Old 04-24-2011, 09:38 AM   #121
jussaral
Oddometer: 25
Originally Posted by FATTKAW View Post
I just had my right speaker die and it the cable right before it goes 90 degrees into the unit. kind of suck since I babied it from day one after reading other reviews.
Has anyone's replacement broke yet??
Also the blueant site shows both mic styles out of stock! wonder if it's getting redesigned??
It happens to me 3 times in a row ... got a complete replacement kit then they only change the speaker set... Hope it won't happen a fourth time ...
jussaral is offline   Reply With Quote
Old 04-25-2011, 09:25 PM   #122
O'Ren
O'Ren's Avatar
Oddometer: 107
I bought 2 sets in September 2010. Mounted them on HJC helmets.
iPhone 4 are paired with them. No GPS as we use the iPhone apps.
My F4 is used daily, extensively, it's always on when I ride to/from work. On WE it's sometimes used 6-10h a day for longer rides. My pillion's F4 is mainly used over WEs.
Let's get rid of the bad stuff first:
After 4-5 months of daily extensive use, my right speaker started to fail. At first it was just a glitch, but it became more and more annoying. The only way to get the stereo sound back was by playing with the thick wire going from the F4 bluetooth piece to the speakers. At first fiddling with it would solve the problem, but as time passed, it became worse. The left speaker gave up on me as well.. I'd be lucky if I get mono sound.
I pulled out the whole set from my helmet, and checked that all the wires were not torn or folded or anything. They were in perfect condition from the outside. I made sure when I installed to not fold or press on any wire and the wires were running along the helmet so the pads or the holding/carrying of the helmet wouldn't impact them.
After a few days of getting frustrated, I contacted the seller who directed me to BlueAnt. They've responded fairly quickly and are now processing my RMA.
My second set, used by y pillion, is working flawlessly.
The other bit about the F4 that was a negative for me, was the issue with the intercom shutting down the iPhone's music when a communication was started while music was playing. But I understand that this was fixed with the latest iPhone firmware, I'll read back the pages here to learn more.
The good stuff :
- Excellent audio quality: It's so good I didn't know what to do when the F4 gave up on me, and I started reading about mainly the SenaMH10 which look like a good contender. I still feel after reading reviews that the F4 audio quality isn't matched by other similar products. I listen to music all the time when I ride and I've tried other intercoms and none has ever matched the F4. Sounds like I have my earplug headset on.. Absolutely perfect.
- Mic quality: let's put it this way, when i ride and pick up a call, people can't tell I'm on the bike. They hear me loud and clear and the mic is very easy to position and use. The arm is flexible without being too loose, and the boom is just the right size to not bother you when you ride and don;t use it.
- Mounting and unmounting: Easy as pie to fix, and very durable. Exactly as easy as you'd ideally want it to be. I use the adhesive mount, and I've been riding on the highway, through torrential rains and it's still as sturdy as ever. The speakers are very slim so it's a breeze to position them behind the helmet padding and you don;t feel them at all.
- Battery life:
this is just amazing. I use it with the iphone, and the intercom and it lasts me at least 8-9h. sometimes 10-11 if I don't use the intercom much. I don't even turning it off on ride breaks because I know the battery will last me until the day is over. The charging is easy and if you have two sets, you get two chargers that can charge a total of 4 sets. You can put one at work and one at home and never run out of battery ! When the battery is starting to reach its limit, you'll hear a series of beeps. With the iPhone, this usually means i still get to listen to 20-30min of music before the F4 shuts down. You can't charge the F4 on the bike with the accessories given, but maybe someone managed to tweak the charger to hook it up to a USB plug or to their bike's battery ?
- Waterproof: We've been riding in heavy rain and the set didn't get damaged.
That's my short review after 6 months of use. I know it can be very painful to decide on which set to get, for me what sold it about the F4 was the audio quality and the waterproofness. I hope the above can help others make their choice :)
O'Ren is offline   Reply With Quote
Old 04-26-2011, 12:51 PM   #123
bmwhd
God Bless Texas
bmwhd's Avatar
Oddometer: 1,469
My experience matches the previous post almost exactly. So far my replacement unit is spot on.
They original (and perhaps current) design does have a weak spot in the wiring but other than that, these things rock.
Also - I too have given up my old Garmin 2620 in favor of my iPhone 4 with Navigon app. My iPhone is Jailbroken and I use a custom app called VoiceActivator that lets you define custom voice commands. I can do everything I need without touching (or even looking at) the iPhone via the F4. If you've used an iPhone's voice commands, you know how finicky it can be but it has no trouble understanding me even at speed.
Todd R.
'78 R80/7
'06 FJR1300A
"Gentlemen, gentlemen, be of good cheer, for they are out there and we are in here!" - Robert Culp, attributed by Hugh Hefner as the official slogan of the Playboy Mansion
bmwhd is offline   Reply With Quote
Old 04-28-2011, 05:10 AM   #124
O'Ren
O'Ren's Avatar
Oddometer: 107
I'm gonna have a look at voiceactivation through the iPhone, the original voice control function is a pain to get the damn thing to pull the right out of my address book. I say "Kate" and the phone dials "Ann" - go figure..)
What do you mean by the design being a weakness to the wiring ? Did BlueAnt change the F4 design recently ?
And for the replacement, they're not replacing my bluetooth piece, just the Boom Mic Kit ( = mic, wire to bluetooth piece, wire to speakers, speakers). Was that the case for you too ?
Old 04-28-2011, 06:10 AM   #125
Offcamber
Offcamber's Avatar
Oddometer: 1,121
I have had the F4 for about 10 months and they are shipping me my second replacement headset....right ear then left cut out....its a serious design flaw the conection is way to weak.
Besides that its a good unit.
Offcamber is online now   Reply With Quote
Old 05-10-2011, 09:33 PM   #126
O'Ren
O'Ren's Avatar
Oddometer: 107
BlueAnt is very slow at processing replacements
Following up on the above post, I am still waiting for my replacement part to be shipped. After 10 days of waiting, I emailed BlueAnt again to see what was the hold up.. They told me they are out of stock and are waiting for replacement parts to arrive at their warehouse.. They predicted they would arrive last week but still no news from them.
It's been now a month since I first wrote to their customer service department. I don't know if they shipped the unit nor if they received the spare part. I'm disappointed by the lack of communication and I now fear the replacement unit will fail as well, seeing the feedback on this thread from people who changed speakers 2,3 or 5 times
Should I switch to the Sena ?
Old 05-18-2011, 12:35 PM   #127
bmwhd
God Bless Texas
bmwhd's Avatar
Oddometer: 1,469
Did you buy direct from BlueAnt? I went through an online retailer that was much more responsive on the service request.
Todd R.
'78 R80/7
'06 FJR1300A
Old 05-20-2011, 05:00 PM   #128
AKBMW
AKBMW's Avatar
Oddometer: 713
Send a message via MSN to AKBMW
Earbuds
didnt read the whole post.. Can you rub earbuds with the F4?
05 1200GS SOLD :(
09 R1200 ADV :)
2013 Prudhoe to Key West T2T (tip2tail)
AKBMW is offline   Reply With Quote
Old 06-13-2011, 07:35 AM   #129
Valentino Magoo
Like a speeding slug
Valentino Magoo's Avatar
Oddometer: 1,728
Did you finally get a replacement? Their web site now shows "out of stock" for their boom-mic kits, which is the source of the shorting-out problem. I have had my 2 blueants since they first came out in the US (Nov 2009). The units are still very loud and the battery life on both of my units is spectactular (not only on long trips, but I go months between charges for my short daily commute to work).
I have had FOUR replacements of the boom mic kits, and the short is always in the wire where it comes out of the unit. I have yet to rip one of the old ones apart, but I think I am about there. It is sad such a great product has a relatively simple-to-fix but horrible flaw.
12 WR 250R
05 Burgman 650
00 HD softtail
Valentino Magoo is offline   Reply With Quote
Old 07-02-2011, 01:28 PM   #130
Pcfly
Dude?! Seriously??
Pcfly's Avatar
Oddometer: 904
STAY AWAY FROM THE F4
I've used it for a couple long trips and when it works, I'm convinced it's the BEST unit............but they go bad and it blows having to deal with sending it in! I'm on my second set in under two years and BlueAnt is great at fixing them, they send me new units without charge.......but they just keep breaking!! I've had two broken speakers and one bad boom mic.
Anyone know of another good comm unit??
2008 BMW 1200GS The Blue Rhino
2011 Husqvarna TE-630 The Red Raptor
2012 Yamaha 50th Anniversary Badass-Sounding R1
Pcfly is offline   Reply With Quote
Old 09-18-2011, 10:00 AM   #131
greybeard146
greybeard146's Avatar
Oddometer: 303
Puke Moi Auci...
Just returned from a trip where me and a buddy ran a set that lasted all of 24hrs (acutal on-road use, approx. 6hrs) before the one unit's microphone died...got that replaced by a dealer near where we happened to be who replaced the whole microphone unit...off we go, and lo and behold, another 6hrs on-road riding later - with only one speaker functioning in my headset, plug 'em in to recharge overnight, and next morning, the other main unit (mine) is totally kaput!
Whilst they were functioning, they were great! But...mabye they'll get obvious inherent weaknesses and malfunctions fixed for the future Interphone 5... I hope so, 'cause a potentially great product is being damaged by the current lot - and I am a firm believer in bike-to-bike comms; they saved our bacon on more than one occasion. DG
ATGATT - protect / prevent / preserve!
Topbox Tours
CB750 F2w / R1100RT / F650 / DL1000 / Bandit 600 / CB200
greybeard146 is offline   Reply With Quote
Old 09-23-2011, 01:53 PM   #132
JetSpeed
ATAC Kfir Hack
JetSpeed's Avatar
Oddometer: 450
I had the original BlueAnt Interphone device and it worked well with a Motorola Razr for a few years, so with a good experience under my belt I purchased a pair of the F4 devices for me and the miss, no problem with the install in a Shoei Hornet DS and RF12, my wife's unit works brilliantly with her iPhone4.
I have an issue with my F4 paired to my old Motorola Droid X and also with my new Droid Bionic, the problem is that I cannot answer or make calls, when in phone mode the sound comes thru the phone and not my headset, the system plays music just fine though.
If I could get this sorted out I'd be very happy with this product.
Good Judgment Comes From Experience, Experience Comes From Bad Judgment.
JetSpeed is offline   Reply With Quote
Old 11-22-2011, 01:23 PM   #133
owrstrich OP
F O T G
Oddometer: 163
interphone f4 update...
if you have defective boom mic kits you may wanna post it up at blueants facebook page...
its what finally gotts this guy some action on getting warranty boom mics...
j o
Grandiose Delusionary commented on his own post on BlueAnt Wireless's wall.
greetings blueant... i purchased 3 blueant interphone f4 motorcycle intercoms... these are the best moto intercoms available... they work perfectly... however i have not been able to use them for 6 months because the boom mic speaker kits have failed... i even bought 2 extra boom mic speaker kits for other helmets... all have failed... no audio to the right speakers and diminished audio to the left speakers... which makes the system inoperable... i have case numbers... i call tech support... they say im a priority... but they cant tell me when my warranty replacements will arrive... i have $700 into this system and i ave not been able to use it since may.... will a blueant representative please help me get the warranty replacements i am due so i can once again use this fine system...
· · 5 hours ago
    • BlueAnt Wireless Hi there - I am sorry you had this issue. We have been working hard trying to get replacement parts for this product and we have just gotten word that they should be inhouse this week. If you respond with your case numbers I can make sure yours get sent out by the end of the week. Thanks - Jeanette - BlueAnt Custoemr Service ManagerNovember 8 at 1:29pm ·
    • Grandiose Delusionary greetings jeanette... here you go... i am due 7 warranty boom mic kits total... the case numbers are: 00020996, 00021795, 00023673, 00048720, 00060543, 00060542 & 00060545... please advise... thank you...November 8 at 6:25pm ·
    • BlueAnt Wireless Thanks!! I will make sure these get processed as soon as we get them in this week..November 9 at 8:30am ·
    • Grandiose Delusionary greetings jeanette... update please... did you get the boom mic kits shipped to me...5 hours ago ·
owrstrich screwed with this post 11-22-2011 at 07:23 PM
owrstrich is offline   Reply With Quote
Old 12-10-2011, 07:19 PM   #134
owrstrich OP
F O T G
Oddometer: 163
they sent me 6 boom mic speaker kits so im back to having sound from both left and right speakers instead of just left...
yeeeeeeeeeeeeeeehaaaaaaaaaaaaaaaaaaa...
j o
Old 12-12-2011, 07:03 PM   #135
chief_lee_visceral
Oddometer: 170
Okay I have been using F4 paired with just the iPhone iOS 5.01 for a months. Works great aside from the wiring problem everyone else has had.
I just got a Zumo 665. I cannot pair the phone to the F4 while the Zumo is paired as well so that I can play music on the phone instead of from the Zumo? I can understand why this might be so but wondered if it is an option.
2008 Yamaha WR250R
2011 Husaberg FE570S
1992 R100GS
chief_lee_visceral screwed with this post 12-12-2011 at 07:17 PM
chief_lee_visceral is offline   Reply With Quote
Times are GMT -7.   It's 04:47 PM.
