Old 05-03-2013, 07:58 AM   #17386
TH
There and Here
TH's Avatar
Oddometer: 912
If I was a crash test dummy, I'd take you up on that in a heatbeat. Wait, crash test dummies don't have heartbeats, unless you are thinking of the Canadian band...
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 05-03-2013, 08:13 AM   #17387
88millimeter
Oddometer: 12
Originally Posted by Mikef5000 View Post
I adjusted the suspension for the luggage (maxed out the rear preload and increased the front 50% more than normal), it was actually a bit stiffer than my (per the manual) solo non-touring settings. I was lightly on the throttle through the corner, no chopping the throttle or braking... I had not time to panic or input any controls... Went from a normal hard corner to sliding on metal/asphalt in an instant.
About the rumbux... The left side bent in and crushed the fan and cracked the radiator, but it high-sided, went completely airborn, and landed squarely on it. Nothing would have saved it.
On the right side, there was light directional scratching where it scraped the ground, and heavy scratching once it low sided, but no penetration. All the mounting points seemed intact. There is a close up picture of the rumbux on my website (now in my signature as well).
Mike, i had the exact same crash with the same rumbux setup, and like you mention it happened so quick i had no time to react. Ive ridden my fz1 at the limit but the differenece is when a peg srcapes you have time to adjust. Glad you're ok. I tore a ligament and will be on crutches for 5 months.
88millimeter is offline   Reply With Quote
Old 05-03-2013, 08:30 AM   #17388
Martin_404
Oddometer: 63
Am I out of line, if I say that this makes the Rumbox skidplate a badly designed and highly dangerous product?
I just ordered an Altrider skidplate.
Do I need to worry about the same thing, or don't they stick out as much?
I do not even want to think about my brand new bike looking like that.
Martin_404 is offline   Reply With Quote
Old 05-03-2013, 08:37 AM   #17389
Dirty bike
Eval Innovations Inc
Dirty bike's Avatar
Oddometer: 870
Originally Posted by pluric View Post
Testers anyone? Testers?
Come on now, don't be shy.
Are you kidding, we were counting on you to do that testing Pluric!
Mike and 88mm - Very sorry to hear about your crashes. That sucks big time. Glad you're ok Mike and I hope you heal back to 100% 88mm.
One of the consistent things I've been seeing with the Super Ten is that it's sprung on the soft side for most riders, especially the guys over 200 lbs, running panniers and other items. Adding another 24 lbs of crash bars probably doesn't help any, but we compromise on the whole protection Vs weight deal.
I re-sprung my stock shock and WOW, what a difference on the improvement side. I'm 250 w/o gear and have more crap than most on my bike, but even though my set-up isn't perfect it's night and day better. I know that gives me some more ground clearance too.
Good to know where the limits are and I hope no others find them in such a dramatic way. I have a better idea of the potential Bad Things® that can happen thanks to your posts. Thanks, but I wish you guys didn't have to 'take one for the team' so to speak.
Dirty bike is offline   Reply With Quote
Old 05-03-2013, 08:40 AM   #17390
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,470
Mike is a skilled rider on a road that is well known for no mercy. As he mentioned
if the Rumbux hadn't barely hit before the bag did it would be a discussion on the
side bags. Loaded bike with after market add ons, one of the most twisty roads
in America, kind of a recipe for disaster.
He's a lucky guy to only be out an insured vehicle.
pluric is offline   Reply With Quote
Old 05-03-2013, 08:40 AM   #17391
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 2,077
Cool2 Depends on how you look at it...
There are reports that the AltRider plate drags its rearmost corners immediately after the pegs, and as such could lever the wheel up and off the pavement in much the same fashion...
Of course, each situation, and corner, is different. Is the corner banked? Is it off-camber? Is there a bump in the corner? Etc., etc., etc. On some either plate st-up might drag, on others not at all. Bike set-up is a factor, too. Is the suspension stock? Is it properly set-up? Is the bike over-loaded? Solo or two-up? Forks slid up in the clamps? Lowering links?
All these things, and more, enter into the equation...
And how you plan to use the bike is a factor. If you plan to ride a lot off-road then you may want to make the compromise a more protective plate might cause - i.e. more off-road protection might mean less lean angle on pavement. Only you know the how's and why's of the uses you will put your bike through, and you are the only one who can choose your own compromises.
It certainly is a good idea to check cornering clearance, etc. with any accessory you bolt on that might present such a compromise.
Just my two centavos...
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 05-03-2013, 09:01 AM   #17392
Dirty bike
Dirty bike's Avatar
Oddometer: 870
I am biased, as I'm the Rumbux importer, but I think that's over stating it a bit. Every bike will drag something at some point. I know FJR riders that have dragged the OEM exhausts and levered the tire off the ground. That's a good ways over!
We are each in control of our ride. When we modify out bikes, it's up to us in the end to be aware of what the limits are. I've tried to show how the bars hit when the bike is over on it's side, but honestly, it did not occur to me to show or emphasize what hit first and how much room there was after that, in terms of scraping hard parts on the street. This is not a sport bike, after all.
When I lowered my S10 for my wife to try out, (1" links and 13mm on the forks), I did notice that in right turns I did have occasional contact depending on the angles involved and speeds, etc. The Rumbux lower bash frame only lowers ground clearance by about 1.25", but it's wider too. I've not touched down in corners with normal suspension height, but I'm not a peg scraper and I push the bike out and my shoulder in when riding hard in the twisties. (sort of the beginnings of 'hanging off' w/o the butt slide)
I will start including a caution about this issue with all new orders so that buyers will be at least aware of the potential for this to happen.
Old 05-03-2013, 09:17 AM   #17393
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,470
Maybe Mike will release some of his photos to go along with the caution statement.
Not to be my normal sarcastic self. I agree with all the statements about the after market
and OEM stuff. Road conditions vary so much there is no way to cover every base.
Some people want extreme protection, high capacity luggage or lowered seat height thorugh
lowering links and dropping the forks. Again unwittingly setting themselves up for a possible
surprise.
Old 05-03-2013, 09:41 AM   #17394
88millimeter
Oddometer: 12
Dirty, i completely agree with your assessment and your plan forward. I hate to blame the equipment but had i known the risk i could have prevented. On a plus side the bars that caused the crash also protected the bike. The lowside of the bike had minor scrqtches on rumbux and jesse luggage. The side of the bike that high-sided had a bent upper c-bar and jesse mount, both of which i was able to fix with the help of a friend and a come-along. Very impressive considering the weight of the bike and the force with which it high-sided. If i removed the accessories right now the bike would be pristine.
Old 05-03-2013, 09:49 AM   #17395
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,849
So how does one test for what will hit first? If you just lay the bike over, the suspension is unloaded, so you don't get a good reading. Tomorrow, I have some friends coming over for dinner. Big strong friends. I think I will compress the suspension with some tie-down straps, and then we will lay the bike over and see what hits first on each side.
This will not be 100% accurate, because it's hard to simulate bumps, but should be close.
I'll report my findings. This is of special interest to me since two weeks from today I'll be on that very road...
Anticyclone is offline   Reply With Quote
Old 05-03-2013, 03:25 PM   #17396
GrahamD
GrahamD's Avatar
Oddometer: 5,422
Sensible question.
I installed a big ass ACD and knobby-ish long wearing tires and some hard luggage.
This is what I expect from the combo.
I will let R1's pass in the twisties.
I will take it easy in the corners and I will treat it like a big bike with less clearance and grip, especially in the wet. I will pretend I am riding a Harley. I will spend more time looking at the scenery and just chill out.
Where I live and where I sometimes ride, a hole on something like a sump and the lack of supplies, especially water, can have serious consequences. So the plus side is I am less likely to have big problems where there is no one around and more likely to have problems when there is someone around.
If I stuff up and come in too hot, well it's just like doing that with any bike where you exceed the bikes limitations.
Many things out there which make riding 10/10th's a bit risky on the road where so many things are out of your control.
Shit happens and unfortunately it sometimes happens to the best of riders.
The Rumux were designed to prevent damage off road. They are one of the best when it comes to that. They may want to look at whether they can tuck them in a bit OR they may supply some longer fellers with the plates. It's up to them.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is online now   Reply With Quote
Old 05-03-2013, 04:33 PM   #17397
true grip
true grip's Avatar
Oddometer: 270
Talking
I'm with you on the pace of my rides but will draw the line at Harley's passing me
This ain't no coon hunt
true grip is offline   Reply With Quote
Old 05-03-2013, 04:34 PM   #17398
roarin calhoun
Oddometer: 385
I've just begun shopping for a crash plate for my Tenere (snow's finally melting around here). After seeing the video of this crash I think I'm going to forgo a crash plate altogether. I'm an old corner blaster & my wife rides with me often(2 up) and now & then I'll pop an asphalt curve pretty hard.Sometimes a curve can surprise you & you're glad for all that ground clearance you didn't think you'd need....but did.
I'll risk banging a hole in the oil pan, better than doing a repeat of this fellow's crash. Thanks for posting it !
roarin calhoun is offline   Reply With Quote
Old 05-03-2013, 04:40 PM   #17399
WestVirginia
Well spoke'n
WestVirginia's Avatar
Oddometer: 84
Finally
Finally bought my first motorcycle in a little over 20 years last night. Put a plate on today and had my first ride. Forgot how much exercise it is to ride in rough dirt (I'm 48 and....not model thin shall we say?).
Out of respect for the two inmates (Mike and 88) I will wait to post the required "me and my new bike" photo. Glad you are both sharing your stores - it helps us all.
I don't have luggage (no need for now), but am curious: I'm guessing on pavement most you guys ride in T 1 mode. So let's say you find yourself entering a corner too fast. What do you do on a Tenere?
PS: Thanks to the inmates here for sharing their insights on a variety of bikes. I researched beginning in September and finally purchased last night. The Tenere is the value-per-dollar winner.
WestVirginia is offline   Reply With Quote
Old 05-03-2013, 04:47 PM   #17400
BSTARD
Mmmmm...shiny
BSTARD's Avatar
Oddometer: 367
Hey Pedrosa, oops I mean Mike. I worked out an equation to explain your face plant.
= Riding a loaded S10 like a 600cc sports bike
= Showing off for photographer
= Face Plant
Your welcome :)
BSTARD is offline   Reply With Quote
Times are GMT -7.   It's 02:08 AM.
