   #15625
Anticyclone
Oddometer: 5,632
I agree, there is a voltage leak somewhere. I outlined measuring 'dark current' in a similar post here or on the Super Tenere forum some time back.
Do you by any chance have a SWMotec powered tank bag? If installed the way the directions are, direct to the battery, it draws current even with nothing turned on, just the bag on the tank ring. And will kill the battery quickly. BTDT. It needs to be wired to switched power instead.
I messed up the original post, edits to correct my errors. Thats what I get from not looking it up again.
As for testing dark current, or parasitic draw with the key off, take a multi-meter, set to AMPERAGE in the 10 or 20 amp range and do the following:
Loosen the NEGATIVE terminal so you can easily pull it off. Touch the DMM probes to the terminal and the same battery post, note the reading, which should be 12-14 Volts, then with the probes staying connected, slide the terminal off so that the DMM is now in series with the removed terminal and the battery post. I've forgotten the Ma that spec is, but post what you find and it will be immediately apparent if it's too high. Should be around 45-54 Ma. Much higher than that indicates a problem.
And yes, the battery should easily last two weeks.
Ok. Battery reads about 12.8v across the terminals. The negative is losing 0.26 mA. IF you read across the poles on the fuse block for the GPS, it reads 0.26 mA even when the GPS is NOT in the cradle. So I moved the GPS to an un-switched spot on the fuse block. The battery is still losing 0.26mA on the negative side.
I don't know. I guess my electrical knowledge comes up a little short
Old 01-27-2013, 05:21 PM   #15626
WARRIORPRINCEJJ
Oddometer: 9,817
Have you had one on the back?
My front tires always wear like iron. But, I can smoke through some rear tires pretty quick...
Old 01-27-2013, 08:45 PM   #15627
20valves
Yamaholic
20valves's Avatar
Oddometer: 449
I'm on my second rear, still first front. I got about 5K miles out of the back, looks like one front will last for two rears for me. They're decent off road and pretty good on road.
'14 500 EXC, '06 R1 LE, '13 FJR, '12 XTZ12, '09 T Max
20valves is offline   Reply With Quote
Old 01-27-2013, 09:03 PM   #15628
Steve G.
Steve G.'s Avatar
Oddometer: 7,066
2012 Super Tenere fuel range
I'm lucky enough to be renting a newer Super Tenere for a month of touring in Europe this summer. Some of the countries I'm going through have spotty fuel availability. I'm wondering what the average real mileage guys are getting out of their bikes? In my case, there will be no offroad riding, mostly backroads, perhaps a mountain pass or 20 [Transfagaien in Romania ].
Cheers
Steve G. is offline   Reply With Quote
Old 01-27-2013, 09:51 PM   #15629
WARRIORPRINCEJJ
Oddometer: 9,817
Gracias, 20v...
Old 01-27-2013, 10:27 PM   #15630
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,911
That's good to hear, I ran those exclusively on my Strom but the Tenere is a much heavier bike and has a lot more horsepower. I was worried the rear would be roasted in 2k.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Times are GMT -7.   It's 02:27 PM.
