Old 02-24-2010, 10:14 AM   #31
justplainray OP
ucancallmeray
Oddometer: 260
thanks...
for subscribing.
there's lots more to come.
justplainray
Originally Posted by Byrdman
Fun stuff. I just love these rebuild threads.
Subscribed.
justplainray is offline   Reply With Quote
Old 02-24-2010, 10:16 AM   #32
justplainray OP
ucancallmeray
Oddometer: 260
Oh...yeah...
but I have a wonderful wife, our policy is simple...
Don't Ask...Don't Tell.
justplainray
Originally Posted by wide
Nice.... but its sure looking expensive!!
Old 02-24-2010, 10:20 AM   #33
justplainray OP
ucancallmeray
Oddometer: 260
the base gaskets
are obsolete, but the originals are a metal stamping, so we cleaned them up and re-used them with "SukuziBond". Art the mechanic swears by this stuff.
The head gaskets are still available thru Honda, I order them from either HondaDirectOnline or RonsDiscountParts. They're about $10.00 each.
stay tuned,
justplainray
Originally Posted by mas335
Ray,
Looks like you are going about this project in the right way, no shortcuts, very nice. Where did you find the head and base gaskets?
Old 02-24-2010, 10:26 AM   #34
justplainray OP
ucancallmeray
Oddometer: 260
Thanks,
the garage is a real pleasure to have, after years of working in the driveway, I finally could afford to build a shop/garage. Measures 20 feet x 24 feet with a 12 foot overhead door and a 10 foot ceiling and it's heated. My wife (god bless her) thinks garages are for parking cars, she just can't understand that there are more important uses for a garage.
stay tuned,
justplainray
Originally Posted by 100mpg
You must ride on hollywood movie sets to find those rare cardboard rocks! It is looking good, even though I am jealous of your work space/garage.
Old 02-24-2010, 10:46 AM   #35
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
stay tuned,
justplainray
20x24...
Your lucky your wife thinks it is for parking cars, most wives think a garage is for storing JUNK for 20 years, then turning it into an apartment!
100mpg is offline   Reply With Quote
Old 02-24-2010, 11:40 AM   #36
Lear60man
Sleeping
Lear60man's Avatar
Oddometer: 720
Nice thread. FYI a standard RD4 skid plate bolts up with minimum modding. I started out with a really clean low mile TA for my TAAT. Keep up the pics!
Edit Signature Here
Lear60man is offline   Reply With Quote
Old 02-24-2010, 12:26 PM   #37
Hans Petter
Oddometer: 11
18 " rear wheel
What kind of spokes did you use to build the 18 " wheel ?
stock hub ?
Great build, btw !
Hans Petter is offline   Reply With Quote
Old 02-24-2010, 01:42 PM   #38
justplainray OP
ucancallmeray
Oddometer: 260
stock hubs..
rims, spokes and nipples came from Buchanans Spokes & Rim
http://www.buchananspokes.net/
It took a few phone calls to explain what we had in mind.
....Yes the bike is stock with 17 inch wheel, 36 spokes.
.....And I want to change to 18 inch wheel, 36 spokes.
.....Yes the rear hub is the original drum brake.
But in the end, they understood what we wanted.
Buchanans drilled the rim, supplied the spokes and nipples.
My local shop did the lacing and truing.
I really like the looks of the heavier gauge spokes too.
thanks for checking it out.
More to follow.
justplainray
stock hub ?
Great build, btw !
Old 02-24-2010, 01:44 PM   #39
justplainray OP
ucancallmeray
Oddometer: 260
yeah...but
I wouldn't have got to play "arts and crafts" with hot glue and cardboard. That was the best part.
justplainray
Old 02-25-2010, 01:24 PM   #40
Hans Petter
Oddometer: 11
Thanks !
I'll contact Buchanans about the spokes and rims.
Keep up the good work !
Old 02-25-2010, 08:44 PM   #41
showkey
Oddometer: 1,955
Oh...yeah...
justplainray
Glad someone is keeping the economy going
Nice work
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 02-25-2010, 09:03 PM   #42
Archangel007
Another Honda Rider!
Archangel007's Avatar
Oddometer: 104
Spokes
Subsribed
Obviously heavy-duty stainless steel spokes and nipples Ray???
Looking very good there!
Cheers,
Tricky
Archangel007 screwed with this post 02-25-2010 at 09:19 PM
Archangel007 is offline   Reply With Quote
Old 02-26-2010, 10:54 AM   #43
justplainray OP
ucancallmeray
Oddometer: 260
Spokes
Originally Posted by Archangel007
Subsribed
Cheers,
Tricky
Yes, the spokes are heavier duty than the originals, I think these are 9 gauge, the originals were thinner.
Note the brake rotor is bigger too. This an aftermarket rotor for a 650 Hawk GT (NT 650 '88 -'91) The caliper is original TA mounted on an adapter piece from MAP Engineering (thank you Jim Rowley, Colorado Springs, CO). Braided steel brake hose (e-bay). Tires Shinko SR244 (I like cheat tires).
Here's the original set-up for comparion.
Here's a shot of the frame and swingarm back from the sandblaster, with paint. It was too big for my blasting cabinet, so I had to send it out to Gary at American Dry Stripping, Milford, CT.
All the paint was applied with a 3/8" wide camel hair artist brush using POR-15 paint products, Caliper Paint to be exact (http://www.por15.com/8oz-CALIPER-PAINT/productinfo/CPB/). The exhaust pipe paint is a POR-15 product also, Black Velvet (http://www.por15.com/High-Temperatur...ts/products/8/)
More to come.
justplainray
justplainray screwed with this post 03-02-2010 at 06:32 PM
Old 03-02-2010, 04:09 PM   #44
justplainray OP
ucancallmeray
Oddometer: 260
Today class....
...we will learn how to design an auxiliary fuel tank.
You no doudt have noticed the cardboard box between the rear frame rails, in this earlier photo.
So here are the dirty details. That is a mock-up of this...
This is a 3.25 gallon fuel tank, designed it in SolidWorks '09, it will be made of .100" Aluminum (5052 H32), the fill neck is a purchased component (RCI #7036B) from Summit Racing that required modifications, it hangs in between the rear frame rails on two steel straps. One the left side there will be a bracket to mount the Hondal CDI pack. The tank will completely eliminate the stock air box, battery tray and inner fender liner. (the tank is the fender liner) Heres a few more photos of the mock-up in position.
Here I'm checking the tire-tank clearance at full suspension travel. The shock is .800" longer than stock, I make a new clevis with the addition length built-in. Note the shock spring is removed and the tire is moved all the way forward for this check. Everything looks good.
With the African Twin tank and this tank, fuel capacity is approximately 9 gallons (US). Air filter duties are being taken care of by the UNI air filter clamped onto the stock air plenum (red, visible is several photos).
But...what about the battery?
That is for another time.
Stay tuned.
justplainray
Old 03-02-2010, 06:01 PM   #45
BeeDub
Havagoowan
BeeDub's Avatar
Oddometer: 2,022
Ray, I'm lovin' your hard work and creativity. I don't know what kind of riding you're really planning on doing with this thing, but I want to caution you abut those UNI pod filters. I had one on my Husky for a few months, and really only did one dirty ride in that time. After that, I wanted to do some jetting and what not, and when I pulled the carburetor apart, there was a healthy amount of dirt in it. I had read posts about them before, but didn't believe that just because the foam wasn't encapsulated by something, it would allow dirt to pass. I doubt the "air box" itself is the reason, but these things do not keep desert dust out of the carb. Just warning you.
Keep up the good work!
BeeDub is offline   Reply With Quote
Times are GMT -7.   It's 07:14 PM.
