Old 02-08-2010, 07:19 AM   #1
Pappy541 OP
Pappy541's Avatar
Oddometer: 803
mapsource problem after computer crash
I need some advice.
Several weeks ago my computer came down with a very bad virus. The virus basicly would not let me do any thing with the computer unless I bought their spy wear protection. All my programs including mapsource were unusable. The telephone computer help person advised that I buy a external hard drive to move my stuff too and then he nuked the bug. The computer has now recovered and is working. Mapsource however did not survive. None of the saved files would open.
So I deleted mapsource and using the CD reinstalled it. Wow this is now an updated version and is much better. However after working on a new trip I go to save it and when I go back to open the saved file the computer wants to open it in the image/ picture program. So then I right click and go to the open in program guide and I get all sorts of options but no mapsource even though mapsource is on the computer.
WHAT do I need to do?
Pappy541 is offline   Reply With Quote
Old 02-08-2010, 09:11 AM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,463
Since you had a virus, I will assume you have a Windoze OS. Here is how you associate your GDB and/or GPX files with MapSource.
1. You will now be in a file explore window and you will need to fine the MapSource application....here is where it might be a bit difficult for you...so, I suggest you Search your C: Drive for the MapSource application: mapsource.exe.
2. When you find it, write down the location - something like: C:\Program Files\Garmin\mapsource.exe
3. Now that you know the location of the MapSource program
4. Open a folder with anyone of your GDB and/or GPX files in it.
5. Right Click on the file name and select PROPERTIES from the list.
6. In the resulting popup window, you will see just below the Tabs a section that says: Type of file: .................
Opens with: ................ "Change"
7. Click on the CHANGE button.
8. In the resulting popup window if you don't see MapSource listed, select the BROWSE... button.
9. Now just navigate to it location of the mapsource.exe file...once there, select the mapsource.exe file and click on OPEN...
10. Select the OK button then in the remaining popup window select the APPLY and then the OK buttons....
You have now associated the GDB and/or GPX file types with MapSource.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is online now   Reply With Quote
Old 02-09-2010, 09:21 AM   #3
Pappy541 OP
Pappy541's Avatar
Oddometer: 803
Thanks for the reply and I get it corrected. Thanks a lot!!!!!!!!!!!!!!!
Times are GMT -7.   It's 09:41 AM.
