Old 12-07-2012, 05:57 AM   #14656
Mikef5000
Oddometer: 2,030
Originally Posted by raybies View Post
It was just 3 freaking steps..
Shoulda wheelied off the top step!
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 12-07-2012, 06:13 AM   #14657
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,395
Like this guy!
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 12-07-2012, 03:16 PM   #14658
GrahamD
GrahamD's Avatar
Oddometer: 5,319
Maybe a bit more damping on the rear shock would have helped.
Ummm.. Do they have a rear shock?
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 12-07-2012, 03:38 PM   #14659
Mikef5000
Oddometer: 2,030
Kinda what I thought. No amount of 'speed bump' should send you into a front flip. Something is either wrong with that bike, or wrong with that speed bump.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Old 12-07-2012, 03:50 PM   #14660
wolfmanluggage
wolfmanluggage's Avatar
Oddometer: 500
Oil Seep between swingarm and final drive
Hi Guys,
Has any one seen or had this happen/ a very slight seep of oil between the swingarm and final drive?
Next tire change I'm going to remove final drive and use yamabond to seal. It seems there is no gasket between swingarm and final drive.
Woof,
eric/ Wolfman
wolfmanluggage is online now   Reply With Quote
Old 12-07-2012, 03:57 PM   #14661
japako
japako's Avatar
Oddometer: 592
Looks like it was a large bump and he may have touched the front brake.
When the front wheel hit I saw some smoke and then the wheel went to a hard left creating a hard stoppie. Just my two cents.
japako is offline   Reply With Quote
Old 12-07-2012, 04:15 PM   #14662
Happy Snapper
GOMOB.
Happy Snapper's Avatar
Oddometer: 2,146
Harley Crash
My guess is no shock or stuffed shock on the back.. it seems the spring's rebound after compression is uncontrolled!
Happy Snapper
Never trust atoms.... they make up everything!
Read my Blog: http://snapshotsfrommark.blogspot.com.au
Happy Snapper is offline   Reply With Quote
Old 12-07-2012, 04:16 PM   #14663
japako
japako's Avatar
Oddometer: 592
Originally Posted by wolfmanluggage View Post
Hi Guys,
Woof,
eric/ Wolfman
There is an o ring to hold back any oil. What you are seeing is probably assembly grease that melted and ran down the shaft. I don't think you need to use Yama bound. jmho
Old 12-07-2012, 07:16 PM   #14664
wolfmanluggage
Oddometer: 500
Sounds Good
Thank you
Woof
e
Old 12-07-2012, 08:38 PM   #14665
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,974
Japako!
+1.
RED CAT is offline   Reply With Quote
Old 12-07-2012, 09:58 PM   #14666
markjenn
Oddometer: 10,441
It's entirely possible to do an endo like this over a big speed bump if all the events line up:
1. Soft front suspension with little compression damping and a lot of rebound damping has the bike front end remaining low after hitting the bump.
2. Rider rises up and forward in seat, perhaps in a belated attempt to cushion for a bump they didn't anticipate, probably pulling on the handlebars to raise themselves.
3. Rider belatedly gets on front brake after hitting the bump, further lowering front and raising rear.
4. As rear tire hits bump, the limited rear suspension compresses briefly, then releases its energy hitting the rider in the ass and catapulting him further forward.
Once you hit the tipping point, you're hosed - you're going end over end. Hope he's Okay.
- Mark
Old 12-07-2012, 10:22 PM   #14667
jaumev
jaumev's Avatar
Oddometer: 1,501
I've made some suspension adjustments and fix a new tire in front (Metzeler Unicross 90/01/21) which is higher than the TKC. Now the ground clearance with the ACD skid plate is nearly 24cm. I measured a new bike with the OEM skid plate and is about 18cm. Im very please, All this changes improved more than 5cm the ground clearance than stock.
More than this high could be difficult to me, now I can only just reach the floor.
My old GSA with long suspensions was 23 and the KTM 990 is 26.
I'm going to try this Unicross on the front and a Mitas E10 rear. As you can see is nearly identical than a Karoo T.
Mitas on the left:
I need a hard tire to go to Morocco. TKC's and Karoo's are too soft.
jaumev is offline   Reply With Quote
Old 12-08-2012, 04:45 AM   #14668
Gundy
Oddometer: 944
Gear oil?
Anyone have experience using this stuff
http://www.walmart.com/ip/Super-Tech...allon/16795067
Readily available and cheap.......the KLR guy within is tempted.
'12 Sertao
'00 KDX220R '12 Tenere, '04 Tiger, '09 WRR, '06 DRZ, '06 TW, '01 250 EXC, '09 KLR
Gundy is online now   Reply With Quote
Old 12-08-2012, 05:17 AM   #14669
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 483
Come on, it's a Yamaha who cares? It prolly came with fish oil in it from the factory anyway. Dump in the Wally World stuff, ride the pig and get on with life.
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 12-08-2012, 11:59 AM   #14670
markjenn
Oddometer: 10,441
It's probably Okay oil and GL5 rated so I'm sure it will work fine. But we're talking a buck or two savings for each gear oil change vs. the well-regarded and widely-used M1 and Castrol synthetics, so "the KLR guy within" has to be dominant. And a gallon of this stuff would last about 20 oil changes which is about 320K miles at the factory-recommended change intervals.
- Mark
Times are GMT -7.   It's 09:08 AM.
