02-27-2010, 08:15 PM
#136 |
ADV Rider
Fake Tilt Shift :
03 Honda XR250R |
02-27-2010, 08:17 PM
#137 | |
Beastly Photographer
Oddometer: 26,523
Motorcycles save lives "It's the game of life. Do I win or do I lose? One day they're gonna shut the game down. I gotta have as much fun and go around the board as many times as I can before it's my turn to leave." |
02-27-2010, 08:19 PM
#138 |
ADV Rider
Alittle better :
03 Honda XR250R |
02-27-2010, 08:21 PM
#139 | |
Oddometer: 26,523
02-27-2010, 08:31 PM
#140 |
ADV Rider
Yeah I noticed the line. I need to get a better city shot with less trees.
03 Honda XR250R |
02-27-2010, 09:50 PM
#141 |
kinda slow
Oddometer: 20,417
Did I make it better or worse?
![]() ![]() ![]() I think the clouds may have gotten over cooked.......
02-27-2010, 11:05 PM
#142 |
ADV Rider
I have a weird bug picture taking fetish :
03 Honda XR250R |
02-28-2010, 10:05 AM
#143 | |
Oddometer: 26,523
:![]() ![]() Just I recommend having a longer lens than me.....and if someone is taking a picture of you to shave and not have bed head ![]()
02-28-2010, 10:27 AM
#144 | |
Oddometer: 26,523
02-28-2010, 10:29 AM
#145 | |
Oddometer: 26,523
02-28-2010, 11:41 AM
#146 | |
kinda slow
Oddometer: 20,417
White balance then duplicate. Desaturate top layer then invert. Set to "soft light" @ 50% then duplicate and set new to 75% Duplicate base layer and move to top. Adjust black level to between 50 and 100 (don't remember exact #) set layer to darken @ somewhere between 30-50% When exposure looks OK merge layers. Made 2 duplicate layers set top layer to "dodge" @ about 10% and middle to "burn" @ about 25% opacity. On base layer adjust saturation then levels/white balance again (usually about 7 & 245) Then added some unsharp mask and flattened. I think I overcooked the "dodge and burn" and still left it a little under exposed......I'm just learning by trial and error, mostly error. Thanks for your help....I'll gladly accept any criticism you care to share.
02-28-2010, 12:41 PM
#147 | |
Oddometer: 26,523
I would try other methods than soft light, right now the colors seem more flat/pastel like. The image itself is underexposed which is going to make processing for an "ideal image" more difficult.
02-28-2010, 05:13 PM
#148 |
Hold Fast
My first dabble with a DSLR. Entry level lens with a lot of PP. I have upgraded the glass and hope to get better.
1986 R80RT 2000 Land Cruiser "The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over." Hunter S. Thompson |
02-28-2010, 05:32 PM
#149 | |
kinda slow
Oddometer: 20,417
![]() All right....I tried to hack that same pic again, in spite of it's limited potential. This time I just tried to set the black and white points (not sure if I know what I'm doing though) then just played with the levels and curves ever so slightly. Not sure if what I did next was good or not but I added just a touch of saturation and unsharp mask......
02-28-2010, 06:05 PM
#150 | |
Oddometer: 26,523
For this type of shooting there are a few things you want to do. First they are all almost dead center, put them off to either side to emphasize where they are going/have been. Second, pan with the bike. You want to do the lowest shutter speed possible where the bike is still in focus and the background gets blurred. ![]() Third and well forth, set your camera for continuous shooting even at 3FPS hold it for another frame....once you get in the rhythm you can keep the bike in the right spot and just hold down the shutter release. And the other part since you are using a base level DSLR pick an AF point and before the bike gets to where you want to shoot line it up and follow the bike there, have it set on continuous focus and then the focus has time for a initial lock on and you can keep the bead. I did a few with my E-420 and 40-150 lens so you should be fine just practice. (The above shot is with the D700 and a 75-300 which is actually a pretty cheap lens, I'll try and find the E-420 shot.)
| Thread Tools | |
