Old 04-05-2010, 01:59 PM   #16
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
Ok I set up a smugmug account and here we go My bike in a box.
this is what the wiring harness looked like
some sort of front fork mod
my rear wheel was on this bike so i assume the rear wheel on the 650 came off of this bike
parts used to get the rear wheel to fit
rear wheel I took off
Misc photos
busted off the chain guard mounting brackets
wear on the swing arm
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Steve B screwed with this post 04-05-2010 at 02:29 PM
Steve B is offline   Reply With Quote
Old 04-05-2010, 02:02 PM   #17
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
Thanks, My SN is after Suzuki changed back. Do I still need to check?
Originally Posted by Harry94025
Hi Steve,
I don't know if you already knew about this, but the 1998-99 DR650s can have a problem with the starter gear (depends on the serial number, you can Google "Suzuki DR650 starter problem", or something like that for the scoop). I also have a 1999, and replaced the solid gear that was driven by the starter motor, with the earlier/later gear that has a torque limiter clutch. If the engine backfires when it shuts down, this can break the solid gear, and that apparently destroys the engine case. Interestingly, my torque limiter came from a 1995 DR; I checked the part number from one of the on-line Suzuki parts houses, and it was identical to the later number. The retail price for the parts is about $175, but I bought mine through eBay for $40...
Regards,
Harry
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-05-2010, 02:05 PM   #18
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
So what do you guys think about going to the 18" rear wheel? I am considering swapping wheels with my DR350. I am also installing a 46 tooth rear sprocker with a 15 and 16 tooth front gear.
Originally Posted by Klay
A common modification is to put an 18 inch rear wheel from a DR350 on there. That may be what you have.
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-05-2010, 02:20 PM   #19
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
Life can pass one by if we are not careful. I have always said I am going to get me some bikes to have fun with and teach my boys along the way. To many tomorrows and not enough today's and two of my boys are grown and gone then i got cancer and through a surgical miracle it was all hacked out and I am still here. I lost most of the left 1/2 of my pelvis but thanks to someone who donated his body to medicine I got his pelvic half and guess what??? It still works. Thank God for good surgeons, organ and tissue donors, and life.
So i went out and bought two 1980 xl250's and we started riding. traded my old quad for a DR350s and had 3 bikes. Now the son, wife and i go out riding often. Found a sweet old BMW R90/7 and now i commute to work on it. What a way to wind down from a hard day of work.
The moral is act now before life acts for you.
Originally Posted by DisTech
Sounds like you have the wiring pretty much sorted, but I have a bunch of pictures I didn't put in my thread just to keep track of the routing. Let me know if your interested.
Nice collection of bikes, are you going to Odessa?
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Steve B screwed with this post 04-05-2010 at 02:36 PM
Old 04-05-2010, 02:39 PM   #20
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
I do not know what Odessa is. Share...
I do not have a bracket for the starter solenoid, if you have a picture of that and location i will make one and get it attached to the bike.
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-05-2010, 02:49 PM   #21
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
Here is the pre-1996 fuel tank mounting hardware adapter from Zen Seeker's Suzuki DR650 Resource Site. http://dr650.zenseeker.net/GasTank.htm
I got the FMF exhaust system, FMF Q-4 and FMF header pipe, and 6.6 gal fuel tank in over the weekend. I was gone all weekend but will assemble tonight and post photos.
Originally Posted by UnderDark
we need to have a look before it come to the comment and conclusion.
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Steve B screwed with this post 04-06-2010 at 09:49 AM
Old 04-05-2010, 06:05 PM   #22
DisTech
DisTech's Avatar
Oddometer: 616
Maybe you know it by another name. Mattawa or Desert 100?
Stumpjumpers MC Desert 100 Race, Poker Run and Dual Sport
...I do not have a bracket for the starter solenoid, if you have a picture of that and location i will make one and get it attached to the bike.
The rubber starter relay holder slides onto the two spades pointing at us. The rubber headlight fuse holder slides onto the one spade on the right pointing up.
Looking straight at the bracket. It's pretty ugly without the relay and fuse in place.
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 04-05-2010, 06:29 PM   #23
DisTech
DisTech's Avatar
Oddometer: 616
Seat
The stock DR650 seat is a 2x4. If you intend on replacing it and care anything about the weight of your bike, do not get a Corbin. The shot fiberglass pan weighs a ton. One point of many but that's the end of this Corbin rant.
Renazco seats use the stock seat pan, are light weight and beautifully hand crafted. The lead time is really long, but the wait is worth it. Local no shipping bonus, Chris Hickson is in Ravensdale!
Sargent makes a DR650 seat that I've heard good things about too. On their website they say they have, "Our own lightweight PolyTec seat pan". Haven't seen one for the DR but I have a Sargent for my R1100GS and the quality is quite good.
The base models are "roughly" the same price for each brand.
Old 04-06-2010, 06:48 AM   #24
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
I have installed the FMF exhaust system with the Q4 muffler on the bike.
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-06-2010, 06:51 AM   #25
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
I was also able to prefit my Acerbis fuel tank.
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-08-2010, 12:20 AM   #26
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
I fitted the seat to the tank tonight and installed a SW-MotechBash Guard / Skid Plate. This is a great piece of armor.
The seat did not fit my new tank very well.
I am on a limited budget so I modified the stock seat to fit the pre 96 tank on this 1999 DR
verified the fit
stapled things back together
and had a great fit
I also got my new SW-Motech Bash plate. It was the most expensive one I found (125.00) but for the protection it will provide I think it is the best on the market. It attaches to the frame and protects like it should.
You get a new FWD lower engine mount bolt.
looks great on the bike.
It took 1/2 hour to fit the seat and 15 min to install the bash plate.
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-08-2010, 12:24 AM   #27
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
The oil cooler has been modified to the point that I can not use it. Before I buy a new used cooler, do I really need one? How much warmer does the bike get with the oil cooler holes plated off?
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-10-2010, 02:58 PM   #28
Steve B OP
explorer
Steve B's Avatar
Oddometer: 73
Hooked up the fuel and started the bike. Running lean, idles nice but backfires and pops when I exercise the throttle. At 4 1/2 turns of the air needle runs better. Thinking that I need a larger jet.
Steve Barrus
North Bend, WA
1976 BMW R90/6
1999 DR650SE
1991 DR350S
1980 XL250
Old 04-10-2010, 08:04 PM   #29
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,375
Lookin great so far. It needs a big 8" round Baja headlight though. Keep posting pictures.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is offline   Reply With Quote
Old 04-10-2010, 10:09 PM   #30
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,222
Yes, you need the oil cooler. The DR is air/oil cooled. That oil cooler is a big part of the cooling system.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Times are GMT -7.   It's 03:39 PM.
