Old 09-28-2011, 02:38 PM   #9586
Krabill
Krabill's Avatar
Oddometer: 3,539
Originally Posted by freeflow View Post
so I cycled the key on and off several times to verify the wiring and voltage etc.....then I left the bike sit for about 4 days....when I pulled it out to go for a ride....it turned over and would not fire...I thought maybe I effed up some wiring....nope...
basically, I guess cycling the key on and off and pressurizing the fuel system repeatedly, and not starting it, floods the bike somehow.....to fix this...hold throttle wide open and crank it over....and after about 5-10 seconds it fired and stumbled for a second, blew out a small puff of unspent fuel and has been running and starting like it's normal excellent self ever since....
so there, FYI....not an issue to not buy it though
If you turn off the kill switch the fuel pump won't cycle when you turn the ignition key on, fyi.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 09-28-2011, 02:46 PM   #9587
tomatocity
Retired and lovin' it
tomatocity's Avatar
Oddometer: 633
Originally Posted by pluric View Post
I put a power bar on mine to run Heat-Trollers and BMW outlets. I used this plug for the relay
trigger wire. It's only hot with the key on.
Nice placement. I would like to know more.
Tim
2012 Yamaha Super Tenere #027, 2005 KLR, 1993 Chevrolet S10,
tomatocity is offline   Reply With Quote
Old 09-28-2011, 03:03 PM   #9588
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,730
I'll post a few more pics when I get home to the bike.
pluric is online now   Reply With Quote
Old 09-28-2011, 03:18 PM   #9589
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 12,782
I know you guys have spoken it, but the heated grip connector is in a picture linked off of my signature block below
MoBill is offline   Reply With Quote
Old 09-28-2011, 03:22 PM   #9590
MoBill
MoBill's Avatar
Oddometer: 12,782
....same for the eastern beaver fuse box as well.
Old 09-28-2011, 06:21 PM   #9591
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,730
I used this universal fuse box set up.
http://www.electricalconnection.com/...ion/pplate.htm
Plenty of room under the seat it fits perfect in the front area.
It has 6 outlets. I had three left after the Heat-Trollers and one BMW outlet.
I mounted the relay at the top of the tool kit area.
I used the power plug to the Yamaha heated grips for the relay trigger wire.
I pulled the rubber plug on the brown wire, tinned the trigger wire and shoved
it into the plug. Used the original rubber plug, tight fit, to hold it in place.
The first Heat-Troller controls the grips. The second one does the heated vest BMW outlet.
I like to paint the Heat-Trollers with liquid electrical tape just cause.
Old 09-28-2011, 06:27 PM   #9592
GrahamD
GrahamD's Avatar
Oddometer: 3,921
Very nice job.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 09-28-2011, 06:34 PM   #9593
Mikef5000
Oddometer: 1,691
Nice find on that fuse block! I've been using this generic one, but that looks way better!
Of course this one is only $9.
Hm.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is online now   Reply With Quote
Old 09-28-2011, 06:37 PM   #9594
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,730
While I'm on the farkle kick I was messing around with some stuff I already had
lying around. The Wolfman tank panniers were not wide enough for the Tenere.
I also didn't want to block the cooling system.
Turns out they are just right to go around the factory bag. Easy to loosen to
open the bag if needed. I have top bags for the top of the bags too.
Found this Kolpin set buried under some other stuff. Fit perfect over
the KLR's trunk. So for water or fuel. Might get a little top heavy.
Made this quick to get the drink bottle out of the tank bag away from cameras and ipod.
I would be helpless without my head bolt loser.
Old 09-28-2011, 06:48 PM   #9595
Krang
Krang's Avatar
Oddometer: 248
Anyone in Northern, IL who has a S10 I can throw a leg over? Can't find a dealer with one in stock to even just sit on.
Krang is offline   Reply With Quote
Old 09-29-2011, 09:11 AM   #9596
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,730
Hm.
I just like the other style because it is designed to be switched by the key.
It also has a hot wire for battery charging. I use the always hot BMW outlet
for charging so I've never hooked up the charge wire. Used the same set up
on two FJRs and a Strom without any problems.
Old 09-29-2011, 02:33 PM   #9597
tomatocity
tomatocity's Avatar
Oddometer: 633
pluric, thanks for the additional power bar photos. Thanks for the Wolfman pannier and water bottle placement suggestions.
Panniers would be nice with the straps trimmed to secure over the sidecase handles.
Tim
Old 09-29-2011, 04:41 PM   #9598
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,730
The factory straps go under the Yamaha bag and hold it top and bottom.
Seemed very secure.
I did a double up ride to Jackson with my wife. I bought a couple flat bottom
duffle bags from a discount outdoors place. Under $10, It's the KLR owner in me.
I knew I would want the additional storage room for womens stuff. I was trying
to run the top trunk empty for shopping space. She didn't buy a thing!
Anyway, they worked out perfect.
I just shortened some quick release packing straps and used the handle holes
so it couldn't slide left or right.
I did put an extra loop through the upper handles and the passenger handle to be sure.
They didn't move at all. If you're worried about weather just put a garbage sack in first
before loading the bags. I also use those shrink down packing bags that are waterproof.
Old 09-29-2011, 04:53 PM   #9599
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 11,730
Home Depot has these Husky receipt bags that make a nice heavy duty tool bag.
Has a little card window that I put my extra keys in.
I replaced the factory crap with a little better China crap.
The rear wheel nut is 27mm and I added the front axle hex too.
Twice I've been on the road where a non Yamaha dealer wouldn't
remove the wheels for liability reasons. I know, What???
So I like to carry enough to pull them if I have to.
It will still roll up and fit in the factory tool kit area. With a little nudging.
I made a mounting plate for the Givi style trunks. After ordering Altrider crash bars
I decided to get their rack system too. It has a mini trunk that I'm hoping will hold
the inflater and tire plugs. I should be set after that.
Old 09-29-2011, 10:09 PM   #9600
DakarBlues
One-everythinged man
Oddometer: 1,271
Send a message via Skype™ to DakarBlues
Super Tenere 1200 Pharaon
Francesco Catanese Super Tenere.
raised suspension, 21" front wheel, heck tanks.
http://www.youtube.com/watch?v=S8iO8XzmR7E
He, whose nuts skim the ground while airborne, won't crash very far!
Pedibus Cum Jambus 1200 S
IBA # 38875
DakarBlues is offline   Reply With Quote
Times are GMT -7.   It's 06:39 PM.
