Old 03-17-2010, 11:46 AM   #1
Hondo OP
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,563
Thumb The Pine Sol Degreaser Thread
Pine Sol as a degreaser?
Yep, that's what I said.
I found this great little trick from "Frank" at the DOHC Custom Forums.
http://www.cb750c.com/modules.php?name=Forums
He recommended that I use Pine Sol as a 1-3 day soak for the bank of carbs of my 1983 CB1000 Custom.
The goal of the soak was to clean the carbs as a bank with most of their internal parts removed (jets, floats, ect) because seperating the 4 carbs is a pain.
And it's just plain easier to do a soak than to disassemble the bank.
The Pine Sol won't damage rubber/soft parts, is easily washed away and is environmentally friendly.
When you're done your parts will smell fresh too -
So I bought 3 big bottles of Pine Sol (not the generic stuff) and a plastic box big enough to hold the carb bank. You can scale this up or down as needed -
Then I emptied the 3 bottles of Pine SOl into the box and added 1 1/2 bottles of water (this topped the carbs, completely submerging them).
Though you can't see it very well, the stripped carb bank is really nasty between the carbs in this pic -
The I sat them into the vat -
Soaking -
I let them soak overnight and then rinsed the bank off with high pressure water- they looked like new -
A few closeups -
I also soaked the bowls, slides and caps -
I have also used the "vat" to clean many other parts. With it's small size I just move the vat & the small parts up to the sink and then can easily wash the Pine Sol off the parts with warm soapy water (Dawn dish washing soap works best- without the hand lotion).
I do suggest that if you are going to work in the vat with your hands (scrubbing deep grime with a tooth brush for example) that you wear protective gloves as the Pine Sol will strip your skin of all oil, really drying your hands out.
Also, best to keep the vat outside unless you want the house to be overwhelmed by the pine odor.
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo screwed with this post 06-07-2010 at 07:15 AM
Hondo is online now   Reply With Quote
Old 03-17-2010, 11:53 AM   #2
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 03-17-2010, 12:05 PM   #3
P B G
Oddometer: 10,001
Very nice, wonder what's in Pine Sol.
Old 03-17-2010, 12:07 PM   #4
Hondo OP
Hondo's Avatar
Oddometer: 9,563
Pine oil?
I think that's what they make turpentine out of.
Old 03-17-2010, 12:14 PM   #5
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 5,044
Wow! Who knew PineSol worked that good.
How long did you have to let things soak?
Wasser is offline   Reply With Quote
Old 03-17-2010, 12:20 PM   #6
Hondo OP
Hondo's Avatar
Oddometer: 9,563
I let the carbs and other parts soak overnight, but others have let their parts soak for much longer.
Old 03-17-2010, 12:59 PM   #7
showkey
Oddometer: 1,934
Originally Posted by Hondo
Pine oil?
What's in Pine Sol
http://docs.google.com/viewer?a=v&q=...zQ1Y99ILPRDdyg
MDS says pine oil and alcohol seems to work and cheap and safe too
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 03-17-2010, 01:15 PM   #8
canyncarvr
Oddometer: 56
Maybe this is better?
http://www.cb750c.com/modules.php?na...ewtopic&t=9866
..or maybe the front page of the forum is where you go if you aren't a registered member.
In which case (if the above takes you to the front, too), it's under 'Tips and tricks', author 'Hondo'.
It's right under the stickies right now..but that'll change..may well move completely off the front page, in which case you'll have to go looking for it.
canyncarvr is offline   Reply With Quote
Old 03-17-2010, 01:17 PM   #9
Hondo OP
Hondo's Avatar
Oddometer: 9,563
Yeah, I posted this thread at The DOHC forums too, but the point of it being a dedicated thread here is so that ADV members can discuss it.
My link to the forums was not to point folks here to the Pine Sol thread there, but to pay hommage to Frank & the DOHC forums for being the originator of this idea.
Old 03-17-2010, 04:27 PM   #10
canyncarvr
Oddometer: 56
Sorry...
Re:
Didn't intend an end-run around anyone..just wanted to make the actual thread a sure find.
Looked to be a good tip to me..especially gettin' ready to yank an in-line carb set to clean 'em up.
Thanks to Wibby for the tip to the tip!
Old 03-17-2010, 04:50 PM   #11
acejones
acejones's Avatar
Oddometer: 5,217
This is a great tip !!
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 03-17-2010, 06:23 PM   #12
DirtMerchant
DirtMerchant's Avatar
Oddometer: 1,465
Pine Sol does work great; just don't get it on xylene based floor paint. DAMHIK
2011 R1200RT Polar
DirtMerchant is offline   Reply With Quote
Old 03-17-2010, 06:49 PM   #13
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,520
That is an awesome trick.
You need to post that in Best Shop Tricks Advrider Garage
scooteraug02 is offline   Reply With Quote
Old 03-17-2010, 06:58 PM   #14
P B G
Oddometer: 10,001
Its good to hear of something not-harsh for soaking aluminum carbs. Most degreasers are quite alkali, super purple, ammonia, simple green etc.
Wonder how pine sol would do in the ultrasonic cleaner.
Old 03-17-2010, 07:58 PM   #15
Kawidad
Kawidad's Avatar
Oddometer: 4,844
Excellent tip! Thanks.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Times are GMT -7.   It's 09:50 PM.
