12-19-2011, 10:34 PM
#10486 |
Oddometer: 112
That was me that stated the S10 at "a bit over 3000 rpm at 100 klm/ hr" . Your right , that is at "speedo" speed , but there is no way in the world it is doing over 3600 revs at 105 ks.
But ,I wonder if there is a slight difference in gearing between the USA and OZ bikes that would give you that figure ? Brian |
12-19-2011, 11:03 PM
#10487 |
Oddometer: 50
My upgraded S10 Luggage Rack.
12-19-2011, 11:15 PM
#10488 | |
Oddometer: 9,698
MCN takes some pretty good data and it jives exactly with my experience. At 4K RPM in top gear my S10 indicates right at 78 mph. Back out the 8% optimistic speedo and this is 72 mph. Ratio this back to 65 mph and you get 3611 RPM, essentially the same number as MCN published. BTW, assuming your "bit over 3K rpm" is actually 3100 and assuming your 100 kph is actually 92.6 kph due to 8% speedo error, the math shows your RPM at a true 65 mph should be 3509 RPM.... close enough for government work. - Mark markjenn screwed with this post 12-19-2011 at 11:24 PM |
#10489 |
Oddometer: 50
Another pic.
6mm, 6082 Ali with stainless support bracket. Measures 300mm X 220mm across the middle. Cost is $175 excluding shipping. |
12-19-2011, 11:30 PM
#10490 |
Oddometer: 113
Re: walking speed of S10
Tire circumference between tire brands, even in the same size, can affect this. Wasp most likely had the knobbies on. It's my understanding the S10 has been shipped with two different tires as well, Tourance EXPs and another I cannot recall at the moment. |
12-19-2011, 11:35 PM
#10491 | |
Oddometer: 9,698
- Mark |
12-19-2011, 11:44 PM
#10492 |
BMWs make good landfill
Oddometer: 816
As the speedo drive comes from the gearbox changing to a different height tyre will make no difference to the relationship between speedo and tachometer. Real speed would vary though.
I was checking my own bike the other day, 100kmh (on the speedo) was around 3100 on the tach. With the speedo being around 8% out, that would be around 3350 at a real speed of 100kmh, didn't have the GPS on that day though. Currently running a Mitas E-09 140/80 rear tyre and not sure what its done to the speedo at this stage. Al |
12-20-2011, 04:27 AM
#10493 | |
Oddometer: 867
I also installed the SpeedDRD and after testing and tuning, it is now set at 6.1%, speedo now indicates slightly more than the GPS at any speed. That is if GPS shows 60mph the speedo now shows 61mph. I disagree that the difference is 8% as stated by Mark.
2013 HyperStrada 2012 Super Tenere 09 Monster 696 (wife's bike) |
12-20-2011, 05:17 AM
#10494 | |
? I don't eat a lot and would be entertaining to have around. I would ride whatever you bought and didn't want to ride. Please. ![]() doctorj |
12-20-2011, 10:02 AM
#10495 | |
WannabenarlyADV'rrrr
Oddometer: 325
Giant rider great riding
Boulder
Burn out dont fade away!! |
12-20-2011, 02:36 PM
#10496 | |
Oddometer: 3,814
The Guy in the Red is Francesco Catanese. He has been given a modified S10 to play with. with new suspension, wheels and push bike brakes. It probably feels like a 250cc to him. ![]() The main thing I am concerned about is what the bike can do when I didn't really mean to go in that deep. Like when I didn't see that 5 foot drop or wash out, multiple times on a crappy outback road over 300km. There is no way that I would normally do what a few of those guys are doing, I think. Maybe. ![]() But this is the other point that barely gets mentioned. The less you weigh, the more you will struggle on a bike like this. Someone who weighs 50Kg and is 5 foot 5" is going to be taking it easier than someone who is 6 foot 5" and 150Kg of solid muscle and fit. It would be good to see a 400cc twin for the smaller folk.
"It's better to ride a boring bike than push an interesting one" ... Canuman The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA. GrahamD screwed with this post 12-20-2011 at 02:43 PM |
12-20-2011, 03:05 PM
#10497 |
Oddometer: 304
Catanese (2m tall) is a good example that rider stature and ability can be related. Too many times you hear or read a guy saying that his GSA/S10 is impossible to ride off road, and then the next guy says the complete oposite.
Maybe people should start to mention their height and build each time they make comments about this bikes off road abilities. |
12-20-2011, 04:09 PM
#10498 | |
Oddometer: 351
12-20-2011, 06:34 PM
#10499 | |
Oddometer: 3,814
Sorry I did notice, just didn't respond yet. So whats the compromises between 6006, 6082 ALI etc etc etc. I've forgotten. Is 6082 almost as good as unaffordium. Cheers Graham
"It's better to ride a boring bike than push an interesting one" ... Canuman The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA. GrahamD screwed with this post 12-20-2011 at 06:50 PM |
12-21-2011, 04:48 AM
#10500 | |
UK GSer
Oddometer: 2,342
BMWs and Triumphs are generally a bit better in this respect, as they are largely built for European-sized ergonomics. However, in markets where they are trying to compete directly with the Japanese (especially the full-on sportsbikes) they inevitably get "shrunk" to Japanese proportions in order to be competitive, particularly when it comes to racing. The "sportsbikes for the road" like Triumph's T595 and the pre-S1000RR BMWs get seen as soft-options by the motoring press and generally lack the kudos of the more focused sportsbikes. They're consequently seen as less desirable by the public and fewer of them get bought (although those that do buy them tend to love them). One of the reason I like Adventure bikes is that they've generally got more sensible ergonomics for 6'2" 105KG me. I'm fairly strong, so picking up something like the Super 10 is not really a problem. Handling it on dirt is obviously trickier than a 250 dirtbike, but then, for someone my size the gap in terms of what you I do on them is much narrower than conventional wisdom would dictate. It always makes me laugh when someone makes an ignorant blanket statement along the lines of, "200kg is too heavy to take offroad, period!" No, it might be too heavy for someone of your stature, who isn't a particularly gifted rider, but as the videos show, they are far from incapable in the right hands.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back. |
