Old 09-13-2013, 08:55 AM   #271
hammerinn101
hammerinn101
Oddometer: 11
My Cradle
Great Product thanks, I used it my ATK-605 Baja 1000 2012 after some get offs the cradle held the GPS unit save and secure.
hammerinn101 is offline   Reply With Quote
Old 09-15-2013, 05:03 AM   #272
cheekorollo
cheekorollo's Avatar
Oddometer: 74
Gday Stovey,
Did you ever end up developing a mount for the Garmin 62? I've got one and my ram mount fell to bits... I spotted one of your mounts for a 60 series and they look the goods. If you make one for the 62 I'll be keen!
Cheers.
2012 KTM 690 Enduro R. Only broken down twice!
2004 KLR650. Was tired, but trusted. Now retired.
cheekorollo is offline   Reply With Quote
Old 09-15-2013, 01:31 PM   #273
Stovebolt OP
Team Ruptured Buzzard
Stovebolt's Avatar
Oddometer: 479
Thanks hammerinn101!
(PM sent)
All the best,
Stovey
Stovebolt
Team Ruptured Buzzard "Never Give Up"
http://bustedcompass.com
http://www.linkedin.com/pub/david-jankowsky/86/31/b04
Stovebolt is offline   Reply With Quote
Old 09-15-2013, 01:35 PM   #274
Stovebolt OP
Stovebolt's Avatar
Oddometer: 479
Hiya cheekorollo,
Sorry to say, I never have developed the cradle for the 62 series. I don't like what I have to do to make me happy with the results to defeat the design I like vs. the power button location on the new 62 series, so I won't be tooling up for that and offering a cradle for the 62's. Anything new I make though, will be posted up here to offer.
Thank you, kind Sir. And a sincere G'day back at you!
All the best,
Stovey
Originally Posted by cheekorollo View Post
Gday Stovey,
Cheers.
Stovebolt
Old 09-15-2013, 08:51 PM   #275
cheekorollo
Oddometer: 74
Thanks for the quick reply, Stovey. Bummer! Maybe I just need to get a new GPS!
Old 09-18-2013, 08:13 PM   #276
Stovebolt OP
Stovebolt's Avatar
Oddometer: 479
Thanks cheeko! You are too kind, Good Sir....
All the best,
Stovey
Stovebolt
Old 10-14-2013, 06:17 PM   #277
Stovebolt OP
Stovebolt's Avatar
Oddometer: 479
The last few orders that have come in have been mailed out. I have some cradles made up and on hand to mail.
PM here to order.
If any of you guys who competed in the Erendira Baja Rally last week want to jump in here and comment on how yours worked, please feel free. Criticisms accepted and welcome.
Thanks for all!
Stovey
Stovebolt
Old 11-05-2013, 03:18 PM   #278
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,505
Originally Posted by Stovebolt View Post
Independent Cradle Review on GPSTRACKLOG.com forums by Rich Owings.
http://gpstracklog.com/2010/05/a-new...gps-mount.html
FWIW.
Concealex now shipping, and thanks to all for recent orders.
Sincerely,
Stovey
I had a question, I was going to PM you, but I figured I could ask it here, and other people might benefit from it too.
Looking at the above link, I like the mount they have, it's a simple clamp and a diamond back plate. It would mount perfectly to the crossbar on my bike. But I'm not sure if that makes the bottom half of the cradle permanently mounted to the bike or not.
For arguments sake, say it does, how is your cradle at opening and closing regularly? Am I going to wear out/loosen the side slide locking tabs eventually if I open up the cradle at the end of each day and remove the GPS? What if I don't wire the GPS to the bike and need to open it regularly to swap batteries?
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 11-05-2013, 06:17 PM   #279
Stovebolt OP
Stovebolt's Avatar
Oddometer: 479
Cradles must be mounted with RAM Mounts!
Hi Brian,
Fair question and I hope I save you and anybody else thinking along the same lines some heartache.
As it has been explained in this thread, post #1 and numerous other places, my cradle is designed to mount with the RAM Mounts only.
My cradle is designed to mount with the RAM Mount System, ONLY - no other way. If you mount it in any other way, and in particular, in any way that "hard mounts" it to any vehicle, you have defeated a design feature/concept and will run significant risk of loss of your GPS and damage to same and the cradle.
The RAM has a rubber covered ball. It also has an articulated arm. Even when the ARM mount is snugged down with the twisty knob it still has the ability to move during a crash. Two things happen there - the cradle moves and acts more like a bending reed in the wind (the JUDO Way) and therefore has less chance of taking full shock from an impact - the inertia of the moving GPS and cradle gets dissipated over some distance while the RAM arm moves, and therefore less shock loading.
Also, if an object happens to make direct contact with the cradled GPS, it can move.
Additionally, two separate rubber mount balls from the RAM mounts also aid in absorbing some vibration which is another good thing for your GPS.
My cradle is made out of plastic - it can break. They seem to work pretty well when mounted as designed, intended, explained and illustrated and outlined in the directions that I send with each cradle.
Please do not mount the cradle without using an articulated arm with the RAM mounts.
Rich Owings reviewed my cradle years ago, and his application in that case was on a mountain bike, and he liked it. I still recommend that all my cradles get mounted with RAM mounts exclusively, all the time, regardless of what vehicle they may be mounted on. Even a mountain bike. An ultralight aircraft, snowmobile, personal water craft, street bike, dirt bike, ATV - anything.
I also always recommend hard-wiring the GPS.
I also recommend taking the GPS on and Off the bike via the RAM mount, rather than consistently splitting the cradle to remove just the GPS.
Eventually, yes - you can wear the contact areas out with many repeated uses like that. I am still able to join and seal my original cradle though, even though a newer and more improved cradle is in the cockpit of my KTM. (It's the exact same improvements I have been making and sending for the past two years when I retooled.)
To answer that question directly, I would say "Yes - you will wear the cradle out sooner if you open and close it repeatedly at short intervals to change batteries."
A benefit to not using batteries and hard-wiring the unit is that there is less inertial energy stored in the GPS to bang around in the compartment, and add wear and tear to the GPS itself, as well as reducing the inertial mass of the GPS which helps keep it alive in crashes.
I carry batteries for backup and had to use them this summer when my 5-year-old battery cable died and before I replaced it. The cable was around $16 if I remember right, and it's worth it to me to have it running off my bike battery. I realize everybody has preference - I respect that, of course. Just giving you the discussion here, since you had some questions. Hope this helps.
Sincerely,
Stovey
Stovebolt
Old 11-07-2013, 01:58 PM   #280
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,505
Got it today, looks great, GPS should be here in a couple days, I can't wait til I get it all mounted up.
Old 11-10-2013, 03:50 PM   #281
Stovebolt OP
Stovebolt's Avatar
Oddometer: 479
I'm glad you like it Brian...
Stay in touch!
All the best,
Stovey
Stovebolt
Old 11-12-2013, 02:13 PM   #282
Hardroad
Oddometer: 142
Stovey,
I purchased a cradle for my 60csx in the past.
I'am updating to a Garmin Montana.
Do you still carry a cradle for it.
Hardroad
Wayne Ray
Hardroad is offline   Reply With Quote
Old 11-12-2013, 07:17 PM   #283
Stovebolt OP
Stovebolt's Avatar
Oddometer: 479
Hi Wayne!
Yes, and I have a couple on hand to send you one. Shoot me a PM with your current good USPS mailing address and I'll get one coming to you. They are all still $75, mailing included to inmates.
All the best,
Stovey
Originally Posted by Hardroad View Post
Stovey,
Hardroad
Wayne Ray
Stovebolt
Old 11-13-2013, 06:07 AM   #284
Stovebolt OP
Stovebolt's Avatar
Oddometer: 479
Position Wanted - Stovey looking for job
Posted in Regional Forums under 'West Networking' thread, here:
http://advrider.com/forums/showpost....&postcount=131
My day job has evaporated. My spirit and needs have not. Thanks for any and all...
Rally on,
Stovey
Stovebolt
Old 12-17-2013, 05:10 PM   #285
Brods1675
Giant
Location: Tasmania. Amazing roads. Adventure bike heaven.
Oddometer: 129
Question Mail to Australia?
I have a 60 series Garmin. So far it's been lost 3 times and luckily found. First time was a Garmin handlebar mount, last 2 were from a ram mount, which ended up snapping in half. the GPS was found in a clay rut.
It's now known as the Chuck Norris GPS as it can't be killed.
Are you able to mail one to me in Australia?
Cheers, Andrew.
2010 R1200GSA
2014 WR450FE
https://www.airbnb.com.au/rooms/4158796
Brods1675 is offline   Reply With Quote
Times are GMT -7.   It's 12:45 PM.
