Old 01-05-2011, 10:08 AM   #6256
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,770
Originally Posted by jdpower View Post
I think I see a worker or two smoking pot and drinking some beer on a lunch break.
JDP
After which they went to work building Baldy's bike
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 01-05-2011, 11:23 AM   #6257
markjenn
Oddometer: 10,483
Originally Posted by jeffs900s View Post
To get around the alu bar and heat loss issue, just use a piece of foil heating duct tape between the heating element and the bar. Works awesome and really reduces heat lost into the bar (only an issue on the non-throttle side obviously).
This may help, but I have two bikes that are essentially identical with respect to their heated grips setup but one has a steel handlebar and the other an aluminum. Even with a good wrapping of heat shrink under the heated grip elements, the alum bar bike has drastically reduced heat from the heated grips, even on the throttle side. The idea of using something with a foil back is a good one... I may try this.
In any event, I'm not planning on swapping the S10's steel bar for an alum one.
- Mark
Old 01-05-2011, 12:17 PM   #6258
Jeremy L
Jeremy L's Avatar
Oddometer: 185
Just finished this video about a week ago, and wanted to get a sense how many of you will be riding off road? What hard parts are you currently considering?
Venture on.
AltRider.com
Jeremy L is offline   Reply With Quote
Old 01-05-2011, 01:02 PM   #6259
martinh
SSYSO Recruiter
martinh's Avatar
Oddometer: 246
Hey Jeremy, I like to be able to take this beast off road once in a while and not have to worry about it. I like your bash plate, looks nice and thick. What is the weight on it? Also your crash bars are growing on me, I will probably be ordering them also. What is the weight of them? I just think the back of them should go up a little highter to follow the lines on the fairing. Any plans for a Version 2 on them soon?
Are you going to be at the NY show displaying any of your products there?
Super Tenere 2012
Versys 2011 Sold
DL1000k6 Sold
XR650L K6 Sold
martinh is offline   Reply With Quote
Old 01-05-2011, 05:53 PM   #6260
upweekis
upweekis's Avatar
Oddometer: 2,758
crash bars for sure
Piss on the "Urban Dictionary" -- Speak English!
upweekis is offline   Reply With Quote
Old 01-05-2011, 06:32 PM   #6261
Chadx
my toot toot
Chadx's Avatar
Oddometer: 2,169
Originally Posted by Jeremy L View Post
...and wanted to get a sense how many of you will be riding off road? What hard parts are you currently considering?
I'll definitely be riding mine offroad. Right now, planning on doing mods in two phases. I've included more than just hard parts just to give a feel for what mods rank where with me personally.
First phase (will be ordered and waiting before bike gets here):
Skid plate
Crash bars
Bar risers.
New top clamp and attached heavy duty hand guards (will shelf factory ones).
Top clamp ram mount for GPS.
Heated gear harness and GPS circuit.
Soft saddlebag racks (for use with my existing dry saddlebags)
Aftermarket windshield
Headlight shield
Second phase:
Install fuse block with two or three circuits
Install dual powerlets in top clamp
Replace rear rack with more robust unit
Top case
U-joint guard
Rear brake master cylinder guard
Possible future additions:
Hard panniers
Exhaust heat shield
LED Driving lights
Wind deflector kit
Off the road again...just can't wait to get off the road again.
The life I love is making roost with my friends.
Chadx is offline   Reply With Quote
Old 01-05-2011, 06:57 PM   #6262
Animo
Beastly n00b
Animo's Avatar
Oddometer: 4,993
Skid plate
Crash bars
Bar risers.
Headlight shield
Second phase:
Top case
U-joint guard
Hard panniers
Exhaust heat shield
LED Driving lights
Wind deflector kit
Sweeeeeeet
Life is good, even in adversity!
Yucatan | Chiapas | Belize 1 | Belize 2 | QRoo | Guanajuato
Animo is offline   Reply With Quote
Old 01-05-2011, 08:08 PM   #6263
japako
japako's Avatar
Oddometer: 592
Pretty close to what Chadx is planning.
Skid plate
Crash bars
Rox risers.
New top clamp
Headlight shield
Top case
U-joint guard
Givi Trekkers cases
LED Driving lights
Wind deflector kit
Side stand plate
Abs on/off switch
Windshield bracket adjuster
Remove pilon and replace with plate.
New style battery
Replacing all regular bulb lights(except head lamps) with LED bulbs.
I have some of these items from my old bike, but will be ordering soon, the rest of what I need.
japako is offline   Reply With Quote
Old 01-05-2011, 09:35 PM   #6264
kpmsprtd
Oddometer: 134
Minimalist at first...
  • wind deflector kit
  • heated grips
I will also replace the windshield if I find it to be problematic.
kpmsprtd is offline   Reply With Quote
Old 01-05-2011, 10:12 PM   #6265
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 2,072
Laugh Decisions, decisions...
I'll be riding off-road, though I have to admit that probably 70% or more of my riding will be on pavement. That's just the nature of the beast down here where I live. Will probably be a lot of dirt roads, but I'm not even sure I count that as truly "off-road"...
What "hard parts"?
Well, the ones that will be there almost from the start are easy...
- Throttle lock - probably a Kaoko.
- Hard bags - not fully decided which at this point.
- Better rear rack - probably yours there at ALTRider, as it looks the best so far.
- Engine guards - and again, ALTRiders look the best so far.
- Skid Plate - as much for our busted up, crappy roads as off-road, and as above ALTRider's is definitely a front-runner.
- Some add-on fuse box arrangement for easy tap-in for electrical farkles - undecided as to which one at this juncture
- Some way to mount my radar detector - just like I have on all my bikes.
Those are to start... Now to be added, as needed or wanted...
- If past experience is any guide, either a windshield adjuster like WaspWorks, or a different windscreen. I've had good luck with CalSci's in the past.
- Maybe a GPS mount
- Most likely a differing handlebar clamp like the HDB one discussed on another thread. Great place for power sockets and switches for those electrical farkles.
- Additional tie-down hard points for lashing down duffles, etc.
- Maybe some tool tubes for extra small item storage if I can find a less than conspicuous place to mount 'em. Don't wanna' have the hard bags on unless I have to.
- Possibly rear master cylinder guard and shaft boot guard, like ALTRider's, but I've never run into those as being a problem so... I dunno'...
- MAYBE an ABS on-off switch... maybe...
- Perhaps a set of driving lights
Things I know I'll have, but I have a tough time calling them "hard parts"...
- I always have a small seat/tail pack and tank bag I can use on all my bikes. If one of the different ones I already have won't work well on the S-10 then I'll find ones that will.
- Same with some sort of larger duffle bag to go across the top of the seat and top of the hard bags for longer trips.
- Liner bags for the hard bags.
One thing I would like to suggest, or request, of you guys at ALTRider... some sort of dedicated storage container for that neat spot you have developed under your rear rack. I really like your idea there, but the icing on the cake would be some optional carrying cases for that spot. Perhaps a canvas or cordura bag that fits specifically in there, maybe even with attached straps to make it quick and easy to lash in there. Perhaps an injection molded plastic container that fits in there and has attached loops that allow it to be strapped in that spot easily. You've already come up with a great universal spot for people to add their own solutions to stuff in there, but offering a fitted solution or two that can instantly add another storage spot for tools, flat repair gear, first aid kit, etc. would automatically free up riders' other carrying rigs for other gear...
Just a thought.
Thanks for asking what we'd like to see. I know I'm looking forward to sending some coin your way!
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 01-05-2011, 10:51 PM   #6266
Chadx
my toot toot
Chadx's Avatar
Oddometer: 2,169
Originally Posted by Dallara View Post
... some sort of dedicated storage container for that neat spot you have developed under your rear rack...Perhaps a canvas or cordura bag that fits specifically in there...Perhaps an injection molded plastic container
I second that with a preference for a small hard case over a cordura pouch. I wonder if any of the existing pelican cases are close. It would be a great place to stow items you rarely use (hopefully anyway) but always want to have with like flat repair kit and other emergency supplies.
Old 01-06-2011, 04:55 AM   #6267
upweekis
upweekis's Avatar
Oddometer: 2,758
And Please, when you write the installation instructions, include Torque values for the fasteners.
Old 01-06-2011, 05:48 AM   #6268
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,832
If I wasn't going to ride her offroad, I wouldn't have bought it.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 01-06-2011, 06:37 AM   #6269
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,466
Front mud guard extender
Found this today at POWERBRONZE.co.uk, orderd one. Expensive, 25 + 8 postage but I am fed up with the crud that the front wheel throws over the engine.
http://www.powerbronze.co.uk/2260609...-%20BLACK.item
Old Git Ray is offline   Reply With Quote
Old 01-06-2011, 06:58 AM   #6270
colorider
colorider's Avatar
Oddometer: 123
They show up on the USA site as well!!! Cool!!!
$37.24
http://www.powerbronzeusa.com/Shop/P...&MC_ID=1564303
Rod
'14 FJR1300A
Loveland, Colorado ~ USA
colorider is offline   Reply With Quote
Times are GMT -7.   It's 07:54 AM.
