Old 05-13-2012, 08:31 PM   #1006
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Drain the float bowl again, make sure there is no water in there at all.
Shaking it should not make it miss.
With it running I would spray some carb cleaner all over it the carb, and boots and make for certain its not sucking air.
Do you still have the stock airbox on it? Without it might be extremely lean.
Check the float/needle that it is slid into the slot on the float and the float is not just sitting on it. These things will never run right if its not slid into the float. This not only keeps it from sticking, it keeps the needle action smooth.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 05-13-2012, 09:10 PM   #1007
Futura
Futura's Avatar
Oddometer: 128
After I adjusted the fuel height today, it idles strong and does not miss when I shake the bike.
i'll spray some carb cleaner and see if I can find a leak.
Stock airbox still.
The needle is in the slot on the float. But I'd like to check it again to make sure it's not binding or handing up at all.
Futura is offline   Reply With Quote
Old 05-14-2012, 07:15 AM   #1008
Larry Ferguson
Oddometer: 88
Stock airbox still.
Did you bypass the kickstand safety switch? It's the first thing I would check with the symptoms you describe.
I also like Sanford and Son but, since I am not a junk dealer in 1970's Watts, I find it hard to criticize his methods.
'01 Connie
'83 XT 550
'78 XL 350
'73 XL 250
'72 XL 250 (Needs "assembly")
Larry Ferguson is offline   Reply With Quote
Old 05-14-2012, 04:24 PM   #1009
ForesterXTguy
Oddometer: 5
Hey guys I just picked up a 550 off Craigslist. I'll post up some pics in a bit. Quick question... How and what attaches the Yamaha bag onto the back of the bike. Thanks
ForesterXTguy is offline   Reply With Quote
Old 05-14-2012, 06:29 PM   #1010
G600
Oddometer: 458
Congrats on the new bike. Three 6mm bolts keep the yamaha bag put.
G600 is offline   Reply With Quote
Old 05-14-2012, 08:20 PM   #1011
ForesterXTguy
Oddometer: 5
Thanks... I found a bag thats reproduced in New Zealand. But nothing else comes with the bag. Im guessing that there is a plate of some sort that holds the bag down along with the three bolts. Now need to find that. Just got done changing the oil and filter and damn near filled my 6 quart oil pan .. I can't believe someone could put that much oil in a motorcycle.
Old 05-14-2012, 08:22 PM   #1012
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Not hard to put 6 qts in the XT.
Most people don't know to run it then CHECK the oil. Not when its cold.
As to the tail bag there is a plastic tray that goes inside the bag.
I have no idea what tools was ever in mine. So thats where my help stops.
Old 05-15-2012, 07:30 AM   #1013
Futura
Futura's Avatar
Oddometer: 128
The previous owner bypassed the kickstand safety switch. I'll check that out to make sure it's not messing up. Thanks the the idea.
Old 05-16-2012, 07:23 PM   #1014
Futura
Futura's Avatar
Oddometer: 128
I could not find a leak any where. I sprayed carb and boots with carb cleaner, then brake fluid and found nothing. I took off the boot clamps, and loosened up the airbox to reposition the carb to make sure it was totally engaged and in line with all the boots. Then sprayed it again to confirm it was all ship shape.
Idles and revs fine when it's on the stand.
Took it out for a ride and before I got to the end of the driveway it started to hesitate and sputter.
ARRRRRRRRGGGGH So I came up for a beer
Any ideas?
Old 05-17-2012, 05:40 PM   #1015
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
almost sounds like its starving for fuel then.
On the stand requires less fuel than under load.
Soon as you load it its not getting enough.
Have you degunked the petcock?
Assuming your still running the stock airbox with a filter in too.
If your running pod filters etc your going to have to fatten the jetting cause your getting more air.
I got a secondary issue right now, at WOT it pops and snorts, but I'm running a free flowing exhaust too and I thinks the cause I need to richen the main on the secondary.
Old 05-18-2012, 07:36 AM   #1016
Futura
Futura's Avatar
Oddometer: 128
Thanks for the idea- I will check out and degunk the petcock.
Yup, stock airbox and stock filter.
I'm going to take off the carb again this weekend and clean it yet again. I'll also make sure the floats are not hanging up, and the needle is seated properly in the tang.
cheers
Old 05-18-2012, 05:57 PM   #1017
ForesterXTguy
Oddometer: 5
Ok I now have the tray for the bag. I have no idea how to connect it to the bike. Where do the bolts go? How does it fasten to the fender? I feel I'm missing something simple. Like a bracket???
Old 05-18-2012, 06:14 PM   #1018
Globecruiser
Oddometer: 19
You should have three tabs/nuts welded to the end of the frame. I would have attached apic if I knew how...
Globecruiser is offline   Reply With Quote
Old 05-18-2012, 06:52 PM   #1019
ForesterXTguy
Oddometer: 5
Thanks for the reply. There are no tabs at all...i can see where the tabs were. They were cut off. I guess I need to make a bracket that uses the turn signal mounts
ForesterXTguy screwed with this post 05-20-2012 at 07:18 AM
Old 05-21-2012, 12:02 PM   #1020
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
What a Saturday.
Don't count out these old machines, with a few mods they're as capable a woods machine as anything built new today.
It will go in and back out again.
Of course mine is so far removed from what Yamaha envisioned of it that it might actually be apples to oranges.
http://www.advrider.com/forums/showp...8&postcount=21
It was basically 9 miles of Heck for some.
I rode 180 miles Friday to NW Arkansas for the SLAP get together, I didn't get the oldest bike award that went to a fellow on the XT500.
Saturday mileage totals put me around 40 miles and spending 3 or 4 hours on 9 miles of it in the report.
I had actually thought about retiring the old bike.
I have a KTM LC4 640 too, but it had proven less than reliable and its engine is in pieces on the workbench and I'm seriously thinking that its going to leave one piece at time when I get ready.
Overall I out around 370 miles on the bike over the weekend without much flaw. I'm fighting a WOT burble still and it actually straightened out for a bit on the way home and the thing reached the 80mph mark. Pretty good chore since I'm not a light weight by any means.
Times are GMT -7.   It's 05:51 PM.
