12-07-2012, 04:16 PM
#14686 | |
Oddometer: 444
12-07-2012, 07:16 PM
#14687 |
Oddometer: 400
12-07-2012, 08:38 PM
#14688 |
Bumpy Backroader
Oddometer: 2,432
Japako!
+1.
12-07-2012, 09:58 PM
#14689 | |
Oddometer: 9,739
1. Soft front suspension with little compression damping and a lot of rebound damping has the bike front end remaining low after hitting the bump. 2. Rider rises up and forward in seat, perhaps in a belated attempt to cushion for a bump they didn't anticipate, probably pulling on the handlebars to raise themselves. 3. Rider belatedly gets on front brake after hitting the bump, further lowering front and raising rear. 4. As rear tire hits bump, the limited rear suspension compresses briefly, then releases its energy hitting the rider in the ass and catapulting him further forward. Once you hit the tipping point, you're hosed - you're going end over end. Hope he's Okay. - Mark |
12-07-2012, 10:22 PM
#14690 |
Oddometer: 973
I've made some suspension adjustments and fix a new tire in front (Metzeler Unicross 90/01/21) which is higher than the TKC. Now the ground clearance with the ACD skid plate is nearly 24cm. I measured a new bike with the OEM skid plate and is about 18cm. I’m very please, All this changes improved more than 5cm the ground clearance than stock.
More than this high could be difficult to me, now I can only just reach the floor. ![]() My old GSA with long suspensions was 23 and the KTM 990 is 26. ![]() ![]() I'm going to try this Unicross on the front and a Mitas E10 rear. As you can see is nearly identical than a Karoo T. Mitas on the left: ![]() I need a hard tire to go to Morocco. TKC's and Karoo's are too soft. |
12-08-2012, 04:45 AM
#14691 |
Oddometer: 567
Gear oil?
Anyone have experience using this stuff
http://www.walmart.com/ip/Super-Tech...allon/16795067 Readily available and cheap.......the KLR guy within is tempted.
Inconclusive: "Is the Sertão’s price premium worth it? Sure, if you want more power, fuel injection, stronger brakes with standard ABS, better suspension compliance with more travel, higher-quality tires, quicker handling and better fuel economy." |
12-08-2012, 05:17 AM
#14692 | |
Suffer Fools; Gladly!
Oddometer: 318
12-08-2012, 10:40 AM
#14693 |
Oddometer: 195
I use whale semen in mine and havent had any problems.
12-08-2012, 11:59 AM
#14694 | |
Oddometer: 9,739
- Mark |
12-08-2012, 12:04 PM
#14695 | |
Oddometer: 567
12-08-2012, 12:52 PM
#14696 | |
Oddometer: 9,739
- Mark |
12-08-2012, 01:05 PM
#14697 |
Curmudgeonly
Oddometer: 8,935
How do you extract it from the whale?
("Looks like you blew a seal...")
"A man turns his back on the comforts of home... to ride off alone, and when the dust all settles and the story is told, history is made by the side of the road" -DBT, Monument Valley |
12-08-2012, 01:06 PM
#14698 |
Oddometer: 1,691
I changed mine at 500 miles, then every 10,000 after that. At the first 10k change, I pulled the whole final drive and lubed the shaft and splines and everything. I don't plan on doing that again for awhile... maybe around the 50k mile mark. I've been using Napa premium synthetic gear oil, although when I need to re-buy, I'll most likely switch to Amsoil Severe Gear Synthetic Gear Lube.
12-08-2012, 01:12 PM
#14699 | |
Oddometer: 1,691
![]() Well, ok, probably more like ![]() So messed up.
12-08-2012, 03:37 PM
#14700 |
Oddometer: 195
