Old 11-30-2012, 09:50 AM   #14566
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 2,077
Compressor...
Originally Posted by NicolasR View Post
I plugged my compressor and it immediately blew the fuse. It has a 3A fuse, what a shame!!!
I have a couple of questions for you:
Can I change the 3A fuse for a 10A fuse without harming the system??
Can i just connect the air compressor directly to the battery with two alligator clips?? Will this cause any problem to the battery or the system in general??
Ran into the same problem in the first month I had my S-10. Couldn't believe Yamaha used such a wimpy circuit for the power plug. Guess they just intended it for things like a GPS, radar detector, or charging a phone, etc. I thought about putting in a higher amp fuse, but after taking a long, hard look at the wiring to the plug receptacle I decided that might cause more problems than it solved...
And when my headlamp sub-harness melted I really knew a bigger fuse wasn't the way to go.
I use a BestRest CyclePump, and I simply hook mine directly to the battery using the big alligator clips. It's safe, foolproof, and not really any more time consuming given how easy the sidecover goes on and off. I carry a little 4mm allen wrench on my pocket keychain so I always have the tool handy to pull the sidecover. Makes using the compressor a quick and painless deal.
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 11-30-2012, 10:20 AM   #14567
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,441
Originally Posted by omroizo View Post
Thank Pluric. Here in Cyprus you must have pass any kind of English exams (GSE or TOEFEL) to say that i can speak English. The English that i know i have learn them mostly from TV and PC gaming.
Now for the oil filter relocation kit i think it a good mod because you can save time from removing the bash plate to have access to the oil filter. Does it need to be positioned again in horizontal or it doesn't matter if you install it in vertical position???
Τελικα εμεις οι Κυπραίοι ολο ιδεες ειμαστε.
Αναλογα με το τι θα κανεις, το δεκαεννιαρι ειναι μια χαρα.
Αν χρειαστεις βοηθεια σε οτιδηποτε με τα Αγγλικα πε μου.
Originally Posted by An Appalachian mudsquid
Why do we always hurt the ones we hit?
Cos is offline   Reply With Quote
Old 11-30-2012, 10:35 AM   #14568
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,496
It's all Greek to me.
pluric is online now   Reply With Quote
Old 11-30-2012, 11:57 AM   #14569
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,441
Διακοσια πεντε.
Old 11-30-2012, 11:59 AM   #14570
jaumev
jaumev's Avatar
Oddometer: 1,520
Yeah.. agree, you are absolutely right about Pluric.
jaumev is offline   Reply With Quote
Old 11-30-2012, 12:12 PM   #14571
cug
Oddometer: 5,031
Διακοσια πεντε.
CCV
cug is online now   Reply With Quote
Old 11-30-2012, 12:26 PM   #14572
jaumev
jaumev's Avatar
Oddometer: 1,520
Old 11-30-2012, 12:56 PM   #14573
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,496
Please tell him I'm flattered, but I do not ride a black Tenere. Let him down easy.
Old 11-30-2012, 02:51 PM   #14574
jaumev
jaumev's Avatar
Oddometer: 1,520
OK!
Old 11-30-2012, 07:32 PM   #14575
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,498
Originally Posted by Tim View Post
Anyone know if the Super Tenere comes prewired for the Yamaha auxiliary driving lights? I have a set of 530 leds I'd like to add, wondering if I need to use the Piaa wiring harness. Thanks...
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 11-30-2012, 07:44 PM   #14576
Dallara
Dallara's Avatar
Oddometer: 2,077
In a nutshell...
Yes, it does... Just as Yamaha already pre-wired it for their heated grip kit. Behind the right side cover (where the battery is) if you fish around in front of the battery at the upper forward corner, under all the various wire bundles, you'll find two unused plugs... One is for the lights, one for the grips.
But there is already a *TON* of information about both plugs here on ADVrider as well as on the Yamaha Super Tenere forum site. Just do some searches, or use Google and just use "ADVrider" or "Yamaha Super Tenere forum" in the search string line.
Remember, the "Search" is your friend...
Dallara
Old 11-30-2012, 08:59 PM   #14577
soaz
soaz's Avatar
Oddometer: 150
Talking
Best Tenere bags ever?
Almost a matching set. Both Sampsonite, but ones almost double the cost of the other. I think the moral is that Goodwill is a better adventure bike value than St Vincent De Paul.
soaztim.com
soaz is offline   Reply With Quote
Old 12-01-2012, 01:57 AM   #14578
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,476
Mobile Office ??
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 12-01-2012, 02:04 AM   #14579
Old Git Ray
Oddometer: 1,476
Now that is enough. I used to admire your bike, then I was envious, then jealous, now I am beginning to think of stealing your bike on my way back to the UK.
Old 12-01-2012, 04:26 AM   #14580
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,496
Wasp and Jaumev have turned theirs into a KTM. You sir have turned it into a KLR.
I guess all the comparison talk was true.
I think you also managed to single handedly turn a blue Tenere into chick repellent.
pluric screwed with this post 12-01-2012 at 04:32 AM
Times are GMT -7.   It's 12:14 PM.
