Old 03-27-2012, 06:47 PM   #211
SStiffler
Oddometer: 248
Remind me not to have punch at your house. Nice use of a punch bowl!
"If you have to worry about the risk, you're dead already." Paul Newman
SStiffler is offline   Reply With Quote
Old 03-27-2012, 09:05 PM   #212
naota03
naota03's Avatar
Oddometer: 10
I bought it at the dollar store since I didn't have any large containers. I bought 10 for a dollar. The funniest thing is a member of the Nighthawk forums said the same exact thing.
Here is the pics of the cleaned carb parts. I also took a picture of the pine sol after I used it. It looks gross. Though the pine sol did the trick. I will put the carbs in either tomorrow or next week with the help of my buddy Wreckster. Should be fun.
Also Please note if you do plan to take on this project please rinse the carbs in an area with good ventilation. Pine sol can give you head aches. lols
naota03 is offline   Reply With Quote
Old 03-28-2012, 06:58 PM   #213
naota03
naota03's Avatar
Oddometer: 10
Finished the Pine Sol Cleaning of the carbs.
Before
After
It looks good. WOOT!
WIll install the carbs on my next day off when my buddy is free.
naota03 screwed with this post 03-28-2012 at 06:58 PM Reason: forgot to add a word.
Old 04-03-2012, 05:23 PM   #214
Maxitout77
Oddometer: 22
Ok, I'll play along. I thought this thread was nonsense, boy was I wrong. Awesome tip guys! This was a 24hr soak, a rinse off and a wipe. Unreal results.
Maxitout77 is offline   Reply With Quote
Old 04-04-2012, 12:13 AM   #215
naota03
naota03's Avatar
Oddometer: 10
It is so interesting how well this works. I am a believer of the powers of pine sol.
Old 04-04-2012, 01:20 AM   #216
Tech23
Tech23's Avatar
Oddometer: 470
I'm impressed. Pine Sol works pretty good. I wonder if you could build your own homemade Safety Kleen style Pine Sol parts washer with a pump. Or would the Pine Sol kill the pump?
Back in 1993 at my old home I built my own (50/50 Kerosene/Safety Kleen mix) parts washer using an old kitchen sink and counter top that was being discarded from an apartment complex that was renovating a unit. I got myself a Quaker State 30 gallon gear oil drum from work, an Audi 5000 fuel pump, a VW Rabbit rear defogger switch that I used as a power on/off switch, made up a wiring harness with an inline fuse. I used long basic homemade metal brackets that I rubber mounted to the gear oil drums lid to mount the fuel pump to. The only part I had to buy was a $5 short straight piece of PVC pipe to attach to the sink drain as a return to the tank through a hole in the middle of the drums lid. I had the whole thing set on top of a common garage 6 ft tall garage shelving unit assembled in halves...two three foot high shelving units. This is about the same height as a work bench. I had it wired into an old car battery I had set on the bottom shelf that I would charge periodically. While the charger was hooked up the pump acted as a two speed pump because I could set the battery charger to 2 amp or 10 amp. You could also use an alternate power supply for the pump. I was aiming to spend as close to zero dollars as possible...I came real close.
Here's the only two pics of the homemade parts washer that I have...if anyone feels creative and can scrounge up the necessary parts. Sorry for the low pic quality, they were originally 35mm prints, but I think you can get the idea. I used this parts washer for 12 years, never had to change out the solvent, only had to replace the pump once in that time, and only discarded it to move. I felt like I got my moneys worth out of it.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 04-04-2012, 01:08 PM   #217
naota03
naota03's Avatar
Oddometer: 10
Tech23
That's a good Idea. I like it. Its versatile. If I didn't live in an apartment complex. I would try something like that.
Old 04-06-2012, 08:44 AM   #218
prsdrat
Oddometer: 777
Thanks! I happen to have an old SafetKleen tank with a blown pump AND
a couple of old (still running) electric fuel pumps!! I'll have to see what
PineSol does to electric pump innards!
"Can't never could."-Grandma Belle Marie Bullock-Shuflin
prsdrat is offline   Reply With Quote
Old 04-06-2012, 10:17 AM   #219
Tech23
Tech23's Avatar
Oddometer: 470
Originally Posted by prsdrat View Post
Thanks! I happen to have an old Safety Kleen tank with a blown pump AND
Cool, do that. I still have like eight Audi 5000 fuel pumps stored. I gathered them up while they were being recalled for "noise". The Audi fuel pump I used was silent, I also used rubber firewall grommets with metal inserts to mount the pump brackets to the lid. I added the rubber grommets to reduce pump noise. Does Pine Sol harm or "swell" rubber? Safety Kleen does and it never hurt the fuel pumps.
Tech23
Tech23 screwed with this post 04-06-2012 at 03:58 PM
Old 04-06-2012, 12:47 PM   #220
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,808
Cool, do that. I still have like eight Audi 5000 fuel pumps stored. I gathered them up while they were being recalled for "noise". The Audi fuel pump I used was silent, I also used rubber firwall grommets with metal inserts to mount the pump brackets to the lid. I added the rubber grommets to reduce pump noise. Does Pine Sol harm or "swell" rubber? Safety Kleen does and it never hurt the fuel pumps.
Tech23
Pine sol will swell rubber if left to soak for long periods. I just waited for them to return to normal, and then installed those pieces again. YMMV.
BK.RD.RNR is offline   Reply With Quote
Old 04-06-2012, 03:58 PM   #221
Tech23
Tech23's Avatar
Oddometer: 470
Hmmmm. I'm not so concerned about rubber parts being cleaned, but any rubber parts that may be in the parts washers (fuel) pump, and any adverse it may have on those rubber parts. Any time I need to clean a rubber part it gets a quick cleaning in solvent and immediately afterward gets rinsed in a bucket of water.
Tech23
Old 08-10-2012, 01:02 PM   #222
mattsz
moto-gurdyist
mattsz's Avatar
Oddometer: 178
Pine-Sol vs Simple Green
sleeping thread, I know, but...
I just spoke to Rusty at Max BMW in NH - asked about Pine-Sol as a carb dip. He asked the shop guys, and they all laughed - never heard of it. They recommended Simple Green. Can anybody with experience comment on one over the other?
mattsz is offline   Reply With Quote
Old 08-10-2012, 02:11 PM   #223
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,199
Seems you've got 15 pages of experience to draw upon right here.
Old 08-10-2012, 02:29 PM   #224
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,808
You would not pay Max to soak your carbs in Pine Sol if it was that easy would you?
The good news is you don't have to!
Simple green will take the clearcoat off of any product in a couple minutes.
Not that the pinesol won't if you leave it soaking long enough.
It works, it works awesome. I've done at least 10 carbs now, some of them were so bad that I had to let them sit for a week, but it works for sure. Just follow the instructions of the OP. Soak, wash with dawn and hot water, rinse thoroghly, blow out passages etc. with compressed air. You'll be surprised.
Old 08-10-2012, 02:39 PM   #225
mattsz
moto-gurdyist
mattsz's Avatar
Oddometer: 178
Do my carbs have a clearcoat?
I have pages of "experience" here with Pine-Sol, but minimal comment on the pros and cons of Simple Green. So I thought I'd ask...
Times are GMT -7.   It's 05:26 AM.
