Old 04-21-2013, 06:21 AM   #1381
DJCW
Oddometer: 2
Thumb nice combination
Landrover and yamahe xt 550. Life doesn't get better than that.
Best bike ever!.
DJCW is offline   Reply With Quote
Old 04-22-2013, 07:52 PM   #1382
sharkeysmachines
HusqvaYama XTC 550
sharkeysmachines's Avatar
Oddometer: 81
Still at it...
I have done a lot of adaptations lately. Reused the old front fender as an inner rear fender, mounted CDI a Regulator on it. Took a long time to find a K&N that had the angel I needed to not hit the seat bottom. Covered the seat in the Husqvarna Blue of that year (1983). Received my white plastic tank from Clarke, got my new front fender, handle bars and turn signals (eBay is wonderful!). Finished my Chain guides - what a magic in imagination that was. Then I wrapped my exhaust - from muffler connection on, and found a BAD measurement! I have to do that all over again (right rear shock rubbed). But, I just got lucky - I think. I found a site that is like eBay for China, or something (Ali Express). They had a Yashimura muffler set-up for $55 bucks! Yes, they messed up, and I took total advantage of it! photo WithWhiteTank_zps88384cbe.jpg
When in Doubt - Gas it!
Ain't No Ways like Slide-Ways
Imagination Counts for 2/3 your Grade.
sharkeysmachines is offline   Reply With Quote
Old 04-23-2013, 12:33 PM   #1383
Hungry Valley
Oddometer: 16
Originally Posted by Hungry Valley View Post
forks and shock came off an 82 IT 465,swingarm off a 79 YZ400, upper shock mount was cut out of the frame and repositioned.Acerbis headlight and tank,tires are kenda.Motor is stock except for supertrapp slip on and a K&N filter.
https://lh5.googleusercontent.com/-I...of+May08_1.tif
Hungry Valley screwed with this post 04-24-2013 at 01:52 AM
Hungry Valley is offline   Reply With Quote
Old 04-24-2013, 09:32 AM   #1384
Sidecar Jockey
Sidecar Jockey's Avatar
Oddometer: 632
Hi guys, I'm cleaning out the garage and have some xt550 parts I want to get rid of. I bought these thinking that they would make good spares for my xt500's... but it turns out they wont fit a 500 (Obviously I knew the shock wouldnt work, but I got all the parts together. If you have a 1980 or newer xt500 the forks will work.). All of it came off of a 1982 xt550 with 5,000 miles.
Original paint red tank with decals with a few very minor nicks (you can see all the nicks in the photo).
Complete front end.
Rear wheel with good tire, good wheel bearings, good brake shoes, and sprocket.
Stock rear shock.
I'm located in Maryland. These parts are pretty big and/or heavy so shipping might not be cost effective... but if its worth it to you, it ok with me.
Here is a link to my Craigslist ad so you can see photos:
http://frederick.craigslist.org/mcy/3763339905.html
Sidecar Jockey screwed with this post 04-24-2013 at 09:38 AM
Sidecar Jockey is offline   Reply With Quote
Old 04-25-2013, 08:09 PM   #1385
Rahjah
Oddometer: 12
Has anyone successfully sealed the clutch and stator covers on a 550 using rtv gasket maker and no actual paper gasket?
Rahjah is offline   Reply With Quote
Old 04-27-2013, 05:40 PM   #1386
sharkeysmachines
HusqvaYama XTC 550
Oddometer: 81
NO, and it's not worth the cheat to attempt. The bike I purchased for my project had so much sealant used that it looked horrible, still leaked and nearly clogged the frame filter. However, a "SANO" cheat is much cleaner, and works as well as factory - AKA SANO. Trace your cover onto gasket paper (at any auto parts store) or a manila folder, cut it out, and use a paper hole puncher for the bolt holes. Then apply a "THIN" coat of your gasket maker on each side. If there is a gasket, then it was not a machined matched case - it NEEDS a gasket. I prefer gasket assistance by Yamabond 4 = gray, Yamabond 5 = black, also available from Honda and Subaru under different names. The gray is for machined cases, and if used with a gasket, a guarantee no - never leak. But good luck removing the gasket if you ever need to go back in that area again. The black is a snotty type for use with a gasket, and in many cases, the gasket can be re-used. Hope it helps
Old 04-28-2013, 06:17 AM   #1387
Rahjah
Oddometer: 12
That's great info, thank you! I think I will give the gasket material a shot (I work for an auto parts retailer) tomorrow. I have to also get a kickstand installed.
Old 05-01-2013, 10:18 AM   #1388
blackthumper
blackthumper's Avatar
Oddometer: 4
O year!
Saved this baby from the junkyard, stainles spokes,paint the frame and engine, put a 600 engine in it, she is gonna be sweet!!
blackthumper is offline   Reply With Quote
Old 05-01-2013, 02:32 PM   #1389
G600
Oddometer: 462
Nice... and you have the EURO bash plate. Not bad at all...
G600 is offline   Reply With Quote
Old 05-01-2013, 06:24 PM   #1390
Garrettr77
Oddometer: 4
Originally Posted by sharkeysmachines View Post
They sure do! Make me ponder even more
What kind of seat is on that bike?
Garrettr77 is offline   Reply With Quote
Old 05-01-2013, 07:02 PM   #1391
papawhellie
Oddometer: 66
Complete front end.
Stock rear shock.
Interested in the parts. Definitly the tank and rear wheel. Would take the package deal but the shipping scares me. If you can figure how to package the tank and wheel and are close to fed ex or ups get me an estimate to 30293.
papawhellie is offline   Reply With Quote
Old 05-01-2013, 07:51 PM   #1392
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,253
Looks like a seat off a TT600 bike? Or a XT 600?? Hard to say. The cover is off ebay. Big ED XT550 !!
BIG ED XT FAN is offline   Reply With Quote
Old 05-01-2013, 08:51 PM   #1393
Garrettr77
Oddometer: 4
Well like every one of the bikes in the Greek 30 year pictures had that seat on it. It might be a dt seat?
Old 05-01-2013, 09:39 PM   #1394
Garrettr77
Oddometer: 4
Think I might've found something on that seat. http://www.moto-k.gr/en/index.php/ya...category_id=11
Old 05-02-2013, 03:17 AM   #1395
Hungry Valley
Oddometer: 16
Originally Posted by ThumperStorm View Post
A question for those of you that have ridden your bikes in the mountains. Did you need to, or feel the need to, re-jet your carbs? I am planning (dreaming) of some rides this summer and am wondering how an XT550 would do in the mountains of Colorado.
I do most of my riding from 3000 to 8000 ft and never felt the need to mess with jetting.Some of the rides in Colorado get up to 12000 tho so it might be good to go prepared.
Times are GMT -7.   It's 05:25 AM.
