Old 02-26-2013, 11:13 PM   #16261
towboatcrisco
towboatcrisco's Avatar
Oddometer: 25
Hey thanx GrahamD and Dirty bike!!
Funny you should mention the nelson rigg as i was just checkin out their gear today online. As for the tent that may end up in my kit a lil farther down the road . I dont have a garage at the moment but im undercover , i go away for periods of time and basically looking for something to protect the bike while it sits at home.
i also tracked down a " R&G " adventure bike outdoor cover . anybody ever hear about them ?? think it was $ 50 UKpounds
Appreciate the help and it was an easy way to introduce myself to the inmates
towboatcrisco is offline   Reply With Quote
Old 02-27-2013, 02:30 AM   #16262
tremor38
tremor38's Avatar
Oddometer: 1,468
http://www.amazon.com/Speed-Way-MTT-...sim_sbs_auto_4
2011 Yamaha XT1200Z
tremor38 is offline   Reply With Quote
Old 02-27-2013, 02:49 AM   #16263
tremor38
tremor38's Avatar
Oddometer: 1,468
Originally Posted by twinrider View Post
I wanted to add a volt meter as well as an accurate ambient temp gauge so I picked up a Show Chrome 5 function gauge at Amazon for $32 and a stainless steel bracket at the local home center. Used double-sided tape and a zip tie to attach the bracket to the column below the instruments, and velcro to attach the gauge to the bracket. Still have to trim the excess off the bracket but very pleased with the results.
The gauge isn't waterproof, but is pretty well protected from rain in this location. Have used them on several bikes with no long-term issues. http://www.amazon.com/Show-Chrome-Di...w+chrome+gauge
Hmmm! Gears are turning. I'm definitely looking for a combo volt meter and ice warning. I have something similar in my car that I picked up in the local Autobacs. It has an audible low/high voltage alarm that's always chirping away when the engine is at idle with the headlights on. No way to opt out of this alarm in the settings, so I found a sharp object and gave the speaker a little 'tune-up'...problem solved!
I suppose such a thing on a bike wouldn't be much of an issue.
2011 Yamaha XT1200Z
Old 02-27-2013, 03:48 AM   #16264
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
I've used this model on a few of my bikes now and like it, very accurate. For some reason my Dakar's HID headlight would set off the voltage alarm every time it fired up, a quick "tune-up" fixed that.
twinrider is online now   Reply With Quote
Old 02-27-2013, 07:56 AM   #16265
Space Traveler
explorer
Space Traveler's Avatar
Oddometer: 156
Power outlet for electric gear
I am seriously considering to buy Gerbing's clothing to be able to Ride my New flat grey S10 as soon as possible...
I want to know where you plug your electric clothing on the bike. Do you use the factory power outlet in the dash or you aded one under the seat?
If you have some pics, that will help for sure.
Space Traveler is offline   Reply With Quote
Old 02-27-2013, 08:03 AM   #16266
TH
There and Here
TH's Avatar
Oddometer: 912
The stock plug will not support the gerbing gear that well. Best thing to do:
  • Run the wire that comes with the controller directly from the battery and run it to under the seat, or
  • Install a fuse block (many different options) and run the gear off of the fuse block, which would be directly connected to the battery.
I have used the fuse block method, as I don't like to keep my tinkering with the stock electrical wires to a minimum.
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 02-27-2013, 08:34 AM   #16267
Space Traveler
explorer
Oddometer: 156
Great, Thank you!
It help searching on Google when you know what to look for and use the right words
Old 02-27-2013, 08:35 AM   #16268
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,772
[PHP]I have a nice dry place to store my bike although not indoors . The cover will act more as a shield/ blanket , aswell a barrier from wandering eyes .
Maybe it's the "KLR rider" in me, but I use old fitted sheets to cover my bikes in the garage. From Full Queen to King I can find one to fit any size bike.... and they won't scratch the paint!
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 02-27-2013, 08:38 AM   #16269
Bob Herr
Oilpatch Univ. Graduate
Oddometer: 276
Check out Warm N Safe Gear
Check out the Warm N Safe gear too. They have a remote(wireless) operated controller that does not require wires to the jacket and pants. The only connection you have to fool with is the wire from the battery. Gerbings may have it now too. I just haven't checked their website lately. - Bob
Illinois!!! Another Liberal Democratic Party economic waste land.
Much Too Young(To Feel This Damn Old)
Bob Herr is offline   Reply With Quote
Old 02-27-2013, 08:40 AM   #16270
Dirty bike
Eval Innovations Inc
Dirty bike's Avatar
Oddometer: 866
+1 on what TH said. The factory cig outlet is only 3 amps fuse.
Before you buy, check out Warm and Safe, Powerlet and even Tourmaster to see what meets your needs. I've had a bunch of warranty issues with Tourmaster heated gear, but they have always been fast to deal with and their gear does come with a controller, where as all the others you need to buy the controller separately from the jacket or other piece of heated gear. I've had a Gerbing jacket liner for over ten years and it still works fine, but if I were buying today, I'd probably get W&S for the features and quality of the gear. Wife moved from the Tourmaster to the W&S and is pretty happy, though feels the jacket is not as warm by itself, (w/o power), for walking around. It's far less bulky though, and more comfortable to wear under her gear.
All heated gear come with a pigtail that is a fused connection with ring terminals on it, for direct connection to the battery. Many riders that already have an aux. fuse block will connect the pigtail to the fuse block instead of direct to the battery. Most of us learned long ago that you can only get so many wires on the battery, and the aux. fuse block makes it a lot easier to manage your electrical farkles.
I have seen many methods of managing the plugs for heated gear. The simplist is what TH wrote, just run the connector up under the seat, give it a zip tie for strain relief and when you need it, pop the seat and pull the wire up so it sticks out at the front of the seat. The controller will plug in there and hang off your tank bag or jacket.
When you don't need it, it can just stay there and will be fine, and when things warm up consistently that you don't use it, tuck it back under the seat and it's out of sight.
The most sanitary method is to use a 'mounted' controller, Warm and Safe being the best out there. (First gear branded Heat-Trollers are made by W&S and warranted the same.) This means you have the controller box under the seat or under the side panel and a remote adjustment knob mounted somewhere convenient for you to reach. You still have a wire from under the seat to plug into, but you are just plugging in the jacket, the controller is always on the bike. You can also use a panel mount co-ax receptacle if you want to avoid the wire coming out from under the seat.
I use a Heat-Troller for my heated grips too, and have that control knob located in the left switch housing.
Co-ax plug coming out from under the seat, running to controller in pocket of tank bag. I'll update this to a mounted unit soon, probably with a panel mount co-ax jack. (the other cord is for comm to helmet)
Close up under the seat, finger points to the zip tie for strain relief.
Dirty bike is offline   Reply With Quote
Old 02-27-2013, 09:06 AM   #16271
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,225
I have heated grips and a heated vest with the outlets wired in.
If I'm going cold riding I wear one of these and don't need the vest.
They are soooooo warm alone. I use it as a snow suit too when playing
on other winter toys.
http://www.revzilla.com/product/firs...FQxxQgodWDMAaA
pluric is offline   Reply With Quote
Old 02-27-2013, 09:17 AM   #16272
fredz43
Location: Illinois- land of straight, flat, boring roads.
Oddometer: 648
I believe that you still have to plug the jacket into the power port. The remote portion is only the controller. Or perhaps I misunderstood what you were saying.
fredz43 is offline   Reply With Quote
Old 02-27-2013, 09:32 AM   #16273
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,462
You have got to be right. Else its wizardry, not electricity.
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 02-27-2013, 09:58 AM   #16274
Dirty bike
Dirty bike's Avatar
Oddometer: 866
Yep, with any of the options, you have a single power cable coming from the bike to the jacket.
With the portable controller, the controller is in line between the bike and the jacket.
With the mounted controller, the jacket plugs directly to the power cable, as that runs to the mounted controller and you have to run another cable with the control knob to someplace handy.
With the 'remote' controller, it's the same as the mounted one, except you don't have to run a wire from the control box to the adjustment knob. The remote portion is just the heat adjustment knob, and you can stick that where ever with some velcro or dual-lock or just put it in your map case or pocket, etc.
All the remote option saves you is the time it takes to route and install the control knob and led. Well, and the space on a panel or switch housing.
Old 02-27-2013, 10:17 AM   #16275
Space Traveler
explorer
Oddometer: 156
[/LIST]I have used the fuse block method, as I don't like to keep my tinkering with the stock electrical wires to a minimum.
Would you mind giving me a link for the one You have???
Times are GMT -7.   It's 01:32 AM.
