02-16-2010, 03:32 PM
#16 |
ucancallmeray
Oddometer: 252
Ladder106
Thank you for the advice, I have actually read the entire Show Us your Transalp thread and knew about that bracket. I welded one up out of the orignal backet and some strap iron. You can see it in this picture.
![]() Don't ask about the cardboard....that will be revealed later. Oh and the centerstand...I can not believe that someone would sell a motorcycle without a centerstand. That too will be revealed later. Stay tuned... justplainray |
02-16-2010, 03:37 PM
#17 |
ucancallmeray
Oddometer: 252
wide...
I will look into that VW tailpipe extension, I thought there might be something missing from this muffler. The two screws are gone and I figured there must have been an "inner pipe", other wise why have the two welded nuts in place.
Thanks, justplainray |
02-17-2010, 05:21 AM
#18 |
ucancallmeray
Oddometer: 252
Here's a little something to start the day with...
![]() Have a Nice Day justplainray |
02-18-2010, 03:18 PM
#19 |
ucancallmeray
Oddometer: 252
TransAlp Center Stand
Well, I don't understand why any manufacturer would build a bike without a center stand. It is just beyond me. So high on my priority list was to design, fab and install a center stand. Studing the TransAlp frame I noticed there is a cross tube at the lower rear of the engine cradle. This tube is capped on it's ends with real thin sheet metal. After chiseling this off, I could see that the tube ID was 25mm and the tube was un-obstruted. This is where the stand would pivot.
Here is a JPG of the 3-D CAD model. ![]() Here's the same view of the actual installation. ![]() First I fitted nylon flanged bushings into the frame tube (1" OD x 3/4" ID). Had to turn the OD's down to fit. The main pivot shaft is 3/4" OD x 11 1/4" lg with a 3/8-16 X 12" lg hex head bolt thru the center. The center stand itself is a weldment of 1/2" black iron pipe and 1/4" inch plate steel. I had to mill a notch in the left foot peg/kick stand weldment to clear the left side pivot plate, I over did it a bit as you can see in this photo. ![]() The right hand pivot is threaded 3/8-16 to accept the thru bolt and hides nicely behind the exhaust collector. ![]() When the stand is folded up, the cross bar is resting against the Pro-Link frame bracket, visible in the first photo. More to come...Stay tuned. justplainray |
02-18-2010, 07:02 PM
#20 | |
This sentance intent
Oddometer: 15,144
DSI #694 Quote:
02-22-2010, 04:22 PM
#21 | |
ucancallmeray
Oddometer: 252
Oh the things I've seen...
as I tear this beasty down.
I was planning on having the wheels re-laced with stainless steel spokes and nipples, but when I removed the tires and sand blasted the corrosion away, this is what I found. Quote:
justplainray |
02-23-2010, 04:08 PM
#22 |
ucancallmeray
Oddometer: 252
More happy stuff...
continuing the tear-down uncovered this little problem...
![]() the counter shaft splines were shoot. So I ordered a new countershaft from Honda (yeah, they still stock it..$85.00) and packed the engine/tranny off to my local independent bike mechanic, Art at Valley Cycle (Ansonia, CT) New shaft installed. ![]() While everything was apart we found a rusty spot on a cylinder wall, which required a bore job and new pistons from Honda (0.5mm oversize...$55.00 each) Apparently water had been allowed to sit in the rear cylinder for an extended time. A winter spent under a tarp is a killer on an engine. ![]() And with 48k on the odometer, I had better replace the clutch pack and springs... ![]() the basket and hub are in good shape... ![]() ![]() The rest of the engine/trans looked "really good" according to Art. I hope so...these kinds of surprizes are expensive. More to come. justplainray |
02-23-2010, 06:07 PM
#23 | ||
Oddometer: 15,144
Uh...Just wondering, shouldn't you have clean up the case while you had it apart?
DSI #694 Quote:
02-23-2010, 06:13 PM
#24 | |
Loco, pero no estúpido!
Oddometer: 2,274
I really like what I see here....hummm!
Carlos locorider 1989 Honda XL600V Transalp, slightly modified! 1974 Catalina 22....sailing, mi otra pasión! "If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian "Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller Longaniza Ride Ruta del Café |
02-23-2010, 06:59 PM
#25 | |
ucancallmeray
Oddometer: 252
That is clean...
LOL...
I srubbed with a stiff bristle brush some more after the cases were reassembled so I could paint the whole engine. Quote:
justplainray |
02-23-2010, 07:08 PM
#26 | |
ucancallmeray
Oddometer: 252
You are speaking....
of my cardboard skid plate?
With which I intend to repel cardboard rocks? Yeah, I started with a flat layout of a skid plate that I found somewhere on the web. Modeled it up in SolidWorks 3-D, made some changes, then flattened the new 3-D model so I could cut and build it (in cardboard) for a trial fit. You can see some of the mark-ups below. ![]() ![]() ![]() A couple of more refinements and it will be ready to go to fabrication. Stay tuned. More to follow. justplainray Quote:
02-23-2010, 08:37 PM
#27 |
Fat guy on a little bike!
Oddometer: 341
Fun stuff. I just love these rebuild threads.
Subscribed. |
02-24-2010, 12:28 AM
#28 |
Oddometer: 374
Nice.... but its sure looking expensive!!
02-24-2010, 01:26 AM
#29 | ||
Oddometer: 15,144
You must ride on hollywood movie sets to find those rare cardboard rocks! It is looking good, even though I am jealous of your work space/garage. Quote:
DSI #694 Quote:
02-24-2010, 02:21 AM
#30 |
xendurist
Oddometer: 1,563
Ray,
Looks like you are going about this project in the right way, no shortcuts, very nice. Where did you find the head and base gaskets?
Transalps |
