Old 02-20-2011, 07:25 AM   #6976
pinglow
pinglow's Avatar
Oddometer: 237
Originally Posted by colorider View Post
This is the first thing I change on EVERY bike I purchase. BTW, the P/N's of the BMW grips are:
L 32721458395
R 32721458396
Rod
FYI the bmw ribbed grips are slightly shorter than the oem ones. About 5-10mm short. But I like them and have them on too. I positioned them somewhere in the middle so the shortness is not very obvious.
Ready to RACE!
pinglow is offline   Reply With Quote
Old 02-20-2011, 07:56 AM   #6977
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,293
If it is any consolation, my right hand gets numb sometimes on the Duc, and it has like ZERO vibration that I can feel. Different gloves helps some, riding conditions tho usually dictate.
I hold the throttle with my left hand for a short and stretch my right thumb and fingers. The thumb area is what goes numb.
14 KTM 1190 Adventure
14 500xc-w plated
llamapacker is online now   Reply With Quote
Old 02-20-2011, 08:28 AM   #6978
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
Originally Posted by RogerJ View Post
SuperCruise is not the only one. In my case my right hand goes numb after 60-80 kms at those highway speeds he mentions beginning at 120 kph indicated. I grip the bar very lightly and use peg weight and other tricks of the trade.
I have had this buzzing since the bike was new and now have 3,700 kms. Early on I thought this might have been due to a new tight motor but it has not gotten better. I have had lots of bikes, yes including all those Brit twins in the 60's and 70's included but none have done this such that my hand goes numb. Maybe was just lucky in the past. BTW I have stock non-heated grips to which I have added Grip Puppies but no significant improvement.
This kind of vibration can come from:
1. Accessories not installed correctly such that they transmit vibration which gets picked up in the bars.
2. Bolts not set to proper torque, especially in the motor mounts.
3. Tires or rims not within specifications (run-out, roundness) and/ or not alligned or balanced properly.
4. The motor itself.
The first 3 are most easily addressed causes. My dealer wants to help and has just done these first three steps. I am about to see if there is any change and will let you know.
Vibration affects different people differently. For me having a hand go numb no matter how lightly one grips the bar or how often or creatively one shifts the hand position on the bar is not a minor problem if it leads to a hand that can not grip and brake effectively in the moment. As you know the front brake triggers the real braking power in this bike. The brake pedal does very little.
I will keep you posted of what gets tried and what the result is. As always, I appreciate positive constructive comment, and particularly from those who own this bike and have spent some time with it.
Don't get me wrong. This is the best bike yet. It is just this one aspect that needs a fix. Cheers!
Check your throttle body sync. My R1200RT used to put my pinkie finger to sleep after 20 minutes, even after it's first service, which was supposed to include a valve adjust and TB sync. But after I started doing my own servicing and doing the TBs myself, I never had a problem with fingers going to sleep after that. I could also feel when the sync was going out. That was on a brand new bike as well so don't just assume that the TBs are sync'd properly.
Old 02-20-2011, 10:00 AM   #6979
A Knight Who Says Ni
Oddometer: 837
You see this is really funny and just an example of how different people feel different things on bikes.
I test rode a multistrada. At lower speeds that thing vibrated like an unbalanced washing machine on steroids. Each stroke of the engine was like a giant hammer pushing the bike forward. It wasn't something specific to the hands but to my whole body all the way down to the pegs. The rear view mirrors were also completely unusable due to this vibration.
A Knight Who Says Ni is offline   Reply With Quote
Old 02-20-2011, 11:12 AM   #6980
RogerJ
Waypoint Wanderer
RogerJ's Avatar
Oddometer: 222
Handlebar Vibrations XT1200Z What To Do?
Helo everyone!
GrahamD.....thanks for the synthesis.....I agree that is what we are dealing with and what must change. If anyone uses sand should put it in the over for 30 minutes to ensure it is absolutely dry. An accelerator and data logger? Not here in S. Mexico. BTW, I am little short of ready cash or, of course, I would buy you an S10 so you could address this issue. ;-D
SuperCruise....it is not in your head as Bundu says. The problem you and I have is an exception for these bikes. You may want to try Wasp's test without the weights and handguards (see thread above) and report. Check to see if the bothersome vibrations are less, same, or more at what cruising speeds and what revolutions especially in 5th and 6th gears for highway speeds and report what you find.
dcstrom.....will try Wasp's test as well in T and S modes. SuperCruise founnd it didn't matter.
Wasp......pulled off the weights and handguards. Left the screw in the bar ends so I would have some bare metal to feel the vibration at the end of the bar (cause I have Grip Puppies on). Got up early this morning to do the test on my favourite isolated road. Long story short......the boys-in-blue with radar pulleld me over and after a very long discussion let me go. Didn't want to push my powers of persuasion on a second stopping. They were everywhere today. So......bear with me. Will try again tomorrow and get back. Will PM you when I have the results of careful study. Thanks for standing by Greg.
All of your comments much appreciated.
XT1200Z; F700GS; F650
RogerJ is offline   Reply With Quote
Old 02-20-2011, 11:47 AM   #6981
llamapacker
Mr. Conservative
Oddometer: 1,293
I test rode a multistrada. At lower speeds that thing vibrated like an unbalanced washing machine on steroids. It wasn't something specific to the hands but to my whole body all the way down to the pegs. The rear view mirrors were also completely unusable due to this vibration.
The mirrors are a blur, if I want to see way back, have to steady one with my hand. So, yeah guess it does vibrate (but mostly below 4k rpm), not the buzz like in the Versys tho. The Tiger 1050 was of course silk smooth and great mirrors.
Anyways, I can't wait to find out how the S10 is going to be. I do not remember any vibration on the short 15 minute demo.
14 500xc-w plated
Old 02-20-2011, 12:10 PM   #6982
Oddometer: 837
yes the Tiger 1050 is extremely smooth. That motor is beautiful and probably the best part of the bike.
I'm looking to pick up a speed triple at some point
Old 02-20-2011, 05:18 PM   #6983
Buckeye56
Batoutahelius
Buckeye56's Avatar
Oddometer: 202
+1! I had a 955i Daytona and loved the motor. Triumph's triples rock!
2012 Super Tenere
Trying is the first step towards failure.
Buckeye56 is offline   Reply With Quote
Old 02-20-2011, 09:08 PM   #6984
SuperCruise
SuperCruise's Avatar
Oddometer: 329
Finally got sick of my GPS power adaptor jiggling its way out of the DC socket every 30 mins over the course of a ride so changed it over for one of the heftier Jaycar units that have served me well on other bikes.
The wires on the Yamaha one, which run direct from the fuse box, are nearly as thick as those of the Jaycar unit which can handle 10A easily so I bumped the DC socket fuse up to 10A while I was there.
Works good and finally my GPS power adaptor will keep in place in all but the bumpiest of conditions.
And yes, I did wrap the exposed wires in pics 1 and 2 with insulation tape.
XT1200Z Super Ténéré 2010
Around Australia, Super Tenere Style
SuperCruise screwed with this post 02-20-2011 at 11:51 PM
SuperCruise is offline   Reply With Quote
Old 02-21-2011, 12:00 AM   #6985
the darth peach
eats crackers in bed
the darth peach's Avatar
Oddometer: 11,397
Pretty fun ride today….
The 2012
the darth peach is offline   Reply With Quote
Old 02-21-2011, 12:05 AM   #6986
SuperCruise
Oddometer: 329
Did a throttle sync today and, apart from having to prop the fuel tank up to get to the required bits, it was pretty easy. No need to put the bike into any service mode, just connect up the vacuum gauges (T-connector required on the left one), bring it up to temp at idle and measure away and tweak air bypass screws as required.
The following pictures show how to connect up the vacuum hoses to the throttle body. Note that in the first picture (left side) I have pulled out the T-connector so you can see it but it otherwise sides down beside the radiator hose and there are no kinks in any of the hoses.
My bike only has 5000 kms on the clock, so I was only really checking throttle sync as one of the potential culprits for handlebar vibration. Turns out it was just in spec (1cmHg differential max) but I tweaked it anyway to get the gauges as close to even as possible. I had to turn the right air bypass screw about 1/8 turn CCW, which I then dabbed with loctite. Here are the before and after readings, noting that is hard to get a representative photo because they pulse at a different phase.
I haven't ridden it yet, but it seemed similarly smooth to rev as before so I'm not expecting to see much difference on the vibration issue. I'll report back if it has magically fixed it!
SuperCruise screwed with this post 02-21-2011 at 12:17 AM
Old 02-21-2011, 12:06 AM   #6987
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,433
The 2012
That pic does look kinda mean and moody...
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 02-21-2011, 12:09 AM   #6988
Oddometer: 837
The 2012
this smoking hot pic will my desktop background for the next two months... thanks
Old 02-21-2011, 12:12 AM   #6989
the darth peach
Oddometer: 11,397
Here's a better one
Old 02-21-2011, 12:18 AM   #6990
Oddometer: 837
Times are GMT -7.   It's 01:59 PM.
