Old 03-16-2012, 06:06 AM   #196
Big Steve
Big Steve's Avatar
Oddometer: 2,431
I used to work in the "cleaner" business. Pine oil is a great degreaser. I remember when the Citrus products became popular (exceptional degreaser as well, different smell) and they still are as well.
Citrus can get expensive, here is my favorite -
http://www.hillyard.com/ProductsServ...s%2FDegreasers
I once had a chemist tell me the chemical makeup between the pine and citrus was extremely close, looks like PineSol works and pine is always cheaper than oranges!
Big Steve is offline   Reply With Quote
Old 03-18-2012, 01:11 PM   #197
naota03
naota03's Avatar
Oddometer: 10
I bought a 1982 Honda Nighthawk 750. The previous owner didn't properly winterize the bike last season. The fuel went stale in the line. I had my friend look at the bike and determined the bike is in decent condition and I bought the bike.
He and I cleaned the gas tank and did an initial carb cleaning using carb cleaner. We were able to get the bike running. But it runs rough when trying to get the bike to run after turning the choke off. He came across this thread and were going to soak the carbs in pine sol and post the before and after photos.
naota03 is offline   Reply With Quote
Old 03-18-2012, 04:26 PM   #198
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,450
Just make sure to keep all the rubber parts out of the pine sol. They will swell up then eventually go back to normal size, this can be VERY inconvenient. I found out the hard way
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 03-18-2012, 04:43 PM   #199
naota03
naota03's Avatar
Oddometer: 10
-Barron
I will keep that in mind when he and I start to work on the Carbs. Hopefully cleaning the carb should correct the rough idle when starting to close the choke. I guess worse case scenario the carbs may need to be balanced.
Old 03-19-2012, 06:58 AM   #200
Unstable Rider
corn and tornadoes
Unstable Rider's Avatar
Oddometer: 2,541
Great thread.
Do we have any sucess stories for this working on cleaning up the insides of rusty varnished metal fuel tanks?
Picked up a little Honda ATC 110... interior of tank "has that look and smell". Thought I may give it a go, is it best to cut the Pine Sol with a bit of boiling water for this kind of task??
thanks much. I have viewed all kinds of you tube posts of people tumbling rocks in fuel tanks etc., and was wondering if this would be a good pre-wash to try before such things..
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 03-19-2012, 07:18 AM   #201
Hondo OP
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,606
I would try running a tank full of fresh fuel & 1/2 of a can of Seafoam added before I did the carbs- that may solve the issues.
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 03-19-2012, 07:19 AM   #202
Hondo OP
Hondo's Avatar
Oddometer: 9,606
Originally Posted by Unstable Rider View Post
Great thread.
It will clean the tank of any oils but won't treat the rust.
Old 03-19-2012, 07:26 AM   #203
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,729
Great thread.
I have cleaned two such tanks with CLR. Calcium, Lime, Rust remover. One had some heavy surface rust in it, I used BBs for an abrasive. The other was some light oxidation, and nasty old fuel that had been left in there, just the CLR in that one. I preffered to rinse thoroughly with some clean gas a couple of times, then again with some gas, and a fair amount of 2 stroke oil in hopes of conditioning the steel and preventing new rust. So far it seems to have worked OK.
BK.RD.RNR is online now   Reply With Quote
Old 03-19-2012, 02:28 PM   #204
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,300
Try 1" sheetrock screws - they have sharp edges, and will break loose more rustcrap.
HapHazard is offline   Reply With Quote
Old 03-20-2012, 09:16 AM   #205
naota03
naota03's Avatar
Oddometer: 10
My friend and I just took the carbs off my nighthawk were in the process of prepping the carbs for soaking. He had to leave early so The bath wont take place until tomorrow when he comes by. Im just a little miffed that I may need to fix or replace the stator since it isn't charging the battery. But I guess it is time to troubleshoot that when the carbs are squeeky clean.
Old 03-22-2012, 05:39 AM   #206
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,928
Has anyone found that it harms paint in any way? I was hoping to use pinesol as an alternative to less effective degreasers when washing the car....i would use it to degrease the door jambs, engine, etc, not to actually WASH the car... It would only be on for a few minutes...
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 03-22-2012, 05:43 AM   #207
Unstable Rider
corn and tornadoes
Oddometer: 2,541
I am a PINE SOL newb, but I have mixed it with a bit of water like 50-50 and used it as a pre-wash for the dirty greasier bits on my KLR just before hitting it with the high pressure at the local car wash.
Yes, I know relaying this will bring on all forms of gafaws about WHY would you ever WASH a damn KLR..... to impress the toothless circus ladies of course. They have JOBS.
~Butch Cassidy
Old 03-22-2012, 06:09 AM   #208
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,729
I soaked a drive side hub from a 1978 DT400 for a few weeks, hitting it with a wire brush occasionally. It stripped all of the original paint off, and left a perfectly clean piece for fresh paint..
Of course there is no clear coat etc.. on those.
Old 03-22-2012, 06:25 AM   #209
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 24,224
Be careful using any type of degreaser on paint, including dish soap. It can strip the paint itself of it's oils and dull the finish if not ruin it completely.
knybanjo is offline   Reply With Quote
Old 03-27-2012, 10:37 AM   #210
naota03
naota03's Avatar
Oddometer: 10
Talking
Here is my current progress of the pine sol soaking. I will post the after pictures when I am done.
Before Soaking.
Carbs soaking
[img ]http://i1174.photobucket.com/albums/r615/naota_03/Pinesol%20Carb%20Cleaning/IMAG0139.jpg[/img]
Over the next 12 hours or so. I am going to be checking the parts and making sure they get cleaned well
naota03 screwed with this post 03-27-2012 at 10:39 AM Reason: pictures not showing.
Times are GMT -7.   It's 06:30 AM.
