Old 03-25-2014, 03:05 AM   #22396
MikeNewAdventure
AATW ON 2WHEELS
MikeNewAdventure's Avatar
Location: Los Angeles, California From: Bogotá, Colombia
Oddometer: 9
Originally Posted by GrahamD View Post
Welcome to the asylum MikeNewAdventure.
I would look seriously at this If I were you...
http://www.ebay.com.au/itm/Transcend...-/190557405930
I'll get back to you later about any other idea's.
What was this about??
SD CARDS, PLEASE...
I LIVE TO RIDE, AND RIDE TO LIVE... Mike N. www.facebook.com/mike.newadventure
MikeNewAdventure is offline   Reply With Quote
Old 03-25-2014, 03:33 AM   #22397
MikeNewAdventure
AATW ON 2WHEELS
Oddometer: 9
MikeNewAdventure:AllAroundTheWorldOn2Wheels
I've been testing loads, in different places to see where's the best place to put things. Also to see how, the motorcycle handles.
I also have been putting on less as well.
Old 03-25-2014, 03:47 AM   #22398
GrahamD
GrahamD's Avatar
Oddometer: 5,308
SD CARDS, PLEASE...
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 03-25-2014, 05:54 AM   #22399
fedswith
fedswith
Oddometer: 47
new v strom vs S10
Any owners of S10 riden the new VSTROM 1000 yet? Demo model has arrived and I'm about to go for a ride
fedswith is offline   Reply With Quote
Old 03-25-2014, 06:52 AM   #22400
scudrunner82
human whoopy cushion
scudrunner82's Avatar
Oddometer: 2,157
Originally Posted by Old Git Ray View Post
Hows that work then ?
I thought a gas under pressure (inert ones anyway) reacts the same to pressure changes regardless of what it is.
I am genuinely confused (honestly). Please explain.
Apparently I'm the one who's genuinely confused!
That's just what the old timers told us as for why the nitrogen. I never actually did ask an A&P why. Would have saved me from looking like and ass. Are you guys chemists or just crazy smart?
Now I have some ammo to quiz my coworkers with! I'm curious how many actually get it right
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old 03-25-2014, 07:41 AM   #22401
Kawidad
Kawidad's Avatar
Oddometer: 4,808
Originally Posted by techgeek View Post
I've searched for this but all I seem to come up with is how to lower the seat, or how to adjust the seat in the high/low positions..
what are my options for a taller seat height? I am on the taller side, and I find that the peg to seat high is annoyingly low for me. I don't want to lower the pegs because I find myself already scraping if I do anything spirited, so I'm thinking raising the seat would be the best option. My knees are bent enough so as to be uncomfortable.
I already have an airhawk pad on it, which raises me up a little, but I'd like probably 2-4" inches above the stock seat in the high position.
Any ideas without dropping big bucks on a custom seat?
Seat Concepts. They make taller foam and cover. You can order the cover and pre-formed foam and install it on your existing seat base, or ship the seat to them for installation.
http://seatconcepts.com/
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 03-25-2014, 09:38 AM   #22402
techgeek
Oddometer: 148
I emailed seat concepts a while back, and Robert said they only made one version for the super tenere 1200. He said it's about 1/2" taller than stock. They only make a tall version for the smaller tenere's apparently.
Thanks, though.
techgeek is offline   Reply With Quote
Old 03-25-2014, 09:48 AM   #22403
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,368
Thanks, though.
Touratech sells high seats. http://www.touratech-usa.com/Store/3...Tenere-XT1200Z
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is online now   Reply With Quote
Old 03-25-2014, 02:11 PM   #22404
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,632
Virtually nobody and I was quiet because MarkJenn got it right. The FAA's primary reason given is flammability. Of course, the damage that even a nitrogen-filled airline tire can do is truly impressive.
But then I remembered you drive a biz-jet and we have a few other pilots here, so . . . What gets more airplanes like yours are car-type assumptions about leakage rate and an example was the Learjet accident at Columbia, SC, in 2009. All rubber is somewhat permeable and aircraft tires are vented for quick pressure changes, so are allowed to lose up to 5% per day! Under inflation builds heat in the construction and even if fully inflated, jet aircraft tires do not have the unlimited taxi distances that cars do. Blow one of your two mains during RTO or landing on a tight runway at night and you lose half of your braking, plus some steering control. If one of your two tires was under-inflated, do you want to make bets on the condition of the second main tire and the rest of your braking? For more info: http://www.goodyearaviation.com/resources/tirecare.html
Back on subject, while air is only 21% oxygen, using nitrogen does slow the leakage rate slightly. Because the pressure differential increases with altitude and the higher leakage rate of the aircraft tires, using nitrogen can make a difference in jet ops. Use of nitrogen in car tires helps ever so slightly, but is more about marketing.
Dry nitrogen also won't introduce moisture that can freeze at altitude and give you an unbalanced tire on landing.
Super Tenere & WR250R, AMA, IBA
Wreckchecker is offline   Reply With Quote
Old 03-25-2014, 02:58 PM   #22405
roadrkt
roadrkt's Avatar
Oddometer: 16
Question Is this a good deal?
New 2013 ST $10,999.00???
http://hallsmotorsports.com/shop/lan...-super-tenere/
roadrkt is offline   Reply With Quote
Old 03-25-2014, 03:20 PM   #22406
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,603
Originally Posted by roadrkt View Post
Looks good to me.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 03-25-2014, 04:08 PM   #22407
tcourdin
Resident Spooner
tcourdin's Avatar
Oddometer: 10,623
I'd say thats a smoking deal! I've been looking at one for the same price, I'm still considering jumping on it. If I didn't want the electronic cruise that comes on the '14 I'd have bought it already. I'm sure I'll be paying alot more for a '14 though so I don't know if it's worth it.
I also looked at a KTM 1190R today, ugh the decisions are killing me!
My SPOT
tcourdin is offline   Reply With Quote
Old 03-25-2014, 04:32 PM   #22408
NSpooner
Oddometer: 65
yeah I've seen a few places with them for $11k. Sucks because I really want to buy used to save a few bucks but these prices are pretty insane.
NSpooner is offline   Reply With Quote
Old 03-25-2014, 05:58 PM   #22409
scudrunner82
Oddometer: 2,157
Well now that was one insightful post. Our mechanics just changed a relatively new right-outboard tire/wheel because it had a high leak rate and they couldn't find the leak. They were going to have the wheel inspected for a crack I guess. Its amazing how fast we go through tires and they do so few miles! I guess as for the nitrogen, the fuse plugs in the tires will prevent injury due to a tire explosion with hot brakes, but they won't stop a fire with the oxygen in air... Now it makes sense.
Much too technical for my meager brain. They can train a monkey to push the throttles up.
Old 03-25-2014, 06:44 PM   #22410
techgeek
Oddometer: 148
Originally Posted by twinrider View Post
nice seat but nearly $600 seems kind of stiff for an inch or two. I guess I gotta pay to play!
too bad this isn't a klr and I can't stack up a few of those walmart atv pads..
edit: just read this post, and had to throw in a "THAT'S WHAT SHE SAID" or a "that kind of bargain might have saved my marriage!" comment!
techgeek screwed with this post 03-25-2014 at 07:21 PM
Times are GMT -7.   It's 04:43 AM.
