Old 08-18-2012, 03:48 PM   #13291
markjenn
Oddometer: 9,698
Originally Posted by CafeRacer99 View Post
I figured out where to put the tool tube.
I've looked at this location, but the mounting is trick; while there appears to be sufficient space between the pannier and tire to fit the tube, it results in an odd alignment that is not parallel with the subframe member you want to bolt the tube to. (The subframe member angles back towards the centerline of the tire as you go aft.) If you have figured out a way to do mounts that are stable/robust and will keep the tube in the proper orientation away from the tire, I'd like to see the details.
You don't want to be cavalier about this because if the tube were to wedge between the tire and subframe, it would probably cause damage or even lock the tire. And it might be one of those things where you go 1000 miles without problem and then take a big whoop which uses the entire suspension travel and then it happens.
- Mark
Old 08-18-2012, 06:12 PM   #13292
Neonguy95
Self Sponsored Rider
Oddometer: 271
Used Plasti-Dip to spray the top and side cases. I think it looks much better. If you don't like it you can peel it off.
2010 WR250R
2010 XT250 (Wifes)
2012 Super Tenere (Black)((The fast one))
Neonguy95 is offline   Reply With Quote
Old 08-18-2012, 06:23 PM   #13293
CafeRacer99
Oddometer: 282
- Mark
This shot doesn't show it very well, but the tube is well out of the line of travel of the tire.
And it's held solidly. I spent some time trying to push it under the seat and it won't go. I'll be keeping an eye on it to see if vibration over time makes it move.
Ride to Coffee
Coffee to Ride
CafeRacer99 screwed with this post 08-18-2012 at 06:37 PM
CafeRacer99 is online now   Reply With Quote
Old 08-19-2012, 12:19 AM   #13294
tomatocity
Retired and lovin' it
tomatocity's Avatar
Oddometer: 626
Thanks for the additional photos. My only concern for you are the stainless steel hose clamps and the tight bends. I have a KLR with the standard tool tube on the front of the engine guard. Had the SS clamps break twice. After that I used heavy duty zip ties that don't break and are reusable.
I have an additional tube that I am going to mount where you did. Hope it works since it is out of the way. Thanks.
Tim
2012 Yamaha Super Tenere #027, 2005 KLR, 1993 Chevrolet S10,
tomatocity is offline   Reply With Quote
Old 08-19-2012, 08:34 AM   #13295
CafeRacer99
Oddometer: 282
It might be worth putting a couple of zip ties around the tube for backup, I might do that. It's hard to see, but I have some lacing wire at each end as backup already.
Ride to Coffee
Coffee to Ride
Old 08-19-2012, 08:48 AM   #13296
Bundu
Bundu's Avatar
Oddometer: 451
looks GREAT! let us know how the stuff lasts and how easy it is to 'patch' scratches?
Bundu is offline   Reply With Quote
Old 08-19-2012, 09:15 AM   #13297
jaumev
jaumev's Avatar
Oddometer: 917
I dindn`t know this product. Looks great!
Let us know how resistent it is
jaumev is offline   Reply With Quote
Old 08-19-2012, 10:47 AM   #13298
Goldie05
Fast George
Goldie05's Avatar
Oddometer: 553
I looked at that position but I don't think the tire is the whole problem.
I was concerned about the caliper and the bracket hitting the tube, I wasn't comfortable. Too close, in a big suspension compression moment things could go wrong very fast.
I mounted mine on the left side above my rack. Im using my phone now, can't post a picture but search for a posting from me, there's a picture somewhere already.
Sent from my amazing Galaxy SII
12 Yamaha Super Ténéré
Alaska Trip
Cross Country Trip
Riding USA Blog
GeorgeFPhotography
Goldie05 is online now   Reply With Quote
Old 08-19-2012, 12:21 PM   #13299
Gryphon12
Gryphon12's Avatar
Oddometer: 689
Isn't the full rear suspension travel 7.5"? The bottom edge of that tube looks more like 9" from the caliper. I see your concern from an alignment perspective, but not from a real-world travel distance, unless I'm out to lunch on the actual distance. Care to measure it?
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 08-19-2012, 02:08 PM   #13300
CafeRacer99
Oddometer: 282
No problem!
9 inches, good guess.
I also measured the distance from the final drive to the muffler. Also 9 inches to where it looks like it would hit first.
I also compressed the shock as much as I could with my body weight and then ratcheted down as much as I could and this is as far as I got. The bottom end of the tube stands out from the caliper support arm enough that it won't hit.
Not very scientific, but I think I've got the clearance. All I'm concerned about is the tube rotating down from vibration over time. It's solid, so it's not going to just fall unless something breaks.
The test will be Labor Day weekend in Colorado, Ophir and Engineer passes.
Ride to Coffee
Coffee to Ride
Old 08-19-2012, 05:56 PM   #13301
tomatocity
tomatocity's Avatar
Oddometer: 626
I think it will work unless an extreme situation occurs.
How close is the tire to the tube when the suspension is fully compressed?
What if you were in a very muddy location and your suspension was completed compressed? This might happen but I doubt it.
Tim
Old 08-19-2012, 06:12 PM   #13302
Goldie05
Fast George
Goldie05's Avatar
Oddometer: 553
No problem!
Nice work measuring, I was afraid and just didn't use that location.
This is where I ended up mounting mine, looks good, it's easy to get to, doesn't affect the pannier, the lid on the pannier opens with about .5 inch clearance
It's mounted to the rack with strong zip ties
Alaska Trip
Cross Country Trip
Riding USA Blog
GeorgeFPhotography
Old 08-19-2012, 07:46 PM   #13303
CafeRacer99
Oddometer: 282
I'd say the tube is in the same relative location as the muffler in relation to the tire. Even under full compression, I can't see it hitting the tire.
I'll make sure to check in on this after a few rides.
Ride to Coffee
Coffee to Ride
Old 08-19-2012, 07:53 PM   #13304
CafeRacer99
Oddometer: 282
That's nice. I think your panniers are lower than mine. I don't have room there.
Ride to Coffee
Coffee to Ride
Old 08-20-2012, 01:08 PM   #13305
bacon
KZ5TLP
bacon's Avatar
Oddometer: 616
Hey guy's I'm back.
After having to give up the Adventure riding due to major back problems and a bout with lung cancer.
I had to stick to the roads for a while.
The lung is gone the back is better now and back in the saddle.
Picking up my bike this week.
I am on the yanahasupertenere forum also as " bacon "
"Be still, and know that I am God"
For all that motorcycling is, one of it's greatest gifts is the ability to take us to places where that quote is the first things that came to my mind.
bacon is offline   Reply With Quote
Times are GMT -7.   It's 09:55 AM.
