Old 12-05-2012, 08:19 AM   #14641
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,860
Originally Posted by pluric View Post
I tried to bring the headlights in a little. I don't know it just made the bike look stupid.
The true difference of the blue ones is starting to become evident.
Super Tenere & WR250R, AMA, IBA
Wreckchecker is offline   Reply With Quote
Old 12-05-2012, 04:28 PM   #14642
Mikef5000
Oddometer: 2,031
Originally Posted by Old Git Ray View Post
The good news is that Yamaha actually make a slightly shorter one for other bikes that fits exactly.
Part Number???
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 12-05-2012, 04:48 PM   #14643
jaumev
jaumev's Avatar
Oddometer: 1,511
The good news is that Yamaha actually make a slightly shorter one for other bikes that fits exactly. For my fist service, which I did myself, I asked the dealer for a normal one and he did not have one in stock. He gave me the slightly shorter one and said it would be fine.
I used it for the 10,000km between services and it was fine. It is also about 10mm shorter as you need. If you are worried about the flow then you could make the oil/filter changes earlier.
Yeap, we have this one but I want to be sure it about pressure ... The dealer is asking to Yamaha... but I am pretty sure about the answer...
I will apreciate if you give us the part number
jaumev is offline   Reply With Quote
Old 12-05-2012, 05:13 PM   #14644
raybies
raybies's Avatar
Oddometer: 137
Getting back to the clutch switch Mod.
My observations:
1.- Works with the Australian model.
2.- It disables S/T mappings.
3.- It disables in gear clutch safety, so if you're in 1st/2nd and you press the starter it may throw you off.
4.- It only seems to have an effect below 3k rpm.
5.- Pulling the clutch lever slightly without engaging the clutch does the same thing... so I guess they did to help wheelies .
Am I missing anything?
PS: I also if you want to preserve your sump it best to avoid going down stairs , you may even go over the handlebars if it gets stuck on a stair.
raybies is offline   Reply With Quote
Old 12-05-2012, 06:03 PM   #14645
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,263
Originally Posted by Geology Rocks View Post
So how have you guys routed the perminant leads for your battery tender? I am thinking thread through current wires and the wire tied to the frame rail just to the rear of the black plastic cover. I would use those two holes for zip ties to hold it on.
I ran a fused wire direct from the battery to a powerlet BMW style outlet.
I just plug the battery tender into it and also have a dedicated outlet to use
for other items. I put this in before the winglets. Cutting it close so move it
over a little more to the right if anyone else does this.
I use a BMW to SAE plug. Runs a compressor too.
pluric is offline   Reply With Quote
Old 12-05-2012, 06:36 PM   #14646
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,263
My observations:
I don't think it disables the S/T modes.
I wouldn't disagree on the stairs. Nice mess to clean up I would imagine.
Old 12-05-2012, 07:07 PM   #14647
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,997
Mine came from the dealer with it installed just that way.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 12-05-2012, 10:03 PM   #14648
GrahamD
GrahamD's Avatar
Oddometer: 5,400
Just how big were the stairs?
When you can snatch Tenere from jaws of death you are ready to leave Grasshopper.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD screwed with this post 12-05-2012 at 11:17 PM
GrahamD is offline   Reply With Quote
Old 12-05-2012, 11:04 PM   #14649
markjenn
Oddometer: 10,483
You mean going down stairs isn't easy like it looks on the Bourne movies? I'm shocked.
- Mark
Old 12-05-2012, 11:49 PM   #14650
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,466
I knew you were going to ask this. Doh!
I do not know the actual number, but as I recall, it was the same as the normal one with only the second to last digit being different. He showed me this to convince me of the similarity.
The ST1200Z one is 5GH-13440-20. That would make the one I used either 5GH-13440-10 or 5GH-13440-30. Have a chat with your dealer, it is likely he will have one with these numbers on and you could compare them.
I would go to my local dealer in Cartagena but my Spanish is not good enough to make him understand what I want.
I can however confirm that it fits and it lasted a full service term.
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray screwed with this post 12-06-2012 at 12:17 AM
Old Git Ray is offline   Reply With Quote
Old 12-06-2012, 01:45 AM   #14651
jaumev
jaumev's Avatar
Oddometer: 1,511
Ok, don't worry
I'll ask to my dealer
Many thanks!
Old 12-06-2012, 05:32 PM   #14652
raybies
raybies's Avatar
Oddometer: 137
It was just 3 freaking steps... I needed to park in a gated parking lot. So I decided to go in through the side walk/foot path down some stair.
I stood up, go down and bam!
2nd step hit the sump (silver bit) denting it in and cracking it.
Stopped me in my tracks, and I almost went over the handle bars.
If I hadn't been straight and need to put a foot down, I would have gone over. Seesawed if off, doing more damage.
Old 12-06-2012, 05:45 PM   #14653
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,469
I feel for ya man. Even my Dakar with 10" of travel isn't too happy going down steps, I pretty much limit that activity to my Djebel 250.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 12-07-2012, 12:03 AM   #14654
jaumev
jaumev's Avatar
Oddometer: 1,511
You need a 21" front wheel....
Old 12-07-2012, 05:40 AM   #14655
jaumev
jaumev's Avatar
Oddometer: 1,511
We find this one as a short one, could be this number?
5DM-13440-00
Times are GMT -7.   It's 09:25 AM.
