Old 06-02-2012, 12:12 PM   #12391
avc8130
Oddometer: 1,532
Originally Posted by Specterx View Post
Just got my new akrapovic exhaust and put together a quick video to compare it to stock.
Hope you like it.
http://www.youtube.com/watch?v=KHeaBo2lgh8
AWESOME video!
Do you have any other S10s near by? With other exhausts?
We need a comparo just like that!
ac
avc8130 is offline   Reply With Quote
Old 06-02-2012, 04:23 PM   #12392
GrahamD
GrahamD's Avatar
Oddometer: 5,322
Excellent with actual numbers. Good stuff
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 06-02-2012, 05:28 PM   #12393
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,189
World crosser is pretty cool...
http://www.yamaha-motor.eu/eu/produc...pg|ymeGallery1||
Europe only?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 06-02-2012, 09:37 PM   #12394
GrahamD
GrahamD's Avatar
Oddometer: 5,322
Another S10 Built in feature I found...
The people who designed the YAMAHA S10 obviously thought of a few things for the off road intrepid adventurer in mind..
Radiator out of the way
Able to cop a pounding off road.
Double sided swing arm.
Spokes
Big down low torque for that gnarly terrain.
Built in cigarette / camp fire lighter.
Never worry about leaving the matches behind again.
Easily accessible to get those camp fires started on a cold night....
Just let it warm up until the siren starts and rev it to 4K for 1 minute.
I think my motor is nicely balanced at low throttle settings at least
Cheers
Graham
Old 06-03-2012, 04:49 AM   #12395
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,717
A note for when folks are changing tires, especially for those new to Yamaha shaft drive:
When changing the rear tire, pop the 4 bolts that hold the rear differential, the pumpkin easily slides aft for removal, and do 3 things.
(1) Lube the shaft splines. Wipe off whatever is left of the factory grease and apply new. I've never heard of a Yamaha spline set failing but it is a wear point and tire changes are your opportunity. btw, the lower end of outboard motors use similar spline drives, have similar corrosion concerns, the grease works perfectly, and it's available in almost any car parts store.
(2) Spray some ACF-50, CRC, or other anti-corrosive spray on the shaft and other exposed metal. Again, never heard of a failure, but there will probably already be the start of some surface corrosion. The Max, FJR, and Tenere ALL do it. A quick spritz or wipe can stop it.
(3) There is a drain hole in the shaft housing that dirt and bugs can plug. Check that it is clear.
When re-installing, the shaft slides in easily, no circlips or other tricks. And it is EASY to overlook the washers under the 4 nuts that hold the pumpkin in place, so watch you haven't lost one.
Finally, put some anti corrosion spray on the axle, because it will rust and be hard to take out the next time if you don't.
Super Tenere & WR250R, AMA, IBA
Wreckchecker screwed with this post 06-03-2012 at 05:31 AM
Wreckchecker is offline   Reply With Quote
Old 06-03-2012, 06:31 AM   #12396
HUDDERS
Have Fun :-)
HUDDERS's Avatar
Oddometer: 6
Engine management Light
Hi all looking for some info.
Went to the 2011 XT1200 yesterday morning and the battery was dead no ignition lights at all. It is plugged into an optimate when its parked up too. ( the parking lights had not been left on)
Got the bike out and jump started it from one of my mates bikes. The bike started but the battery was so flat that as soon as you took the jump cables of it died on tick over. We left the cables connected to see if we could get enough in the battery to set of and noticed the the Oxford heated grips were getting warm even though they were switched off. (so looks like i have a fault on them).
Put the bike back in the garage plugged it back into the Optimate. Went to the bike today it has full battery and started no problem.
The question is when the bike started the engine management light was on.
Any ideas why? Can it be reset by me or does it have to to Yamaha?
Thanks for any help Simon
HAVE FUN
HUDDERS is offline   Reply With Quote
Old 06-03-2012, 06:40 AM   #12397
Bundu
Bundu's Avatar
Oddometer: 675
I've disconnected my battery a couple of times and if I remember correctly, any warning lights reset themselves after a ride - never had to go to dealer
On the cause: I think your grips are probably wired incorrectly as well, as they should be OFF if the ignition is OFF - I would also think your battery has now taken quite a pounding and is bound not to last very much longer - just my guess....
Bundu screwed with this post 06-03-2012 at 06:47 AM
Bundu is offline   Reply With Quote
Old 06-03-2012, 07:39 AM   #12398
HUDDERS
Have Fun :-)
HUDDERS's Avatar
Oddometer: 6
Cheers Ill take it for a run and try that.
The grips were fitted at the dealers, thought they would of wired them trough the ignition (never used them yet) The main thing was that they were not swithed on at the controler but were still hot with the bike running. I have dissconected them for the moment.
HAVE FUN
Old 06-03-2012, 12:48 PM   #12399
Specterx
Specterx's Avatar
Oddometer: 62
unfortunately I dont know of any other tenere owners in my area.
If someone wanted to compared dB levels they could do that. I put the dB meter 50cm away from the muffler at a 45 degree angle (that is how akrapovic measures)... then mounted the mic 24" above the ground. I used A weighted setting on the meter. so anyone with a meter can check their bike at idle and 3000 RPM and compare.
Originally Posted by avc8130 View Post
AWESOME video!
ac
Specterx is offline   Reply With Quote
Old 06-03-2012, 01:00 PM   #12400
Specterx
Specterx's Avatar
Oddometer: 62
can someone help me out here?
How do you embed a youtube video in a message?
Old 06-03-2012, 01:50 PM   #12401
markjenn
Oddometer: 10,442
Absolutely nothing wrong with doing these things, but I'd judge that doing this every tire change would cross over into the area of "excessive maintenance." Yamaha specs absolutely no maintenance whatsoever in this area for the life of the motorcycle and like you say, I've never heard of any failures.
- Mark
Old 06-03-2012, 07:59 PM   #12402
RidingUpAndDown
RidingUpAndDown's Avatar
Oddometer: 103
Learn How to Embed a Video Clip Here
http://advrider.com/forums/showthread.php?t=385793
hth, d
Sometimes, you find yourself in the middle of nowhere and sometimes...in the middle of nowhere you find yourself. -author unknown
RidingUpAndDown is offline   Reply With Quote
Old 06-03-2012, 08:38 PM   #12403
Specterx
Specterx's Avatar
Oddometer: 62
Yahoo it worked... thanks for the info on how to post videos.
Here is a video of HWY 123 in Arkansas
Old 06-04-2012, 04:29 AM   #12404
mrpete64
Oddometer: 589
overall ride quality?
Hello,
I am curious how you would rate the overall ride quality on the highway with this bike. I do a lot of cross country riding and would appreciate some of your insight(s). I know it is not a Goldwing or BMW GT.
thanks!
Mr. Pete---->
aging hippie
mrpete64 is offline   Reply With Quote
Old 06-04-2012, 04:39 AM   #12405
DinX
DinX's Avatar
Oddometer: 201
I do 600km highway per week, very pleased with it (rode an FJR before).
DinX is offline   Reply With Quote
Times are GMT -7.   It's 08:47 PM.
