Thread Tools Rating: Thread Rating: 366 votes, 4.99 average. Display Modes
Old 01-13-2013, 06:16 PM   #1456
longtallsally
Yeah I'm a chick
longtallsally's Avatar
Oddometer: 4,434
Originally Posted by dwayne View Post
I also assumed that you Jeep is a automatic, the factory derates the GCVWR to less that 6000 lbs for a standard (if you have a standard).. I also just noticed your winch, and that along with any other add ons need to be factored into your weight calculations. Also consider a front mounted winch will amplify the effects of not enough tongue weight.
Bottom line I ain't gonna do it with this vehicle as 1) I have a stick on principle, and 2) you are correct in that there is about 300 lbs of armor and the big nasty winch.
The thing that is very surprising is that with the stick that it is 2100 lbs less for GCVWR. Might I ask your source? I was always under the impression that a stick was invariably stronger than a slush box- especially in the case of towing.
[quote=Insert witty comment here]
longtallsally is offline   Reply With Quote
Old 01-13-2013, 06:58 PM   #1457
OaklandStrom
Oddometer: 1,612
I bought a used F150, and after I bought it, double checked the towing capacity. With an auto it's 8,000 pounds, but with a manual trans, v6 and the rear end ratio I have (really tall gearing), it's about 2,500. Oops.
Fortunately, I don't tow much any more, and I sold my 3/4 ton Dodge/Cummins and got an F150. It was still a bit surprising that I supposedly can't tow my 14' tandem axle box trailer *empty*.
I assume the clutch is the weak link in the towing capacity.
OaklandStrom is offline   Reply With Quote
Old 01-13-2013, 07:09 PM   #1458
GP640
GP640's Avatar
Oddometer: 3,351
Manuals used to be stronger in trucks but in my experience, any manual in a Jeep is no better
than an auto. I've had tranny problems in a newer Jeep and I've had friends with troubles and it
didn't matter if it was manual or auto.
If I remember correctly, my 09 Rubicon unlimited 6 speed had the same trailer specs as the auto.
Towing max load or close to it with a Jeep is not what I'd call a confidence inspiring event.
GP640 is offline   Reply With Quote
Old 01-13-2013, 07:55 PM   #1459
SgtDuster
SgtDuster's Avatar
Oddometer: 3,315
An automatic trans usually have a better towing capacity due to the torque converter.
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster is offline   Reply With Quote
Old 01-14-2013, 02:36 PM   #1460
AtlantaViking
AtlantaViking's Avatar
Oddometer: 955
Originally Posted by EvilClown View Post
This one of Mr. Cob's has always been an inspriation to me.
Bought the same carrier. May eventually move it to the front of my tow rig.
I really like the concept of a front mount carrier EXCEPT for one little thing...how do you drive at night with one? I use a versahaul behind the truck, and it has spots to mount aux lights which I connect up to the trailer harness. But these front mount rigs look like a real problem if you get caught at night, heck even during the day your turn signals are mostly blocked... Do you just drive only during the day with a rig like this?
I'm here to chew bubblegum and kick ass....and I'm all out of bubble gum
06 Suzi DL1K
99 Suzi DR350SE
AtlantaViking is offline   Reply With Quote
Old 01-14-2013, 04:06 PM   #1461
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 694
This is why most newer vehicle with a manual trans have a lower tow capacity. Generally they also have a much higher gear ratio in the axles.
I was a pretty firm believer that a manual transmission is much stronger then a auto. However I have learned that it greatly depends on the vehicle.
My 99 cherokee has 247k on it now. And I have beat the living shit out of it, towing well beyond the rated capacity for thousands of miles. I'm still on the original transmission and it still shifts like new. By far the best vehicle I have ever owned.
Oh and my little camper trailer
IMG_7302 by boardrider247, on Flickr
Life is a waste of time, Surfing is a great way to waste it
boardrider247 is online now   Reply With Quote
Old 01-14-2013, 05:03 PM   #1462
tonymorr
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,504
That's because the 99 still has a Aisin-Warner AW-4. That thing is tough. You have one of the last good Jeeps.
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 01-14-2013, 07:33 PM   #1463
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,528
I downloaded the owners manual for a 2012 from the chrysler website.
I believe it's because the drive-line is more likely to be shock loaded. Higher rated autos is a very common phenomena in newer trucks (including my '98 dodge).
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 01-15-2013, 01:48 PM   #1464
drm
drm's Avatar
Oddometer: 454
+1
I had a 99 and flogged it as well. It had 287k when I sold it. No major service other than front wheel bearings.
I hope my outback treats me as well.
drm is offline   Reply With Quote
Old 01-15-2013, 01:51 PM   #1465
drm
drm's Avatar
Oddometer: 454
Oh and my little trailer
What kind of tent and trailer? Details please :)
Old 01-15-2013, 02:34 PM   #1466
hppyfngy
not dead yet
hppyfngy's Avatar
Oddometer: 4,127
Every time I see one of those rigs I think of how windy it is in some places I camp...
Would you feel safe in that in 30-40 mph gusts?
Some say I'm apathetic, but I don't care. - Randy
'13 KLR 650 For Sale!
'07 KLX250s
hppyfngy is offline   Reply With Quote
Old 01-15-2013, 03:03 PM   #1467
PTC
Oddometer: 268
Originally Posted by drm View Post
+1
cherokee "sports" with the 4liter have the aw unit. non sports have the a500/42/44re/h
there were no aw units behind the v8s.
and the outback is a very good trans. youll need headgaskets or pistons before a tranny! jk
off topic, sorry
PTC is online now   Reply With Quote
Old 01-15-2013, 04:20 PM   #1468
Tech51
Oddometer: 147
Hell every time I see one I think crap I'd have to sleep on the ground after a hard night of camp fire drinking...
Tech51 is offline   Reply With Quote
Old 01-15-2013, 05:32 PM   #1469
boardrider247
Weekend Anarchist
Oddometer: 694
It's a standard chinese roof top tent, available from several vendors. I think mine is "roof top tent" brand. The trailer is a single place aluminum snowmobile trailer that I built a custom aluminum rack for to hold surfboards and the tent. It has so far worked out very well for me.
Honestly I'm not sure. The tent itself is far more sturdy then any standard ground tent I have slept it. We weathered tornado conditions in it when it was on top of my pickup truck with a rack.
With the amount of weight I had down low on the trailer I don't think it would be a problem. But I can't say for sure.
And so far I have always been able to make it back up in there no matter how much
Old 01-15-2013, 05:55 PM   #1470
pvangel
Team AARP
Oddometer: 2,556
I have one on my cargo trailer, easy to get in and out of. Mine stood up to high winds and rain without a drop in it even though I left the "windows" open. Mines a Tepui Roof top tent.
pvangel is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 09:35 AM.
