Old 02-10-2010, 01:05 PM   #1
catweasel67 OP
Oddometer: 8,856
mapsource..I cocked up and...
well..I downloaded the US and it's sitting in my memory card fine but...
no US maps in mapsource. When I did a bit of digging I realise I should have purchased the CD (same price even).
Anyone else done this and found a solution that doesn't involve paying Garmin another $100? I route plan a lot in mapsource so am keen to get this resolved...or am I screwed?
catweasel67 is offline   Reply With Quote
Old 02-10-2010, 02:18 PM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,994
You will have to work that one with Garmin. My experience has been that they will not charge you full price on the CD if you are polite and tell them you made a mistake....
You might also try your trip planning over at RideWithGPS. It's free and will do most of what MapSource will do. I understand support for creating Waypoints is under consideration.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 02-10-2010, 02:27 PM   #3
catweasel67 OP
Oddometer: 8,856
Cheers,
thanks Drtbyk...dirtbike? your reg plate?
Old 02-10-2010, 02:45 PM   #4
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
Yep....
Cheers,
Dan
All Things GPS
Old 02-10-2010, 02:50 PM   #5
Oldmessage
Tour Guide
Oldmessage's Avatar
Oddometer: 45
Hi, I had the same Problem, one call to Garmin Support and explain what you did (be friendly, laugh) and they will send you a CD, cause the downloaded version can't be used on your PC.
Play stupid and tell them that the waring on theire website isn't big enough for you un-computerized person. Worked for me.
Ohh, you would need to install the Map from the CD again on your Navi, just to make sure MS and Navi are in sinc.
TJ
Breaking is the convertion of premium speed into useless heat !!
"Don't follow me--you won't make it"!!!
Tourguides always from "Bike Tour Germany"
www.BikeTourGermany.com
Oldmessage is offline   Reply With Quote
Old 02-10-2010, 04:05 PM   #6
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,766
Just to clarify - it's DVD not a CD. You must have a DVD drive.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 02-10-2010, 11:59 PM   #7
catweasel67 OP
Oddometer: 8,856
thanks guys :)
Old 02-11-2010, 01:47 AM   #8
buick driver
buick driver's Avatar
Oddometer: 89
Cheers,
Great site, Thank you.
just another dave in paradise
buick driver is offline   Reply With Quote
Old 02-17-2010, 04:04 PM   #9
buyarbi
buyarbi's Avatar
Oddometer: 36
I tried the demo map on ridewithgps and it created a red line between required points (route or track) for north america but not for central or south america. Is this typical for all gps routable maps for central and south america.
Bill
buyarbi is offline   Reply With Quote
Old 02-17-2010, 04:28 PM   #10
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
Yes, Google Maps does not have routable data for Central and South America (and many others). You can create a Track though...just select the "Draw Lines" routing option.
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 02-17-2010 at 04:38 PM
Old 02-20-2010, 11:11 PM   #11
Thinc2
Paciugo
Thinc2's Avatar
Oddometer: 4,652
Cheers,
How do you download a Route you create in RidewithGPS to your Garmin?
I get to the point where you can export it, but all it does is save it as a file. How do you get that to the GPS?
Me: You should think before you speak.
Daughter: That always backfires on me.
F800GS review.
Thinc2 is offline   Reply With Quote
Old 02-21-2010, 12:20 AM   #12
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
That depends upon the GPS you have. If your GPS can connect to your computer as a USB Storage Device, you can just save that Exported file directly to the GPS's proper folder.
If Ride With GPS doesn't work for you, you can always just use Google Maps along with the GMAPtoGPX Bookmarklet and GPSVisualizer.
Cheers,
Dan
All Things GPS
Old 02-21-2010, 12:33 AM   #13
Thinc2
Paciugo
Thinc2's Avatar
Oddometer: 4,652
It's a zUMO 550... I tried that and it didn't show. Tring again - what folder do i use?
Why are these things so complicated to use...
EDIT - just figured it out - this is a good alternative to mapsource - thanks!
F800GS review.
Thinc2 screwed with this post 02-21-2010 at 12:54 AM
Times are GMT -7.   It's 12:08 AM.
