Old 07-23-2012, 02:44 PM   #13111
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,900
Thumb 303...
Originally Posted by freeflow View Post
why Kriega would make an outdoor product that is not UV stable is beyond me....
this is good stuff I use on my boat....
Big +1 on the 303!
IMHO nothing works better on vinyl, colored plastic, etc. than the 303. They make a bunch of great products, and their "Fabric Protectant" is second to none, too.
http://303products.com/index.php/303...uard-16oz.html
If you're not familiar with their various products their site is worth a look - http://303products.com/
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 07-23-2012, 03:00 PM   #13112
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,624
Originally Posted by jaumev View Post
More answers to your questions:
http://www.advrider.com/forums/showp...3&postcount=68
The right is the clutch switch
You have a switch for when you want sun or rain???? I am impressed.
pluric is online now   Reply With Quote
Old 07-23-2012, 03:21 PM   #13113
Mikef5000
Oddometer: 2,030
On an unrelated note...
I just put 248 miles (400 km) on a tank of gas! It wasn't easy cruising either; 60 miles of 80+ on the highway, followed by 60 miles of spirited backroad blasting, finishing with another 120 miles 2-up, all in Sport mode. It took 5.3 gallons at the pump, which means at a minimum, I would've made it to 260 (at 5.6 gallons), with a theoretical maximum of 280. It probably didn't help anything that my back tire was at 10 PSI .
I'm now completely confident, if I wanted to, I could pass the 300 mile mark. I might have to take a day and do a back road loop just to prove it.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 07-23-2012, 03:55 PM   #13114
jaumev
jaumev's Avatar
Oddometer: 1,487
Yes, the rain is gravity inversed but it works great opening and closing the umbrella
jaumev is offline   Reply With Quote
Old 07-23-2012, 03:58 PM   #13115
GSDonovan
There and back again
GSDonovan's Avatar
Oddometer: 860
Perfect, thanks!
GSDonovan is offline   Reply With Quote
Old 07-23-2012, 06:28 PM   #13116
Desert Dave
Enjoying the moment
Desert Dave's Avatar
Oddometer: 2,735
Originally Posted by tomatocity View Post
Talk is cheap. I want to see some photos.
You'll get your photos, but after this weekend. Can't do to much off road though, the bike just looks fragile now with the stock plastic thingee down there....
I've got to say Yamaha priced the new cover a lot cheaper than I would have expected, and at least ONE part of my bike looks brand new again
See what I've been up to! Ongoing Ride Report
Desert Dave is offline   Reply With Quote
Old 07-23-2012, 09:11 PM   #13117
RockyDS
Wizened adventurer
RockyDS's Avatar
Oddometer: 289
Originally Posted by sscol View Post
Remember, if you ride it like a dirt bike you better be prepared to maintain it like a dirt bike.
Maybe so, but it is an issue with USD forks and although dirt bike fork seals are not warranted the seals are a better design and dirt bikes usually have OEM fork guards, which is not the case with the S10. I have had new fork seals on my S10 but my KLR went places off road my S10 has never been and with standard forks and fork gaiters there was no issue. In fact my S10 hasn't been off the highway, but that includes gnarly gravel highways.
Maybe the performance gains from reducing unsprung weight are not that important on a DS bike? If the bike needs gaiters for the designed purpose maybe Yamaha should have fitted then as standard.
Super Ténéré
RockyDS is offline   Reply With Quote
Old 07-23-2012, 10:19 PM   #13118
Dallara
Dallara's Avatar
Oddometer: 1,900
Fork gaiters...
Full fork boots don't work very well on "upside-down" forks... And they really won't work on the Super Tenere. No way they could survive so close to the brake discs and calipers, especially when they heat up under some heavy braking.
And let's not forget that a fork seal weeping very lightly (and I do mean very, very *LIGHTLY*) is not always an all bad thing in some cases. Hell, Husqvarna's back in the late '60's and all through the '70's came with leaky seals... Because Husky thought it made for smoother fork action with less stiction. OTOH, a leaky seal is a much touchier situation in this instance because you honestly don't want *ANY* fork oil on your front discs.
I've ridden my S-10 both on- and off-road for nearly 20,000 miles, and I've never had a fork seal issue. Please note, too, that I am a *BIG* boy weight-wise, and I don't ride gently (I carried an AMA Pro MX license & number for a few years), so I think I hit hard enough to have seal issues... But that said, I think I know why I don't.
I've mentioned this before, but I think it may help to post it here again.
Most of the time when you have a leaking fork seal it's *NOT* "blown" and needing replacement. Probably 85 - 90% of the time you simply have some grit underneath the seal lip, and it is that piece of dirt raising the lip of the seal that allows oil to seep by and make it appear you have "blown" a seal. The trick is to get that little piece of grit out of the seal. "Back in the day" we used anything and everything from 35mm film negative strips to business cards to slip up under the seal and try to flick the grit out. But today there's something much, much better... The "Seal Mate"
http://sealmate.net/
Watch the video there. It's worth your time. These little devils *WORK*! And with their cool little curved edge combined with the super-strong, super-thin material they easily get under the seal without damaging it. You absolutely won't believe what you will clean out from underneath your seal lips from time to time. I keep one of these on each of my bikes and one in the shop toolbox, too. If I see any sign of a seal weeping I pull the "Seal Mate" out and clean the seal. The "Seal Mate" is a relatively new tool, but using the old methods (film, clear acetate, etc.) I haven't had to replace a fork seal in *YEARS*... And that includes our 3 "Time Tunnel Racing" AHRMA vintage CZ MX'ers.
You might want to try some regular cleaning of your fork seals and it might help you avoid replacement, warranty or otherwise.
Just my two centavos... YMMV.
Dallara
p.s. I am not affiliated with Motion Pro, R&J Engineering, or Seal Mate in any way. Just a satisfied customer.
Dallara screwed with this post 07-23-2012 at 11:45 PM
Old 07-23-2012, 11:29 PM   #13119
jaumev
jaumev's Avatar
Oddometer: 1,487
Looks great! simple and clever.
Thanks Dallara
jaumev screwed with this post 07-24-2012 at 01:26 AM
Old 07-24-2012, 02:34 AM   #13120
SuperCruise
SuperCruise's Avatar
Oddometer: 329
Thanks Dallara
+1
XT1200Z Super Ténéré 2010
Around Australia, Super Tenere Style
SuperCruise is offline   Reply With Quote
Old 07-24-2012, 04:15 AM   #13121
Flydream
King of the Atlantic
Flydream's Avatar
Oddometer: 378
+1 thanks
Flydream is offline   Reply With Quote
Old 07-24-2012, 07:39 AM   #13122
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,918
Fork Seals!
The S10 forks are quite exposed to the elements. Do yourself a favour and instal something like Fork Skins or Seal Savers. Cheap and they work. Get a new pair every year and I doubt you'll ever have a problem with leaky forks.
RED CAT is offline   Reply With Quote
Old 07-24-2012, 11:01 AM   #13123
Goldie05
Fast George
Goldie05's Avatar
Oddometer: 633
Thanks Dallara :)
Mine are no longer leaking after the cleaning we did. I'm going to look into the link you have once I'm home and buy whatever you recommend
My question is, how do I know or how can I find out how much oil it leaked? Should I send it to the dealer?
I don't think it was a lot but... :
Sent from my amazing Samsung SII :-)
12 Yamaha Super Ténéré
Alaska Trip
Cross Country Trip
Riding USA Blog
GeorgeFPhotography
Goldie05 is offline   Reply With Quote
Old 07-24-2012, 11:11 AM   #13124
Mikef5000
Oddometer: 2,030
Unless it's leaving puddles when you park, it's not leaking enough to make a difference.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Old 07-24-2012, 11:35 AM   #13125
Dallara
Dallara's Avatar
Oddometer: 1,900
Oil Loss...
Thanks Dallara :)
Just like Mikef5000 said, unless you literally see puddles under the forks, and/or your front brakes are no longer working, then I doubt you've lost enough to worry about. Maybe you dropped your oil level in the forks a millimeter or two... Doubtful it's more than that.
You know how oil is... five drops on your garage floor looks like a puddle the next day. What usually gets past fork seals is more of a *mist* or *fog* of oil. That coats the slider tubes, and lots of dust and dirt adheres to the oil film, then the action of the forks squeegees this down, making it all look way worse than it usually is.
I really do keep one of the "Seal Mate" cleaners under the seat of my S-10, and usually pull it out and give the seals a swipe after every good washing I give the bike. You'd be surprised at what comes out sometime, and my seals have never leaked.
One more thing to note about fork seals... If they do start leaking very badly it's *NOT* because they're *blown*, as in lost their tension, etc. At least not 95-99% of the time... It's because a piece of dirt or grit has actually *torn* one of the lip surfaces of the seal. Once that lip is torn then usually the tear just gets worse and worse, causing more leakage Once that tear reaches a certain point on the seal then the seal loses its structural integrity and sort of *rolls away* from it's dual duties of wiping the slider clean and keeping the oil in. Once it stops wiping the fork tube then more dirt gets in, resulting in more tears, etc., and the problem becomes a cascade. Finally all seal integrity is lost and oil really dumps out.
Stop the dirt from tearing the seal and you've helped alleviate the problem.
It's also important to remember that there is more than one *part* of the seal. On an "upside-down", starting from the bottom, you'll have a dust wiper. This is there mainly to knock large particles off the fork tube. Truly small particles get right past this. Next is the actual seal assembly itself, which also has a primary *wiper* face, and is often surrounded by a small diameter spring (the S-10 has one of these springs on it's outer dust wiper, as well). This spring is to help hold sufficient tension on this seal wiper so it can scrape even smaller bits of dirt and grit away from the tube and keep them from the inner lips of the seal itself. It is these inner seal lips, that are behind the female tubes dust wiper and the fork seals own primary wiper, that actually seal the oil in the fork. The trick is to keep dirt and grit from getting to those inner lips, and that's where film cleaners like the "Seal Mate" come in. They let you get under the wiper section and remove dirt that is building up behind it, and starting to tear at the inner seal lips themselves.
And BTW... A lot of the neoprene *booties* some are using, like "Seal-Savers" and the "Kriega" ones, do no more than just trap a lot of dirt and grit behind them and IMHO do more damage than good. Remember, you're not trying to stop the dirt and grit you *CAN* see... The forks own primary dust wiper will do that if they are in good shape. Get into some muddy water, and the dirt and grit suspended in that will easily get past that neoprene booty. And then it sits there, trapped between the booty and the dust wiper and seal wiper, doing its damage where you can't see it to clean it off. Add to that the fact that these neoprene booties can hold dirt in their surface that rides up and down on the fork tube and what you have is something that is continually gouging and scratching your very, very expensive chrome-plated fork tubes...
Hope this helps!
Dallara
Dallara screwed with this post 07-24-2012 at 07:26 PM
Times are GMT -7.   It's 02:54 PM.
