Old 06-15-2011, 07:59 AM   #8341
fredz43
Location: Illinois- land of straight, flat, boring roads.
Oddometer: 660
Originally Posted by dcstrom View Post
Still mounts to the sump up front though? or are these set up somehow that they can't damage the engine the same way the OEM one can?
I believe the problem with the OEM is the rear mount, which bolts directly to the sump underneath.
fredz43 is offline   Reply With Quote
Old 06-15-2011, 08:12 AM   #8342
sail2xxs
Oddometer: 125
If you smack the front of any of these plates, what "gives"? I would hate to look down and discover an important, un-duct-tapable or un-JB-weldable piece of the engine missing.
I got lucky with the GS the second time - the bracket for the plate broke. Pics of both incidents @ post 7: http://f800riders.org/forum/showthre...103#post465103
Chris
sail2xxs screwed with this post 06-15-2011 at 08:36 AM
sail2xxs is offline   Reply With Quote
Old 06-15-2011, 08:51 AM   #8343
~TABASCO~
www.rideonadv.com
~TABASCO~'s Avatar
Oddometer: 380
Originally Posted by Goldie05 View Post
Wow, looks like 8 bolts need to come out so you can get to the filter for an oil change
With the miles I do it will become a pain pretty soon
Looks like I will be making a little mod to the unit to add a few more bolts just so I can get the filter out
Picture shows it still being bolted to the sump... NO WAY for me... No you dont pop a hole in the rear,,,, you blow the whole front out.. I know the SW guys are thinking they are using the plate as a fulcrum, and they think they are safe with those front sump mounts, but not for me...
Thanks for posting pic....
~TABASCO~ is offline   Reply With Quote
Old 06-15-2011, 11:19 AM   #8344
bross
Where we riding to?
bross's Avatar
Oddometer: 4,695
Are those solid metal collars or are the two sump bolts rubber "bumpers". If rubber bumpers I can see that being about the best solution you could hope for. The plate will take most of the hit with the bracket but a serious hit will be further absorbed by the rubber bumpers, if they're rubber.
Old 06-15-2011, 11:31 AM   #8345
fredz43
Oddometer: 660
They are rubber.
Old 06-15-2011, 11:33 AM   #8346
jdpower
jdpower's Avatar
Oddometer: 644
Have you seen any of the others and how they are bolted up? I will have to research this but thought I could talk someone else into doing that . Hey how about using 3M dual lock for the front
JDP
jdpower is offline   Reply With Quote
Old 06-15-2011, 12:57 PM   #8347
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,476
The SW engine guard does bolt to the sump in the mid section (lower front) but it is not direct to the bash plate. The extra metal plate allows some measure of flex and rotation onto rubber supports. So any shock is distributed over a large area after having the sting taken out of it. It bolts to 2 substantial lugs that protrude from the sump.
The front is bolted along with the two side casings on either side of the bike, to the crank case.
The rear are bolted to the footpeg/sidestand supports, and again there is and element of flex built in. There are rubber shock distributore between the support and the sump.
On top of this all the 8 bolts to fix the guard to the supports are also all rubber mounted.
So, yes, it is fixed to the sump but not in the simplistic way that the Yamaha one is. There is no other way in reality to fix a guard to the bike due to the engine being a stress member and it having no front frame.
Oh and BTW, it does need 8 bolts to be removed to change the filter (I've just done it) and the front 4 are loose nuts and bolts. Its a bit fiddly but its only 5 minutes work. The nuts (#23 on the diagram) are the integral washer type so can be easily held in place with a ring spanner.
I have today been out and hit my SW guard several times in the same location (boulders) that I wrecked the Yamaha one. All is still good.
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray screwed with this post 06-15-2011 at 01:06 PM
Old Git Ray is offline   Reply With Quote
Old 06-15-2011, 01:01 PM   #8348
Rema in Paluda
Rema in Paluda's Avatar
Oddometer: 563
Just put an synthetic numberplate bolt in it, it prevents the alu bell to ring effectively put will sheer op at greater impacts
Rema in Paluda is offline   Reply With Quote
Old 06-15-2011, 04:53 PM   #8349
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,400
[QUOTE=dave6;16170514]
Originally Posted by sail2xxs View Post
250 mL oil? Troll food! It's an oil burner. Synthetic? Regular Rotella T? Which filter?
1/4 of a quart since Salt Lake City (normal for other brands) where the service was done, my other Yamaha's would not use oil between oil changes. I wonder how this bike was broken in, if it was fired up and run on the freeway for days or if the proper break in was followed. I think proper break in is important to seat the rings properly. I guess I will find out when mine comes in 2 months. Still if that's all he's added since then, no big deal.
If it is the one we rode at IMS Dallas in Nov., it got worked pretty good!
What bash plate does Nick have on his bike?
14 KTM 1190 Adventure
llamapacker is online now   Reply With Quote
Old 06-16-2011, 12:17 AM   #8350
Brendan J
ONE HACK AT A TIME
Brendan J's Avatar
Oddometer: 1,563
Force Bash Plate
G'day all !!! Sometime ago I posted some photos up of a new bashplate being designed by Force Accessories here in Australia. I will have the final version in my hands by Wednesday 22 June. A retail price as finally been set at $240 AUD. The plate be removeable by 4 bolts to do an oil change if needed. It is constructed of 4mm aluminium cut from one sheet folded and tig welded. Mounting brackets are made from stainless steel. The plate will come only in a black polymer coating. I will endeavour to post photos up as soon as I can.
Brendan J is offline   Reply With Quote
Old 06-16-2011, 01:57 AM   #8351
GrahamD
GrahamD's Avatar
Oddometer: 5,423
Thankyou!
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 06-16-2011, 03:32 AM   #8352
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,945
I'm wondering not if, but how many times, Nick Sanders bike has been on it's side and this 250cc bit ought to be expected.
Appreciate the SW bash plate illustration and look forward to comparisons. Still looking and still not found one I'm totally satisfied with.
Super Tenere & WR250R, AMA, IBA
http://s198.photobucket.com/user/Che...France%20Spain
Wreckchecker is offline   Reply With Quote
Old 06-16-2011, 04:36 AM   #8353
Tee Dee Mmm
Tee Dee Mmm's Avatar
Oddometer: 1,636
By the book filter change only every 2nd service and add these http://www.off-the-road.de/XT-1200-Z...ve-Yamaha.html to make life quicker and less messy.
Cheers Rick
Tee Dee Mmm is offline   Reply With Quote
Old 06-16-2011, 08:16 AM   #8354
protondecay123
protondecay123's Avatar
Oddometer: 466
Originally Posted by A Knight Who Says Ni View Post
not a big deal, buddy... just messin with ya
If you want to look over the manuals, here they are for free download. http://www.konepool.demon.nl/de_xt1200z_pagina.htm
But if you post the question about service intervals a third time, I will have to fart in your general direction!
Thanks for posting that!! Just what I was looking for!
Sometimes the Lights are all Shinin' on Me
Other times I can barely see
Lately It Occurs to Me
What a Long, Strange Trip it's Been!
protondecay123 is offline   Reply With Quote
Old 06-16-2011, 12:14 PM   #8355
jdpower
jdpower's Avatar
Oddometer: 644
When I tried to open that link for the service manual I get "no result". Do you think it has been closed off?
JDP
Times are GMT -7.   It's 07:07 PM.
