Old 01-31-2013, 01:11 PM   #15781
freeflow
get in or go in
freeflow's Avatar
Oddometer: 16,208
Originally Posted by iridemotorbikes View Post
The new stickers must add at least 15hp....
I used a blue mini fuse for that.....but my bike is blue so it doubled the output...true story
as far as heated grips go...just like I installed on several previous bikes....I went with the Symtec kit....grips can off easy with a compressor,,,,a few eastern beaver plugs and male/female connectors.....and viola, connected up to the stock wiring harness nice and clean and ran a GPS / SAE 2 prong connection too.
I used this simple Hi Lo round rocker and put it here...it worked for thousands of miles on my strom (and 2 other stroms )
freeflow screwed with this post 01-31-2013 at 01:16 PM
freeflow is offline   Reply With Quote
Old 01-31-2013, 01:11 PM   #15782
TH
There and Here
TH's Avatar
Oddometer: 912
Originally Posted by pluric View Post
So.... anyone tried to start their bike recently.
Rode mine to work today.
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 01-31-2013, 01:17 PM   #15783
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,884
Me???!
You're the icing licker around here.
Didn't you announce your shared jealously and love, last night?
And then you said something about liking licking, this morning.
Come clean, Pluric; Did you paint your bike blue?
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 01-31-2013, 01:48 PM   #15784
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,286
pluric is online now   Reply With Quote
Old 01-31-2013, 01:54 PM   #15785
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,286
Man, I wouldn't mind working if I could do that.
Old 01-31-2013, 02:02 PM   #15786
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 2,071
Laugh Told ya' so...
What did I tell ya'?
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 01-31-2013, 03:12 PM   #15787
markjenn
Oddometer: 10,483
Originally Posted by Dirty bike View Post
And the guy with 8 bikes in the garage, it's not the other 7, it's a Yamaha and there is a known issue with EFI Yamahas. The cold start sequence doesn't like to be interrupted. Do that, then let it sit, it will display the hard start 99% of the time.
Bull. Go out and fire your bike up for 60 seconds, shut it down and come back 3 days later. You'll have a classic hard start.
Originally Posted by markjenn View Post
Okay, test underway.
To close on this, I did exactly as instructed, ran the bike for exactly sixty seconds three days ago and just went out and started it. It fired up immediately and ran normally without touching the throttle. And this is a bike which has had three previous "no start" episodes, all with none of the often-discussed contributing factors such as an interrupted previous start or cycling the ignition.
I guess I'm either an exceptional 1% who doesn't match the pattern, or else your 99% statistic is BS. I'll leave which is more likely as an exercise to the reader.
- Mark
Old 01-31-2013, 03:25 PM   #15788
Dirty bike
Eval Innovations Inc
Dirty bike's Avatar
Oddometer: 867
Well Mark, I have to thank you for playing along all the same.
I can create the hard start by doing what I said, though I haven't tried to repeat it multiple times in a row either. And the FJR did the same thing.
Aside from your koolaid addiction, you do have some good posts and good input. We will continue to disagree on some matters though. Feel free to call BS when you feel the need, and I'll do the same.
Dirty bike is offline   Reply With Quote
Old 01-31-2013, 03:28 PM   #15789
GrahamD
GrahamD's Avatar
Oddometer: 5,403
- Mark
Same here...
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 01-31-2013, 04:12 PM   #15790
crazyjeeper
crazyjeeper's Avatar
Oddometer: 403
Nope.
2012 Yamaha Super Tenere, 1997 Honda XR650L, 1985 Honda XR350R, 1976 Honda GL1000 Goldwing
crazyjeeper is offline   Reply With Quote
Old 01-31-2013, 04:26 PM   #15791
Dirty bike
Dirty bike's Avatar
Oddometer: 867
Originally Posted by GrahamD View Post
Same here...
You did a lot of other things too Graham, w/o any real hard start, just some minor stumbles.
Are the AUS bike ECUs different? You do get foam filters instead of the paper, if I recall correctly. Any other differences?
Probably moot, but I've never noticed any "off idle stumble" either. Have you?
Old 01-31-2013, 04:27 PM   #15792
Dallara
Dallara's Avatar
Oddometer: 2,071
Laugh Speaking of statistical probability...
- Mark
Of course, we could consider another much more likely scenario for those "three previous 'no start'" episodes you had...
It was put this way by a poster in a thread on the Super Tenere forum:
"Without examining the bike, mechanical failure can't be ruled out, but it is MUCH less likely than simply (rider error, operator malfunction, rider losing control, etc.). The weakest link is typically the nut behind the handlebar."
Given that you've had probably hundreds and hundreds of starting attempts during the time you've owned your bike it perhaps stands to reason that those few (3) times you had a "hard starting problem" it was probably something you did, eh?
Dallara
Old 01-31-2013, 05:37 PM   #15793
GrahamD
GrahamD's Avatar
Oddometer: 5,403
Are the AUS bike ECUs different? Don't know. It's a first gen 2010 Pre Fukushima bike.
You do get foam filters instead of the paper, if I recall correctly. Yep.
Any other differences? It's the fastest and most economical colour combo..
No electrical farkles. Other OZ bikes have had the hard starting issue so it's not an "OZ bike thing".
Probably moot, but I've never noticed any "off idle stumble" either. Have you? Yes. Only in touring mode because I usually use that in traffic which I do as little as possible.
This is not what I call a minor stumble.
. If that was a minor stumble all I can say is I cleared it before the battery went flat.
All I wanted to do was figure out the most reliable way of inducing the hard start and a reliable way of clearing it.
And, after all that I can say that it was easier to induce if the battery was not 100%, no amount of switching the ignition had any effect and that it reliably occurs if the bike is cranked without firing between one or multiple times.
I could induce it with a freshly charged battery but it was harder to do. As the battery softened it became easier to induce.
It can be cleared by opening the throttle between 1/2 and 3/4 throttle for one to three starts. WOT may do it as well but I never did WOT.
I have started the bike and switched it off immediately, left it for days, with no problem.
I have started and let it warm to just over "Lo" and left it for days with no problem.
The most reliable way to induce it is to crank it without it actually firing cold. The more time that happens in succession the worse it gets.
GrahamD screwed with this post 01-31-2013 at 05:58 PM
Old 01-31-2013, 05:48 PM   #15794
snakebitten
Small Town Hick
Oddometer: 980
Originally Posted by crazyjeeper View Post
nope.
f150?
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 01-31-2013, 06:24 PM   #15795
White Tenere
Look a moose
White Tenere's Avatar
Oddometer: 740
Short video of my Saddleman Adventure Track heated seat. I had Saddleman build it with a red insert and red stitching, not over the top flashy but looks sharp in my opinion .
White Tenere is online now   Reply With Quote
Times are GMT -7.   It's 05:40 AM.
