Old 03-23-2012, 03:28 PM   #211
Raven Rider
Oddometer: 267
How much are the gen 2 spot cradles?
Raven Rider is offline   Reply With Quote
Old 03-23-2012, 05:50 PM   #212
Stovebolt OP
Team Ruptured Buzzard
Stovebolt's Avatar
Oddometer: 478
Hi Raven Rider,
(Nice handle...)
All cradles remain $75, check or money order only. I pay USPS Flate Rate Priority Mail to all ADV Inmates, to CONUS addresses.
If you want a SPOT cradle though, you should PM me to confirm stock availability before sending a a check, and I'll shoot you a reply. Then you can print the instruction and liability release form, read - initial - sign that, and get it coming my way with your check. Gen1/Gen2 SPOTs are available in BLACK or Carbon KYDEX and in stock at this time. (SPOT cradles are the only cradles that I require the signed release hard copy in hand before I ship.)
Thanks for all!
Stovey
Stovebolt
Team Ruptured Buzzard "Never Give Up"
http://bustedcompass.com
http://www.linkedin.com/pub/david-jankowsky/86/31/b04
Stovebolt screwed with this post 08-30-2012 at 05:55 AM
Stovebolt is offline   Reply With Quote
Old 04-26-2012, 08:04 PM   #213
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
Field Test (Crash Report from Wyoming)
Berg Briggs remains one of my most arduous field testers - he has no fear of riding hard, nor of setting his KTM down occasionally...
His most recent get-off in the Red Desert yielded a broken RAM ball from the impact of his cratering into his handlebars with his chest protector. Luckily, he was unhurt and his bike was fine too! But the cradle got sheared from the bars and landed in the desert - GPS unharmed.
Cradle - unharmed. No damage.
RAM ball - busted.
The cradle Berg was using was an early prototype that's been in service for a couple years. Newer ones are much improved over this version, but it still functions as intended. That gives me some satisfaction, and glad he wasn't hurt when out doing some earth-moving in the Big Sandy last weekend. (Good riding with ya, Berg.... you too Jwats.)
All the best,
Stovey
Stovebolt
Stovebolt screwed with this post 04-26-2012 at 08:09 PM Reason: add pic
Old 04-28-2012, 04:43 PM   #214
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
Hi,
These are the kinds of things you will need to mount my CRADLE - (customer supplis his/her own RAM Mounts. RAM Mounts are not included with my cradles.)
A RAM diamond plate with ball
http://www.gpscity.com/ram-mount-dia...am-b-238u.html
The BUZZ BOMB Cradle is designed to connect to the RAM Diamond Plate on the back of the cradle. The diamond plate has a 1.0 inch diameter rubber ball connected at right angles to the plate, which connects directly to the 1 inch arm socket. You will also need the RAM arm socket...
http://www.gpscity.com/ram-mount-med...am-b-201u.html
You will also need a way to get this onto your bike, and there a different ways to do that with the RAM system. A common mounting is on the handlebars using a setup like this...
http://www.gpscity.com/ram-mount-zin...m-b-231zu.html
Medium length arm kit:
https://www.gpscity.com/ram-mount-cr...inch-ball.html
or maybe,
Short length arm kit:
https://www.gpscity.com/ram-mount-zi...-assembly.html
Thats the basics. There are so many options to "get your balls together" with RAM components that each rider needs to sort that out with their own bike. Different handlebar diameters take different sized U-bolts, so pay attention to your dimensions when shopping.
But I will stress that the cradle I make is designed to work only with the RAM mount system. The adjustability and shock absorption and impact resistance of the RAM mounts help keep my cradles "bomb-proof." Mounting them any other way with any other components is recommended against.
Stovey
Stovebolt
Stovebolt screwed with this post 01-22-2013 at 06:14 PM
Old 05-14-2012, 02:20 PM   #215
Bicycle Phil
Bicycle Phil's Avatar
Oddometer: 692
are you around
Stovebolt,
I want a cradle for a friends 60csx. I suspect that my check will get to you in 3 days.
Can you send me a cradle to arrive(San Francisco) by June 14th?
Not too picky with the material/look....do prefer the kydex carbon fiber if possible.
thanks
Phil
-Phil-
San Francisco Motorcycle Club
Thank you: MX1West, Renazco Racing, KTM Twins, Rally Management Services
Bicycle Phil is offline   Reply With Quote
Old 05-14-2012, 02:48 PM   #216
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
Absolutely Phil - you got it.
PM your mailing address for USPS and it goes out in tomorrow's mail to you.
Thank you again, Good Sir.
Sincerely,
Stovey
Originally Posted by Bicycle Phil View Post
Stovebolt,
thanks
Phil
Stovebolt
Old 06-08-2012, 02:11 PM   #217
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
New "Holstex" is shipping now...
Hiya,
All orders shipped and the last of the older Kydex "Carbon Kydex" lighter grey color is almost gone. When I'm out of these it will be awhile - if ever - that I do another run of that coloration. The newer Holstex Carbon Fiber (look-alike) is what I've got going, but all SPOT's and Garmin 60's are still on hand in Carbon Kydex (lighter grey fleck). Some items not on hand in the new Holstex pattern yet but I'm trying to build some more stock of these.
Meanwhile, everything ordered is out the door, and so am I, for the weekend. Will answer any PM's starting again on Monday June 11.
Thanks again to everybody for your orders, encouragement and kind words! Happy trails for now...
All the best,
Stovey
Stovebolt
Old 06-11-2012, 10:26 AM   #218
DeepSea
electronically challenged
DeepSea's Avatar
Oddometer: 240
Garmin 60 series
Hey Stovebolt, I'd like to get a cradle for my Garmin 60 in the "Holstex" if you have them available.
Thanks,
Steve
CDR 2012 ------ Too Lazy to write my own RR
Commercial Diving flashlight and tools
It's not me. My bike is Narcoleptic.
Research is what I'm doing, when I don't know what I'm doing.
DeepSea is online now   Reply With Quote
Old 06-11-2012, 11:34 AM   #219
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
PM sent Steve,
Thanks,
Stovey
Thanks,
Steve
Stovebolt
Old 06-16-2012, 11:30 AM   #220
DeepSea
DeepSea's Avatar
Oddometer: 240
Thumb Fast shipping
Shipping was very fast. Got a quote on Monday, received it on Wednesday.
Good product, it fits very well.
I wouldn't hesitate to buy another or recommend to my friends.
Thanks Stovey, keep it up.
Steve
Old 06-16-2012, 09:13 PM   #221
TRZ Charlie
That's MR. Asshole
TRZ Charlie's Avatar
Oddometer: 15,892
No affiliation but I wanted to drop a line here. Dave (Aka: Stovebolt) makes great products. I have a SPOT mount that has been on my bike a while now and it is fantastic, good looking and rock solid. If you have doubts about purchasing one of these you can be sure that you are receiving a A+ product.
My SPOT - No tracks = not riding | Husky TR650 Thread Index | Husky TR650 OEM and Interchangeable Parts List | Cheap Beer & Tenderloins | "You know your getting old when a bad hair day includes your nose, eyebrows and ears" - Inmate - advNZer?
TRZ Charlie is offline   Reply With Quote
Old 06-17-2012, 04:36 PM   #222
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
Thank you Steve and Charlie!
I am very fortunate to have such good people as customers such as yourselves. I'm glad you are satisfied, of course... but for you to take the time to say something so complimentary is very gracious. This makes me try all the harder to make things great for everybody, every chance I get. I sincerely appreciate it!
All the best my friends,
Stovey
Stovebolt
Old 06-20-2012, 08:18 PM   #223
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
Off-line for 4 days until 6/24 and will answer any/all PM's this thread upon returning.
Thanks again for all the support and patronage!
All the best,
Stovey
Stovebolt
Old 07-11-2012, 07:41 PM   #224
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
All current orders shipped - thanks!
Everything ordered has been shipped as of today.
Will advise when and as the new Montana series is in production and available. Possibly be end of August.
Thanks for all!
Stove
y
Stovebolt
Old 08-30-2012, 05:57 AM   #225
Stovebolt OP
Stovebolt's Avatar
Oddometer: 478
Garmin MONTANA's coming soon...
I've been tooling up for the new Garmin Montana's and I should have some of these available soon.
Carbon Holstex material. Same price as all the others. $75. PM to order.
Stovey
Sorry for the Crappy pictures...
Carbon HOLSTEX
Montana and a 60Csx
Montana and a Gen2 SPOT
Montana and a Gen1 SPOT
60Csx and a Gen2 SPOT
SPOT and a SPOT (Gen1 and a Gen2)
*Gen2 SPOT installation note*
You MUST remove both safety covers over the HELP and OKAY activation buttons prior to installation into my cradles.
These things gotta come off before you put a Gen2 SPOT into a Buzz-Bomb cradle
GEN2 SPOT only - remove back cover over battery compartment.
Safety covers are designed to be removable. Slip them off from their keeper tab, no tools needed.
Get them both off, one from each side.
Make it look like this, both safety covers removed. Then install into Buzz-Bomb cradle after that.
This procedure is a condition of use. Thanks!
Rally on,
Stovey
All cradles still $75 each. I pay mailing to ADV members via US Postal Service, Flat Rate Priority Mail
Stovebolt
Stovebolt screwed with this post 09-02-2012 at 08:18 PM
Times are GMT -7.   It's 05:36 PM.
