Old 04-21-2010, 10:41 PM   #121
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,727
Just spent some quality time, about 10 hours all up, in the garage getting my '80 XS11 running.
I bought a battery around 2 weeks ago and did the usual -"well, it was running last time" - fresh petrol and hit the starter. Sort of wanted to run but no.
Off with the carbs. so THAT'S what the turps smell is! A bad cas of Carbie Horrobullis Cloggii
Thought a quick scrub out with a bit of carby cleaner might do the trick.
Two cylinders. hmmm. check the coils. One cylinder for each coil is running, and one not. Just confirm spark. Yep. Carbs off again.
Bought some better quality carb cleaner (Nulon) - this stuff works fantastic!
Especially on your skin and lungs.
Full strip down, separate the carbs, impact driver on some screws that just wont budge - that's an interesting feeling - whacking the shit out of your carbs with a hammer. How hard can you hit before the carb body breaks!
well, as hard as I hit it anyway 'cause I eventually got them all to pieces.
Halfway through and I disover a very small spring on the bench. Where did that come from. back to the manual. So I've got the two springs but not the two locator balls for the choke mechanism. Deal with that later.
Re-position the needle clip and wonder why the main jet is 125.5, when the book reckons 135.5, or something similar.
All cleaned up. Determined that one carb had the idle fuel circuit blocked and the other had the pilot jet blocked.
Cannibalized a spare set of carbs from a wreck I picked up a few years back. Two 1mm steel balls and one pilot jet. And even a couple of phillips head screws to replace the one's that I chewed out with some multi-grips (they weren't gonna budge otherwise)
Set the float heights. Easy peezey!
Wack em back in. Bit of spray lube helps to get the inlet tubes in the right spot, screw, screw, screw, screw.
Fill the carbs and away she goes. 4 cylinders, sweet as. They'll need a balance and I may even give that a go myself.
Bleed the rear brake - piston kit installed last week & that came up reasonable almost straight away. Amazing.
It's all coming together. Add a Tkat fork brace shortly. Then get the paint restored.
The only photo of it that I can find.
rayb Crash Dummy (no testing involved)
Old 04-22-2010, 04:56 AM   #122
aussie ttoad
T.T.O.A.D
aussie ttoad's Avatar
Oddometer: 129
Thumb
Good to see Greyghost still riding those great XS650's. His might not be stock, but they are a great classic bike with a bullet-proof engine. Keep those XS's alive Greyghost. If anyone else has an interest in the Yamaha XS650, there is plenty of good stuff on the XS650 Club of Australia web site (few offroad bikes too)
aussie ttoad is offline   Reply With Quote
Old 04-22-2010, 02:35 PM   #123
hunter_greyghost OP
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,538
Any readers of this thread heading to 'Autumn Leaf' this weekend?
I'll be there Fri - heading home Sat [work @ 1400!]
Catch up for a yarn
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 04-23-2010, 07:36 PM   #124
hunter_greyghost OP
Oddometer: 8,538
Heading home from 'Autumn Leaf', Wee Jasper Valley
hunter_greyghost screwed with this post 04-23-2010 at 07:41 PM
Old 04-30-2010, 05:25 AM   #125
hunter_greyghost OP
Oddometer: 8,538
Might wash it one day!
Henning's old R90 [1970?] @ 'Autumn Leaf'
Old 05-04-2010, 05:40 PM   #126
hunter_greyghost OP
Oddometer: 8,538
A couple of shots from the Jingellic ride, 1-2 May
Russell's 1980 XS1100 outfit
Old 05-05-2010, 04:51 AM   #127
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,373
They are such a great bike to ride worth the effort for sure.
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is online now   Reply With Quote
Old 05-05-2010, 04:54 AM   #128
davorallyfan
Commonist
Oddometer: 16,373
Re-incarnated
Terrafied
Old 05-05-2010, 06:41 PM   #129
GSnovice
Beer me up, Scotty!
GSnovice's Avatar
Oddometer: 1,631
Lions Road,SEQ, mid'80's
Fcuk, we were skinny in them days!
Harley Davidson - The best way to convert petrol to noise without the side effect of horsepower.
GSnovice is offline   Reply With Quote
Old 05-09-2010, 07:55 AM   #130
hunter_greyghost OP
Oddometer: 8,538
Alf's 'Voodo Child' @ 'Loaded Dog'
Old 05-12-2010, 03:03 PM   #131
hunter_greyghost OP
Oddometer: 8,538
Another from 'Loaded Dog' Won the slow race!
Old 05-15-2010, 04:12 AM   #132
hunter_greyghost OP
Oddometer: 8,538
Two old mates @ 'Loaded Dog'
These two have done a few kms together
Old 05-16-2010, 11:52 PM   #133
hunter_greyghost OP
Oddometer: 8,538
L5T Yamaha
I've just issued myself a challenge!
This is to be restored & on the road for 'Alpine' 2012
'Doctor' should be impressed! [so will I if I manage it!]
http://advrider.com/forums/showthread.php?t=579893
hunter_greyghost screwed with this post 05-17-2010 at 04:11 AM
Old 06-01-2010, 06:21 AM   #134
hunter_greyghost OP
Oddometer: 8,538
Thought I'd chuck this one on for to bump things along
Old 06-04-2010, 03:32 AM   #135
MelbXS
Oddometer: 3
1981 XS1100RH
Just going back OTR next week. Hope to track down a few other XS11 owners thru the xs1100.com.au website. I'd love to see a line of XS11's in the one spot. I've never seen another one when I've been out and about on mine.
MelbXS is offline   Reply With Quote
Times are GMT -7.   It's 12:36 AM.
