03-17-2010, 05:49 PM
#61 |
Life is good
Oddometer: 306
Did any of you guys upgrade the carb? I swapped-in a CRF100 carb and my TLR runs so much better. The carb and 10/50 sprockets made a huge difference.
03-18-2010, 06:26 AM
#62 | |
Buffoonery, Inc.
Oddometer: 2,312
Work hard. Play hard. Team Dead End. The drinking team with a Trials problem. ![]() 2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ. |
03-22-2010, 03:05 PM
#63 |
Retarded Motardian
where did you find 9 and 10 tooth front sprockets, i dont see anything under 12 teeth listed for the reflex or xr.
Duc, sequere, aut de via decede |
03-22-2010, 05:25 PM
#64 | |
Oddometer: 95
B&J Racing
http://www.bjracing.com/tlr200.html |
10-27-2010, 06:17 PM
#65 | |
Oddometer: 378
10-28-2010, 05:15 AM
#66 |
Oddometer: 237
Yeah.. BRAVO to us
10-28-2010, 08:50 AM
#67 |
not waiting anymore
Oddometer: 1,685
Buy the poor thing some fresh tires, then go out and ride!
10-28-2010, 07:36 PM
#68 |
Oddometer: 97
carb swap
I'm interested in changing my carb also. I've heard of using the xr 100. and the crf 100. Any advantage to either?
quote=NJ-Bill]Did any of you guys upgrade the carb? I swapped-in a CRF100 carb and my TLR runs so much better. The carb and 10/50 sprockets made a huge difference. [/quote]
10-28-2010, 11:57 PM
#69 |
Loose Pre Unit
Oddometer: 3,977
I thought the TLR200 footpegs were too high when I first got it - they feel they are above the CG,compared to other bikes which feel like they are under the CG.The bike feels very tippy,and responds too much to weight inputs....but now I'm used to it and don't want to change.
Gearing is an issue - with 2 stroke twinshock bikes 2nd gear is used for nearly everything,3rd only for long hills,and first for some real knarly stuff.The TLR200 hasn't got the grunt to use 2nd even on small climbs,you just have to use 1st and rev the tits off it.The saving grace is that it has more traction than a 2 stroke under power,so you can use full throttle on hills.A 2 stroke of course uses the flywheels,and will climb with a shut throttle. The TLR250 is much better,with only 5 speeds and better gear ratios you can use 2nd,and it has the grunt to pull it too.But TLR250 riders I've talked to say they just use 1st gear too.Here are a couple of TLR250's - I rode the one nearest the camera,the one behind is a works bike.
10-29-2010, 05:56 AM
#70 |
Buffoonery, Inc.
Oddometer: 2,312
MMmmmm, works bike.......
10-29-2010, 06:36 PM
#71 |
Loose Pre Unit
Oddometer: 3,977
Practically the same bike with an alloy tank/seat unit.And a TLR250 is almost the same as a TLR200....but completely different to ride.A Reflex is almost the same as a TLR200 too....but was down graded to a trail bike.
10-30-2010, 05:02 PM
#72 | |
Buffoonery, Inc.
Oddometer: 2,312
VERY downgraded.
10-31-2010, 01:40 PM
#73 | |
Life is good
Oddometer: 306
03-30-2012, 08:20 PM
#74 |
Ride Deprived
Parts left over you say? Sending PM... Might need some of yer junk :b
03-31-2012, 12:51 AM
#75 |
Oddometer: 1,073
TLR 250 has 6 gears as does the 200. The 200 with a few simple mods is a far more effective bike than the 250, and Adrian Lewis I think will be riding a modified 200 in this years US national twin-shock championship series. Carb that seems to work very well on the 200 is listed on Ebay here: http://www.ebay.co.uk/itm/MIKUNI-VM2...item43ad928f5a but do seem to be available most places in the world.
