Old 11-26-2012, 10:33 AM   #14461
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,930
Originally Posted by GB View Post
I
Pluric: For the places you take your bike, a dry clutch like on the GS wouldn't last you very long! Then you need to BringMoreWallet.
This was an all but new Altrider skid plate. I kept hearing the rocks that were thrown
up hitting it.
This side still got the exhaust pipe. I'm sure it would have been worse
without it. Looking under the plate I can see where it got pushed up to
the drain plug. Probably saving me from a night in the desert.
pluric is online now   Reply With Quote
Old 11-26-2012, 10:36 AM   #14462
simmons1
simmons1's Avatar
Oddometer: 1,526
Are you going for Jaxon's bomb proof plate next?
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is online now   Reply With Quote
Old 11-26-2012, 11:31 AM   #14463
jaumev
jaumev's Avatar
Oddometer: 1,501
Pluric, you need the 21"/18 wheels and harder suspensions to reach the bike. That's the best insurance against rocks.
I tested the 21" front wheel in the same place I did the skid plate some months ago (with the 19" wheel) and it was really difficult to hit the plate.... with my light weight
jaumev is offline   Reply With Quote
Old 11-26-2012, 11:39 AM   #14464
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,930
Originally Posted by jaumev View Post
Pluric, you need the 21"/18” wheels and harder suspensions to reach the bike. That's the best insurance against rocks.
I tested the 21" front wheel in the same place I did the skid plate some months ago (with the 19" wheel) and it was really difficult to hit the plate....with my light weight
I think I'd go orange before I started to convert the bike into something else.
Opps, was that my outside voice?
You just had to throw that last comment in didn't you.
Old 11-26-2012, 11:41 AM   #14465
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,930
His set up does look impressive. It's alloy, it will all bend eventually.
Old 11-26-2012, 12:20 PM   #14466
jaumev
jaumev's Avatar
Oddometer: 1,501
Well the new 1190 KTM R looks impressive... perhaps my next bike??
Opps another outside voice!!
To me the biggest problem the ST has is its low ground clearance:
Yamaha ST: 20,5 cm
BMW GSA: 23,5 cm
KTM 990: 26 cm
Now with the new setup I have nearly 24 cm, thats a big improvement.
What is the problem to be light??
Old 11-26-2012, 12:45 PM   #14467
simmons1
simmons1's Avatar
Oddometer: 1,526
It may be alloy, but it is really thick and mounted only to the frame. You would really have to blast something hard to bend or break it. For whimpy plates I have a few hundred miles on rocky but easy to ride fast roads and my SWM plate looks like it has been through a war already.
Old 11-26-2012, 01:05 PM   #14468
kantuckid
Oddometer: 3,080
2012 Yamaha Tenere lowering info please???
I'm 5' 8.5" with 28.5" inseam. Currently ride a BMW with 29.5" seat height- can I get a Yamaha down to my size via rear links,front tubes & seat changes ??? Or should I keep looking-BTW, I ride pavement only & thanks!!!
kantuckid is offline   Reply With Quote
Old 11-26-2012, 01:07 PM   #14469
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,930
Yeah, my first OEM plate was like that. The sump mount and lack of any pipe protecton
made me move on. Just trying to straighten the Altrider and get it off the pipe it bent pretty
easy. Maybe the bike is trying to tell me something?
Old 11-26-2012, 01:23 PM   #14470
William42
William42's Avatar
Oddometer: 2,831
Well pluric wouldn't know.
I would not say that his size has anything to do with bending rims and bashing bash plates.
He does seem to enjoy himself.
Mud is evil
William42 is offline   Reply With Quote
Old 11-26-2012, 02:55 PM   #14471
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,930
Yes I do enjoy myself. On the bike and at the dinner table.
Old 11-26-2012, 04:49 PM   #14472
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,637
You should ride one first, we're about the same size and height wasn't an issue for me. I'm not sure where the seat was set, but feet on the ground wasn't a problem.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Old 11-26-2012, 05:54 PM   #14473
Superstar
Superstar's Avatar
Oddometer: 491
I hate the way my radiator fan cooks my left leg at stoplights. It's Texas...it's almost December...I don't think the fan should cycle at stoplights in 76 degree weather.
How much worse will it be in July?
Superstar is offline   Reply With Quote
Old 11-26-2012, 06:53 PM   #14474
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,930
For pavement only you can get lower bikes that still have that nice twin power.
I quess I'm a little confused why you would consider the Tenere. It is a nice
slab runner just if you really are pure street I'd sniff around some more.
Old 11-26-2012, 07:23 PM   #14475
Mikef5000
Oddometer: 2,030
I'm exactly the same height/inseam. With the seat on low. I'm on the comfortably on the balls of both feet, or flat foot one and the toe of the other. It's not too tall at all, and I wouldn't even consider lowering it unless you require flat footing both feet.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Times are GMT -7.   It's 06:48 AM.
