Old 10-19-2012, 02:41 AM   #13966
Paulvt1
Paulvt1's Avatar
Oddometer: 3,596
Well folks - it's been a fun 18 months with the Ten, but the time has come to move on. I scored a deal on a brand new MTS 12 and just couldn't say no.
Off to the red side...
Paulvt1 is online now   Reply With Quote
Old 10-19-2012, 03:22 AM   #13967
MDMcDuff
Oddometer: 4
As a long time duc owner, currently still have 2 albeiht '94 vintage and have had 5 others pass through my hands, You'll be back :p.
MDMcDuff is offline   Reply With Quote
Old 10-19-2012, 03:42 AM   #13968
Tim
Tim's Avatar
Oddometer: 2,364
Fitted the Yamaha carbon exhaust shield (if I spent all that cash on an exhaust I have to show it off!) and Yamaha LED indicators (flashers). I must say that although the Yamaha indicators seem to be good quality and came with resistors to get the flash speed right, I was a little disappointed to find that the wires weren't long enough and that I needed to extend the rear ones to reach the connectors under the seat. If Yamaha are going to sell these as a universal fitment for all of their bikes I would have thought they could measure which of their bikes needs the most wire and supply that amount.
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 10-19-2012, 03:54 AM   #13969
jaumev
jaumev's Avatar
Oddometer: 1,511
Nice!!
jaumev is offline   Reply With Quote
Old 10-19-2012, 04:41 AM   #13970
TH
There and Here
TH's Avatar
Oddometer: 912
Originally Posted by jaumev View Post
Nice!!
Agreed!
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 10-19-2012, 05:48 AM   #13971
jub jub
frumiousbandersnatch
jub jub's Avatar
Oddometer: 15,982
Originally Posted by WARRIORPRINCEJJ View Post
Actually, Jubby, I don't think it's something they're gonna' be able to "address"; not completely, at least.
At this point in time, all over the world, the emissions standards seem to be getting higher, and harder to reach.
On bikes with a ride-by-wire system (like the ST), the movement of your throttle hand is monitored several times per second. The human hand is not consistent enough to maintain the emissions standards at low RPMs. So, the ride by wire does the work for us; allowing these big bikes to "make the grade", so-to-speak.
What your hand is doing, and what the ride-by-wire system is communicating to the bike, are two different things. That is what gives the on/off, "light switch" feeling to the throttle.
Is there a chance that Yamaha overdid it, and can smooth it out a bit? Sure. But, as far as completely ridding the bike of it, a non-OEM (aftermarket) reflash is probably the answer (in my humble opinion). If Yamaha does smooth it out a bit, at the factory level, it would be nice for them to offer a reflash to the current owners.
Many (magazine columnists, writers, owners, test riders, etc.) have complained of this issue. Is Yamaha listening? Well, they were the only Japanese manufacturer to have the sack to build this bike in the first place...
Thanks for the detailed explanation! I was expecting a yes or no! It must not be that big of a deal though, I noticed that Cycle World has a long term Tenere that they've been testing and you actually have to schedule your time on the bike. In other words, it's very popular with the staff.
I was just drooling over the pictures of the white one ^ up there. That bike looks to purdy to get dirty!
jub jub is offline   Reply With Quote
Old 10-19-2012, 06:02 AM   #13972
jaumev
jaumev's Avatar
Oddometer: 1,511
Last week I went to Mambatec (BM suspension distributor) to check the BM shock and fork. As a prototype for the Super Ténéré they wanted to check them are after the hard off road use I did. They have now almost 7000km but everything was ok. I'm very happy with these suspensions and this people professionalism.
Their suspensions are custom made. Before an order, the customer has to fill out a questionnaire about the type of riding, the weight is usually carried, etc. They make my rear shock with the possibility to rise the height up to 30mm so I can change the bike geometry, improve the ground clearance or levelled the bike if I mount a 21” front wheel.
They also care to detail, they have designed a specific supports for the Super Ténéré which are perfectly integrated into the bike. I've never liked to see this high quality (and expensive) shock absorbers attached to the bike with simple steel clamps.
Since I have these suspensions the bike has changed completely, despite the weight of the bike, in jumps is almost impossible to reach the end, there are endless adjustments (high, low, compression…) and the performance in all areas is superior to everything I've tried so far. I also noticed a lot of improvement with the front springs and fork oil, much progressive that the standard.
So, highly recommended, if you want more info: http://www.mambatec.com/
This is the knob to tighten the spring if you carry passenger, luggage ....
And here is the bottle to regulate high and low. Normally that is fixed with clamps but Mambatec designed a support attached to the passenger footpegs
Old 10-19-2012, 10:05 AM   #13973
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,886
I can't remember; what was the final verdict? Are the Worldcrosser pieces available separately? And, are they available in the States?
That carbon exhaust shield is pure sex...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 10-19-2012, 12:14 PM   #13974
NHADV
NHADV's Avatar
Oddometer: 554
That Tenere is sweet! Nicely done. I have been looking at these a lot lately.
-Gary
NHADV is offline   Reply With Quote
Old 10-19-2012, 01:42 PM   #13975
bross
Where we riding to?
bross's Avatar
Oddometer: 4,626
Originally Posted by bouldertag View Post
For those who are married to a non motorcycle luvn wife, how were you able to justify a 14k Tenere?
Give me the secret and I will be a tenere owner.
bd
Sorry, I'm not in your category. My wife loves to ride and buys more bikes than I do. She's usually saying something like "You need a new bike, haven't you had that one long enough!" or her latest taunt "When are you going to sell that POS Honda and buy a REAL bike." meaning a Triumph. So of course I had to go buy a Tiger to keep her quiet. Just got back from a 2000 mile ride on her Street Triple and she's decided she wants more protection so now she's shopping for a sport tourer.
Originally Posted by markjenn View Post
Financially, the solution is easier - for every dollar I spend on bikes she gets to spend the same amount on something that gives her indivdual satisfaction - she likes furniture. If $28K can't be swung, then you need to buy a $7K bike.
- Mark
I like Mark's advice and can't see how you could go wrong.
Old 10-19-2012, 06:18 PM   #13976
GrahamD
GrahamD's Avatar
Oddometer: 5,399
- Mark
Go give your SO a big kiss for me. In my world it's more like $8:1
I still got the bike though. Grit and determination I say. That's all you need.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 10-19-2012, 06:19 PM   #13977
GrahamD
GrahamD's Avatar
Oddometer: 5,399
Eeeeh Gads man. You're English. What happened to the Tiger.
Old 10-19-2012, 06:48 PM   #13978
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,236
Yee haw I'm baaaaaaaacckkk!
....and so is my bike. Woody's wonder wheel installed, new K60s and a new touring
screen as a bonus farkel. I've missed you all as I was forced to lurk
Many thanks for not throwing me under the bus while I was unarmed and unable to respond.
pluric is offline   Reply With Quote
Old 10-19-2012, 07:03 PM   #13979
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,866
Perhaps, but if there is one thing I've learned in a 43-year-long motorcycling career is that there is little or no correlation between the amount you spend on a bike and the enjoyment you get out of it. The folks that ride 20-yo bikes that cost them $3K and they sell after five years for $2700 seem to have just as much fun as the folks buying the latest/greatest $20K sportbike or Harley every year.
Agree about the thread hijack, I'll shut up.
- Mark
Mark, your post describes my position pretty accurately. My current street ride is a '93 Suzuki GSX1100G that I bought, just to have something to ride, after selling my 950SE of 5 years. I like it a lot more than I expected to. Bang for the buck factor is off the charts. Maybe the best street engine I've ever experienced, and I don't particularly like I-4's.
After demoing a Super Tenere, I got back on my G to ride home, and within 10 minutes had decided that there is no way the S10 is $12,000 better than the old 'Zook.
But, I'm still here, keeping track of you guys. The S10 is on a very short list of bikes that interest me at all, and the tipping point will probably be brought on by yet another session of cleaning crap-fuel-induced gunk out of the carbs.
Apologies for re-starting the hijack.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 10-19-2012, 07:09 PM   #13980
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,236
These next posts may get me banned again for being
NSFW.
(That's really Not Safe For Wallet, not Work)
I've been very busy with the time off ADV gave me. Quick update.
Took the kids to Disneyland,
Drove 9 hours round trip to get the grandkid something to kick the cousins
Power Wheel asses with.
I had bought her a RZR 170 that is still a little big for her so I did what the
internet told me to do and upgraded all the shocks and added a receiver hitch
so she can tow her dolls in the trailer. I take the job of a spoiling grandparent
very serious. Plus it's fun.
Times are GMT -7.   It's 08:38 AM.
