Old 11-21-2012, 01:13 PM   #14416
jaumev
jaumev's Avatar
Oddometer: 1,487
Originally Posted by Thagua View Post
Hola Jaumev ... I have done the upgrade to 21" on the front modifying the front fender and making the suspension more stiff on the last inches before bottoming with the Wilbers progressive springs.
Saludos,
Roberto
PS.- Remember that I am one step ahead of all innovations
Hola Roberto!
I know! You and Wasp where my inspiration to the conversion! Many thanks to be the first to show us the way.
My BM springs are harder than the OEM so I hope they help to no to arrive to the end of the fork travel.
I remember all your innovations.... also the ones I never must do (the trailer)
Cheers!
jaumev is offline   Reply With Quote
Old 11-21-2012, 01:31 PM   #14417
jaumev
jaumev's Avatar
Oddometer: 1,487
Originally Posted by Dallara View Post
No problem, Jaumev.
Happy to be of any assitance... Especially to someone like you who has contributed so many fine ride videos and pictures of the Super Ténére´out there off-road.
That was my contribution to keep pete quiet
One note... I just went out and checked my fork travel indicators (small cable tie around each fork tube) on my own Super Ténéré, and my forks hit full travel with an indicated 25mm from axle carrier casting to the dust cap slider limit at the upper edge of the cable tie. That's in actual riding. Though I haven't ridden in any off-road sections as technical and extrem as you have, I do ride fairly hard and have bottomed my forks regularly (as should be the case).
Note this is traveling more than the 34mm you seem to be getting in your pics.
Just for the record, my bike has the full Stoltec mods (stiffer, custom-wound, heavy spring wire front springs, Penske valving, etc.) to the forks, and as such might actually have slightly more usable travel than stock since Nick at Stoltec says the springs he uses have a much more *open* wind to avoid coil-bind so early. With his mods the forks are much smoother in operation as well as more compliant than stock, yet with much more control and precision... None of the indistinct "hobby-horsing" (excessive fore-and-aft pitching) that the stock set-up exhibited. They also smoothly bottom out, with none of the harsh "slamming into a hydraulic-lock stop" feeling of the stocker.
That said, again my fork travel is nearly a half-inch more than your "test bench" travel so you might want to go take another look.
Just FYI...
Dallara
Probably I can go a little further than the 34mm but I was afraid the straps broke, I did lot of power…. I don’t know if my springs can be the reason to that difference.
Anyway, the bike is finished and Saturday is going to be the great day… I’m really anxious to try it, it looks sooooo god!
Many thanks again!
Old 11-21-2012, 02:05 PM   #14418
GrahamD
GrahamD's Avatar
Oddometer: 5,289
Originally Posted by jaumev View Post
I though I've sent to you a PM days ago.
It is in the flea market forum:
http://advrider.com/forums/showthread.php?t=834493
PM sent. Sold.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 11-21-2012, 02:45 PM   #14419
jaumev
jaumev's Avatar
Oddometer: 1,487
Originally Posted by GrahamD View Post
PM sent. Sold.
Received!!
Old 11-21-2012, 02:56 PM   #14420
wolftrax
wolftrax's Avatar
Oddometer: 411
Many thanks again!
Lookin good, your going to love the 21"er!!!
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 11-21-2012, 04:22 PM   #14421
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 354
Protect your forks
Hola Javier ... Protect your forks ... for the lower use those sponge type covers (Acerbis) and for the upper, italian manufacturer Pro Grip makes a slip on carbon protection.
Saludos,
Roberto
'Let's go adventuring'
Thagua is offline   Reply With Quote
Old 11-21-2012, 04:48 PM   #14422
GrahamD
GrahamD's Avatar
Oddometer: 5,289
"can I put more than 5Kg on the back of the Tenere? Will it break? Can it take it?"
From Barrel over at YST.
Old 11-22-2012, 01:47 AM   #14423
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,411
Of course it can. As I understand it you can also do motocross with it on too. Gonna be messy when you fall off though.
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 11-22-2012, 04:27 AM   #14424
BSTARD
Mmmmm...shiny
BSTARD's Avatar
Oddometer: 279
I’m still messing about the 21” front wheel.
Next week I’m going to be with ACD to see if they could modify the skid plate, I’m worried it could be difficult… Everything is so tucked in!!
I fixed the Touratech skid plate and if I compressed the fork using all but the last 34mm the tire touch the plate. Less than 34 It could hit the front pipes but I don't know if its possible to use all the fork travel.
Looks like you're almost there dude, just one thing left to get....it even has twin pipes ;)
Better to beg for forgiveness than plead for permission.
BSTARD is offline   Reply With Quote
Old 11-22-2012, 05:06 AM   #14425
GrahamD
GrahamD's Avatar
Oddometer: 5,289
Lessons
Pluric, you need some lessons from this guy...
Old 11-22-2012, 05:08 AM   #14426
GrahamD
GrahamD's Avatar
Oddometer: 5,289
Originally Posted by BSTARD View Post
Bad idea.
Those things are always loosing front wheels.
Old 11-22-2012, 07:16 AM   #14427
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,580
I'd rather..........
pluric is online now   Reply With Quote
Old 11-22-2012, 08:31 AM   #14428
Rick West
Function not Farkles
Oddometer: 1,222
Dallara, we need to hear from you on this
KTM 990 - The only real "dual" sport in the big Adventure bike class
Rick West is offline   Reply With Quote
Old 11-22-2012, 08:34 AM   #14429
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,890
Laugh Looks normal to me...
Looks like your bike, out by the mailbox, Rick... In pieces again!
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 11-22-2012, 12:30 PM   #14430
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,580
Dallara
It's back, yes it looks good, it's going, going..... IT'S OVER THE FENCE!!!
Knocked that one out of the park.
Times are GMT -7.   It's 12:00 PM.
