Old 02-27-2013, 10:35 AM   #16276
Bob Herr
Oilpatch Univ. Graduate
Oddometer: 276
Originally Posted by fredz43 View Post
I believe that you still have to plug the jacket into the power port. The remote portion is only the controller. Or perhaps I misunderstood what you were saying.
Yes, you still have to plug the jacket into the power cord from the battery but there are no wires from the controller to the jacket. W&S told me that is the reason they do not call it a wireless setup because it still has a power cord. FWIW, I prefer the portable controller rather than the one mounted on the bike. I have a couple of bikes and I just clip the controller to my jacket and put a lead from the battery on each bike to plug the jacket in to. With permanet mount you will have to buy additional controllers if you have more than one bike. Finally, if you trade bikes all you have to do is put a new battery harness on the new bike and you are ready to roll. - Bob
Illinois!!! Another Liberal Democratic Party economic waste land.
Much Too Young(To Feel This Damn Old)
Bob Herr is offline   Reply With Quote
Old 02-27-2013, 12:00 PM   #16277
TH
There and Here
TH's Avatar
Oddometer: 912
Originally Posted by Space Traveler View Post
Would you mind giving me a link for the one You have???
I just went to autozone and bought a fuse block. I velcro'd it by where the tools are located (right side cover).
However, there are multiple other options available. Do a search of this thread you and you will see some good setups. Likewise, you can also go to www.yamahasupertenere.com where you could also search for solutions.
Pluric has a nice setup that fits in the cavity under the seat. Mine was just a bit to long to fit in there, so that is why mine is under the right side cover. Pluric has some photo's of his setup on this thread.
Eastern Beaver is also a popular choice for many folks here too. http://www.easternbeaver.com/
A good place for outlining the wiring, using a distribution block and relay can be found at Canyon Chasers (This is what I used as a template for my wiring setup). http://canyonchasers.net/shop/generic/relay.php
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 02-27-2013, 01:09 PM   #16278
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,243
Here is the link to what I did under the seat for a power souce. Post 9591 on.
http://advrider.com/forums/showthrea...45850&page=640
pluric is offline   Reply With Quote
Old 02-27-2013, 01:59 PM   #16279
Space Traveler
explorer
Space Traveler's Avatar
Oddometer: 156
Space Traveler is offline   Reply With Quote
Old 02-27-2013, 03:37 PM   #16280
FMFDOC
Oddometer: 905
Illegitimi non carborundum!
Tell someone you love them today, because life is short...but shout it at them in German because life is also terrifying and confusing.
So much adventure, you can hear the theme from National Geographic playing in the background...
ANY WAY YOU CAN! http://youtu.be/Gg_G-NeSmW0
FMFDOC is online now   Reply With Quote
Old 02-27-2013, 03:40 PM   #16281
RideAbout
Mentally Retired
RideAbout's Avatar
Oddometer: 1,777
New owner, stupid question....well, usually if I'm talking I'm saying something stupid!
Clutch Mod Short.... why does it work? When the clutch is out (normal riding mode) that circuit is already shorted. When the clutch is pulled in, it's open.
Does the ECU somehow sense that the circuit was open (taking off, shifting, etc...) and limit power until you reach 4th gear? I'm not questioning the mod....just cornfuzed why it makes a difference.
West - "Oeste Sanchez"
RideAbout is offline   Reply With Quote
Old 02-27-2013, 04:35 PM   #16282
markjenn
Oddometer: 10,482
No one has the full answer. For some reason, Yamaha screws with the engine tuning depending on clutch position. As you probably know, Yamaha uses an electronic throttle on the S10 which means twistgrip position is translated electronically to throttle plate movement by a computer which takes into account many things and apparently the position of the clutch is included. Other bikes do this also so this is not unusual in modern EFI systems.
My personal theory is that Yamaha removes some of the throttle damping and delay inherent in the electronic system to make shifting crisper and let the engine rev more quickly and freely with the clutch pulled. And that's probably all the mod does - you can think of it as a jumpier "super sport" throttle mode that is addition to the sport and tour modes. Others think ignition and fuel mixture may be involved.
Getting the bike past emissions might have also have been a consideration.
- Mark
Old 02-27-2013, 05:09 PM   #16283
fredz43
Location: Illinois- land of straight, flat, boring roads.
Oddometer: 649
You have it backwards. When the clutch lever is out the circuit is open. It closes when the lever is pulled. Shorting the switch simulates the lever being pulled in. As to what the ECU does when it thinks the clutch lever is pulled in, we don't know for sure, but shorting the switch does seem to improve the bottom end throttle response with bikes that have not had the ECU reflashed.
fredz43 is offline   Reply With Quote
Old 02-27-2013, 08:39 PM   #16284
towboatcrisco
towboatcrisco's Avatar
Oddometer: 25
Well ended up with a Nelson-Rigg ( falcon defender XXL ) for the money 58$ i dont think i can go wrong .
Oh and as for using sheets haha call me crazy but i always drape thick towels over the windscreen,tank, seat , and any other sensitive area's .. ???? ive just always done that
Quirks " eh "
i really like what pluric did with his fuse box under the seat .. i may have to poke around a tad more on the thread and do some more research . I have stock heated grips put on by the dealer so i did'nt have to fuss ... but for futures , I like
towboatcrisco is offline   Reply With Quote
Old 02-27-2013, 09:12 PM   #16285
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
Huge improvement imo. Pluric mentioned that even with the ECU flash the CSM still improves the bottom end response. Not sure why as the flash is supposed to remove all restrictions but he's got both so...
twinrider is offline   Reply With Quote
Old 02-28-2013, 02:53 AM   #16286
tremor38
tremor38's Avatar
Oddometer: 1,470
Important to note that not all ECU flashes were created equal. Pluric's was done at AF1 racing. They use the ECU Unleased flash which has pretty smooth response off the very bottom end. By comparison, my Diapason flash is fairly abrupt off the bottom end, though I wish it were smoother at times.
Have you sent your ECU to Off The Road yet, or did you decide against that?
2011 Yamaha XT1200Z
tremor38 is offline   Reply With Quote
Old 02-28-2013, 03:13 AM   #16287
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
The bike's running great with the CSM so it's slipped down the farkle list behind panniers, driving lights, a Sargent seat, tank bag... I would love to ride yours back to back with mine sometime so I can see what I'm missing.
Old 02-28-2013, 10:22 AM   #16288
snakebitten
Small Town Hick
Oddometer: 980
I'm like you. The CSM reshuffled the deck. Priorities got re-arranged.
Ohlins is the one sucking me dry currently.
But I was WARNED not to drive a well sorted-fueled Tenere or I would change my mind about how well my CSM engine runs.
Easy enough. I won't!
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 02-28-2013, 10:48 AM   #16289
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,243
I do have a OEM bag collecting dust and a OEM bash plate that has been retired too.
Old 02-28-2013, 02:10 PM   #16290
jaumev
jaumev's Avatar
Oddometer: 1,511
ACD skid plate finished
The plate is finished at last!!
Now I can change the oil and filter without remove the plate
jaumev is offline   Reply With Quote
Times are GMT -7.   It's 07:37 PM.
