Old 06-17-2013, 10:11 AM   #18481
RoyQ
RoyQ's Avatar
Oddometer: 2,152
Originally Posted by Anticyclone View Post
You ain't kidding! I washed my bike over the weekend (I know, my bad) and was amazed at the chips and scratches in the tank. It's bad enough I'm thinking about having it sprayed with bedliner.
The blue ain't much better but not as visible at first glance than black.
2012 YAMAHA Super Ténéré
'11 GSXR750
'11 GSXR1000 racebike
WERA Expert #826
RoyQ is online now   Reply With Quote
Old 06-17-2013, 10:11 AM   #18482
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,411
Our S10 is three years old today. Happy birthday to our trusty steed
This was it when we picked it up....... (I changed the tyres before I took it out of the shop)
...and this is the very different beast now.... a long way from home as it should be !
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 06-17-2013, 10:13 AM   #18483
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,490
I have to give Suzuki the nod for having tougher paint. My 'strom had 50k miles of abuse when I sold it and the paint on the tank still looked new...
Later,
Michael
"If I can't pass at a reasonable speed I do it unreasonably." - jdmetzger
Anticyclone is online now   Reply With Quote
Old 06-17-2013, 10:15 AM   #18484
Anticyclone
Oddometer: 5,490
snip
snip
tnd
Looks great! I'm enjoying keeping up with your travels on the blog.
Later,
Michael
Old 06-17-2013, 10:17 AM   #18485
RoyQ
RoyQ's Avatar
Oddometer: 2,152
EDIT: I also had a "no start" situation after I washed it. The clutch switch must have gotten water in it or I wiggled it loose. BIke would not start in gear, only in neutral. I wiggled the connection around a little and she fired right up in gear with the clutch in again. No problems since
Funny you mention the no start issue. Had my second one Saturday. Not as bad as the first one months ago as it did finally fire this time without pulling the FI fuse. I came back from vacation washed the weeks worth of grime off it. Cranked it and rode it until fan came on, parked it for two weeks until this past Saturday. It fired and died I knew what it was instantly. Turned key on went wot and it finally fired to life flooded of course.
But keep in mind we are all imagining that this is happening and we all need training on how to start a Tenere.
'11 GSXR750
WERA Expert #826
Old 06-17-2013, 10:23 AM   #18486
Anticyclone
Oddometer: 5,490
Mine was for sure not the flooding issue this time, I have had that once. This was purely electrical at the clutch switch. It still fired up without a problem clutch out in neutral.
Later,
Michael
Old 06-17-2013, 11:40 AM   #18487
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,567
Originally Posted by VEGASGSA View Post
Put 50 u jponts a year in axles and shafts on my rockcrawler..it's a wear part..big deal.
Damn, sound more like you were rock bashing.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is online now   Reply With Quote
Old 06-17-2013, 12:18 PM   #18488
RocketJohn
Hook em' Horns!
RocketJohn's Avatar
Oddometer: 11,330
How many miles/kms on it now?
You must have gotten one of the VERY first ones.
RocketJohn is offline   Reply With Quote
Old 06-17-2013, 04:35 PM   #18489
TRUBRIT
TRUBRIT's Avatar
Oddometer: 159
Vegasgsa
I have had the stumble and die issue. Happened a couple of times changing down fast coming to a stop sign and then rolling on the throttle turning right. It just died. Fired right up, but annoying. Bit dodgy if you have a car up your ass at the time. Stalled a couple of times about to pull away from a light. Now I am aware of it I keep the revs up and no issue. I do want to find the cause and cure though. It is always in the back of my mind. I have had the throttle Bodies balanced and the Air screw adjusted. I think I will be going with the Gen 2 reflash after my next trip.
Other than the above annoyance I have had no issues in 10K. I ride with my Buddy who has a 2010 GSA. 110 HP to my 105. I am lighter than he is so he does not get to pull on me. What little offroad we have been able to do down here in SFL, gravel and water crossings, we see no difference between us. There are others with far more experience on here who have had both which can give an honest comparison. Off to CO end of July so will get to compare the two in mild off road conditions (actual hills). We are off road noobs so it will be interesting to see which one is more user friendly and which builds confidence faster. From the specs comparison, weight is about the same. Rake angle on the ST is considered to be better than the GSA. Wheelbase on the ST is 2" longer so should be better balanced. The Techies will no doubt jump in now and correct or explain in more detail
Pluric will no doubt agree that an extra 2" always make s difference and makes things better
TRUBRIT is offline   Reply With Quote
Old 06-17-2013, 04:42 PM   #18490
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,895
Laugh It's *THIS* big!!!
Originally Posted by TRUBRIT View Post
...Pluric will no doubt agree that an extra 2" always make s difference and makes things better
I think you misunderstood ol' Pluric...
I think he said *ALL HE HAD* was 2"...
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is online now   Reply With Quote
Old 06-17-2013, 07:05 PM   #18491
WestVirginia
Well spoke'n
WestVirginia's Avatar
Oddometer: 84
Dallara
Now things are starting to make sense. I found all the cute girls Pluric was with on google. Turns out they all work for the "Make a Wish" foundation.
Sorry, just a "little" joke.
Four wheels move the body. Two wheels move the soul.
WestVirginia is offline   Reply With Quote
Old 06-17-2013, 07:13 PM   #18492
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,594
For me it would be the difference of having an innie or an outie.
pluric is offline   Reply With Quote
Old 06-17-2013, 07:14 PM   #18493
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,594
Yes, and I made their wish come true. You would be surprised how many cute young
ladies need a grandfather figure in their lives. Who knew?
Old 06-17-2013, 07:17 PM   #18494
WestVirginia
Well spoke'n
Oddometer: 84
Don't mind me Pluric. The only reason I got into motorcycles is that girls will only talk to me if I'm wearing a full face helmet with tinted shield.
Haven't kept up here as I should. Did we decide if a Power Commander V was needed if the reflash was done?
Old 06-17-2013, 07:56 PM   #18495
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,594
It's all good. I just figured being from West Virginia and all a family reunion would
solve any meeting women issues.
I've only run the reflash so no comment on the combination of the two.
Times are GMT -7.   It's 12:37 PM.
