09-01-2011, 06:27 AM
#9256 |
Let's go adventuring...
Oddometer: 251
Sans cat exhaust
Just changed the OEM exhaust for the OTR Racing headpipe http://www.off-the-road.de/XT-1200-Z...-XT1200-Z.html and have noticed an increase in power and less fuel comsumption although will have to adjust the mixture to prevent sputtering and the 'ratatatatat' noise ... I'm wondering if the Power Commander V (PCV) (http://www.off-the-road.de/XT-1200-Z...er-Tenere.html) will do the work or I'll have to depend on service at a Yamaha dealer ... Bargenator and Bundu maybe have the clue ... both have helped with other troubles such as the GIPro Gear Indicator ... and have more to come such as making an accelerator pedal instead of the throttle control on the handlebar (I had a severe case of Arthritis Rheumatoidea) which is harming my wrists, and a cargo platform to replace the pillion seat. Will post photos of the installed headpipe which left some purchased protection obsolete (http://www.off-the-road.de/XT-1200-Z...-XT-1200Z.html), so I am on the look for a bash plate with a high side on the right hand side such as the one shown here (http://www.off-the-road.de/XT-1200-Z...er-Tenere.html) ... strangely no photo of the right side ... or I will have to develop a full right hand protection using the fitting points left by the removal of the OEM headpipe.
Cheers, Roberto aka Thagua ![]() ![]() ![]()
09-01-2011, 11:21 AM
#9257 |
Yamaholic
Oddometer: 318
um, that's not what you said. You said only with S could you achieve full power. Simply not so.
![]() Just trying to be accurate.
'06 R1 LE, '13 FJR, '12 XTZ12, '09 T Max |
09-01-2011, 11:48 AM
#9258 | |
Oddometer: 837
yes I mean that only using S can you experience the full power output. I'm talking about feeling power because the gentleman was talking about what the engine felt like on a test ride. I'm not talking about what a dyno would say if you open the throttle all the way on T or S mode. (And according to you, you would still have to open the throttle wider in T mode to achieve the same power) I don't know or care about that Anyone who has ridden this bike will tell you that S feels more powerful that T. So no matter how it is done or what the mechanism is, power is more limited on T. (And yes that includes making the throttle less responsive) You are nitpicking semantics by saying that technically if you simply open the throttle more using T mode, you are getting the same power output. |
09-01-2011, 03:15 PM
#9259 |
Oddometer: 103
Full throttle in both modes provides the same power output then.
This is significantly different than not achieving full power unless in s. I consider this a good clarification, not nitpicking, but I suppose now I'm nitpicking! Anyway, feels more powerful in s than t, that is simple enough, and widely reported. That makes sense too. |
09-01-2011, 03:30 PM
#9260 |
Now retired...YeeHaa
Oddometer: 816
There were some dyno figures put out last year by a German company who showed that there are actually differences in the power output between S and T. I believe they were posted in this thread but it is too big to look up (I know I tried before).
IIRC it only effects the lower 3 gears but the bike does not produce full power in 1st and 2nd gear in either mode, possibly in third too. |
09-01-2011, 06:52 PM
#9261 | |
D S N
Oddometer: 271
I don't know where I'm going but I won't be late! |
09-02-2011, 05:13 AM
#9262 |
Supa10 pilot
Both fork seals weeping...
Whats the deal with fork seals on the Super Tenere.. Any of you long term owners had to replace them yet?
I had my bike over at the dealers workshop for service (trucked it there but definitely did not yank down on the load straps)(and certainly saw no sign of leaking when the bike was taken off the truck), and when I went to pick it up today I find both legs weeping at the seals??? WTF.. ![]() Has anyone had to replace their seals yet...? My bike has done around 14500kms and is 13 months old. Fork legs are not pitted, bent, or dented and I see no reason why they should be leaking now. If these seals are only lasting 14,500kms at $200 a set to have them replaced at the dealers, should I expect to spend $1400 on fork seal maint in the first 100k???? I think (and certainly hope) NOT... Greg.
The original WaspWorks S10 detail & evolution thread: http://www.advrider.com/forums/showthread.php?t=595933 The NEW "Long Term" WaspWorks S10 detail & evolution thread: http://www.advrider.com/forums/showthread.php?t=778809 |
09-02-2011, 05:26 AM
#9263 | |
Oddometer: 451
I can't post more than one attachment, so here's the link to German web http://www.tenere.de/forum/index.php...27584#msg27584 and here is the graph that I have felt from day 1 |
09-02-2011, 05:38 AM
#9264 | |
Oddometer: 840
Mud is evil |
09-02-2011, 07:16 AM
#9265 | |
Oddometer: 1,524
Greg - I've been keeping a tally - you are now the 6th case I've heard of. You're in good company, Nick Sanders had the same problem on his Pan Am ride. I guess the fork legs are not well potected. Look at at the coverage on the the Tiger XC or the F800GS and you'll see there's a big difference. I put Dirtskins on mine in the first week. Hopefully they will preserve the seals... I also picked up a couple of Seal Mate tools in case they don't! dcstrom screwed with this post 09-02-2011 at 07:25 AM |
09-02-2011, 08:24 AM
#9266 | |
Where we riding to?
Oddometer: 3,520
Compress the forks halfway and use a rubber bungie hook to hook on the strap to keep the strap connected even over bumpy roads. I think what the S10 needs is a pair of these... ![]() Have you tried cleaning gently around the seals with a very thin feeler gauge or 35mm film (who has any film left anymore). |
09-02-2011, 08:42 AM
#9267 | |
Fast side of farty
Oddometer: 217
XT1200Z day to day workhorse. 888 strada (license buster in waiting), 900 superlight (sleeping for the winter whilst I think about a wheel swap/tyres) |
09-02-2011, 08:45 AM
#9268 | |
Where we riding to?
Oddometer: 3,520
09-02-2011, 08:46 AM
#9269 |
Oddometer: 1,524
Wasp, what kind of service? You're not at valve-check interval yet... can't think what other service a guy like yerself might be going to the dealer for?
09-02-2011, 09:09 AM
#9270 |
XT1200Z and DL650
Oddometer: 528
Greg, I added the Kriega fork seal guards to mine right away to ward off just this issue. I posted a thread on YSTF showing them if you are interested.
Try tucking a sealmate or 35mm film in and see if it just needs to be cleaned.
FS: XT1200Z Super Tenere Gas Tank Side Panel Guards, Rear Tank Guards, Fork Tube Guards, Headlight Masks and Exhuast Shield Masks http://advrider.com/forums/showthread.php?t=714789 FS: V-Strom Frame guards, triple-clamp guards and THE ORIGINAL Headlight Masks http://www.advrider.com/forums/showthread.php?t=356383 |
