Old 12-17-2012, 09:17 PM   #14761
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,444
Originally Posted by pluric View Post
I had the reflash before the clutch mod. Across the whole rpm range it smooths out flat spots
and made the bike feel perfectly jetted. I would do the reflash again.
Did the clutch mod make a difference after the reflash? I thought the reflash eliminated the 1st-3rd gear power restrictions that the clutch mod also gets rid of.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 12-17-2012, 10:15 PM   #14762
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,102
Originally Posted by WARRIORPRINCEJJ View Post
I gotta' admit; These posts are putting a little happy in my pocket.
Ewwwww, could have lived without that visual.
With any luck, I'm gonna' try to get my ECU done, after the first of the year. I was waiting until I had a few thousand miles on the bike, so that I was thoroughly used to its behavior (and would immediately notice any difference).
My main question is this...
Does it do anything to the bike on the bottom-end?
Yes, cures the off idle stumble. Smooths out the entire throttle range. No surge or hiccups.
Anyone who rides this bike, for a few hours, will realize that the low-RPM (and partial-throttle) fueling is dicked-up. In fact, if you wanna' see how dicked-up it is, roll the throttle on (1/8 to 1/4) under compression braking. It gargles and warbles all kinds of unnatural noises. And, if you fill it with regular, the low-end issues are even more pronounced.
Other than my KLR, I have never owned a bike that I couldn't (first gear) drift the ass-end, in turns. Even my little DR had a little hooligan in its blood. This bike has NADA...NOTHING. I have a hard time believing that a 1200 doesn't have a little unlocked juice left in there.
I didn't feel there was a large perfomance increase. Some and dyno tests show HP increase.
I was hoping for a sea level feel at alttitude, didn't happen.
I love this bike SO MUCH. A little hooliganability would just be icing on the cake...
You don't have to drift it to find a little hooligan.
pluric is offline   Reply With Quote
Old 12-18-2012, 01:25 AM   #14763
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,455
I have been putting off any mods up till now as most of my riding is 2 up.
Can someone tell me (and I am sure it was posted before on page gazillion) but does the ECU flash remove T mode.
I find T mode useful in traffic especially when the boss is on the back.
The stumble and cutting out when blipping the throttle is starting to pi55 me off so now I am thinking about it.
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 12-18-2012, 01:44 AM   #14764
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,444
The clutch mod will get rid of the stumble off idle. If you add a switch you can use T (or S) mode when desired.
From what I understand, the Diapason reflash leaves T mode unchanged, while the ECU Unleashed reflash sharpens it up a bit but it's still less aggressive than S mode.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider screwed with this post 12-18-2012 at 01:55 AM
Old 12-18-2012, 04:17 AM   #14765
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,857
You don't have to drift it to find a little hooligan....
How much does the County charge you, for asphalt repair, when that front wheel touches down?
Thanks for the response, Pluric. Other than you and Allan, sometimes, after I post a question, I start to think that the whole thread has me on "ignore".
I feel like the highlighted areas coulda' been me posting. I feel the same way.
Like you, I also find myself using the "T" mode. Most recently, San Antonio has been getting these morning drizzles. They soak the street, but don't really wash-off the oils. I absolutely love "T" mode (and all the other 'lectronic goodies) during those "oil slicks".
In regard to the throttle blipping, mine has cut-out completely (died), twice, while I did that. As you stated, it's kind of annoying...
EDIT- I forgot to post; When I spoke to the gentleman, at AF-1, he informed me that (after the reflash) "T" is still "T", and "S" is still "S". As has been posted, the reflash simply makes the bike run like it is perfectly fueled...
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 12-18-2012, 04:28 AM   #14766
tremor38
tremor38's Avatar
Oddometer: 1,460
I'm running the Diapason reflash and really like it. That said, if I had to do it over again I'd go with the ECU unleashed flash. As much as I like most of what the Diapason flash brings, it doesn't smooth out the on/off throttle transitions. They are more abrupt if anything (S mode). From what I've been reading, people who have the ECU unleashed flash report a smoother on/off throttle transition.
When you add-in the fact that Italian customs jacks you up with an import duty on the way in, communication from MotoShop Yamaha is spotty and slow, then U.S. Customs hits you with an import duty on the way back, ECUu really starts looking attractive.
2011 Yamaha XT1200Z
tremor38 is offline   Reply With Quote
Old 12-18-2012, 05:19 AM   #14767
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,720
From my short ride yesterday evening, I can say the answer is a definitive yes!
Example 1:
Before the re-flash when cruising along at about 65 in 6th gear, if you had to slow to 55, you really needed to downshift to 5th to get back up to speed without having the engine feel like it was going to rattle itself to death. Now it will roll from about 50 to whatever speed you want in 6th gear and do it smoothly.
Example 2:
Lugging in 1st gear, rolling around 7-8 mph; before the re-flash the bike would lunge and lurch when you cracked the throttle. Now it just transitions smoothly from idling to whatever amount of throttle you give it.
Anticyclone is online now   Reply With Quote
Old 12-18-2012, 06:33 AM   #14768
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,444
No reflashed bike to compare it with unfortunately, but my bike feels smooth and powerful with the clutch mod compared to without it. Fixes the initial lag in first gear and will lift the front wheel in second. If the reflash bumps up the upper rpm power I might consider it after losing a highway roll-on contest to a stock 2006 1200GS in 5th and 6th gears.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
Old 12-18-2012, 07:44 AM   #14769
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,102
Opps, I just got a bunch of angry PMs. Seems the other guys are pretty pissed at Allan and I right now.
Gotta go, someone is driving slow by my house again.
Seriously check out the threads over on the sober site about the reflash. I used the people in
Texas at Dallara's recomendation. AF-1 I think. Fast turnover. They'll talk to you on the phone
about any concerns or if you have after market mods that may need to be considered for the
reflash. Very good people to work with.
Old 12-18-2012, 07:52 AM   #14770
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,102
Wait until you try it against a 2010 GS. That was just humiliating. Oh well, The Tenere beat it off road.
I did feel it pulled stronger in the upper gears after the reflash. As far as lofting the wheel into second
you must be at or close sea level. When I had it in Baja it was a different bike. Big grins.
Utah is pretty stingy with it's air and it's a noticable differerence in power loss.
Trying to get to Death Valley next week to get my air fix.
Old 12-18-2012, 08:06 AM   #14771
cug
Oddometer: 4,939
Argl ...
cug is offline   Reply With Quote
Old 12-18-2012, 08:47 AM   #14772
WARRIORPRINCEJJ
Oddometer: 9,857
Example 1:...
...Example 2:...
As usual, I'm liking what I'm hearing. Those are definitely two behaviors that I've noticed (and the bike could do without).
I'm all for "clean" vehicles. But, the Manufacturers and Emissions folks should try to strike a balance between "clean" and "nice running". If it were more balanced, I think Yamaha woulda' hit the nail square on the head with this bike. Except for a few little quirks, the bike is damn-near perfect for me.
Seriously, man. You've seen some of my questions. I post, and it's like *crickets*...and then y'all go back to discussing waitresses, the sexual orientation of the owners of black S-Ts, etc.
The guy you're thinking of is "Ed", at AF1. Allan gave me his name. The great thing, for me, is AF1 is ~60 miles from my front door.
As far as readling more about the ECUnleashed, I'm already sold. I just wanted to ask that one question.
Old 12-18-2012, 09:01 AM   #14773
Anticyclone
Oddometer: 5,720
Like this one?
I asked this question, before, and don't remember getting a single response. So, I wanted to check-in, again.
I have a Yamaha top box. It lets-in dust, water, small animals, etc. (while it's closed and locked)
I seem to remember that this was a common issue, and that there mighta' been some warranty assistance. However, my search fu is weak.
Anyone got any info. they could throw my way?
Thanks in advance...
J.J.
I don't have the Yamaha cases, so I'm no help.
But I get the same feeling sometimes. I just figured it was because my S10 is black.
Old 12-18-2012, 09:10 AM   #14774
WARRIORPRINCEJJ
Oddometer: 9,857
Like this one?...
Exactly like that one...
...I don't have the Yamaha cases, so I'm no help.
Oh, your S-T is black?
Please don't respond to anymore of my questions...
Old 12-18-2012, 09:24 AM   #14775
rebel346
rebel346's Avatar
Oddometer: 70
That!
rebel346 is offline   Reply With Quote
Times are GMT -7.   It's 03:48 PM.
