Old 08-11-2012, 09:33 AM   #241
mattsz
moto-gurdyist
mattsz's Avatar
Oddometer: 90
Thanks, Lornce!
Is this strictly aesthetic? Should I be worried about polishing up the interior parts that interact with fuel and with each other? Any kind of oil or material I could use with the elbow grease to brighten them up a bit, and/or maybe protect them from further oxidation?
mattsz screwed with this post 08-11-2012 at 01:04 PM
mattsz is offline   Reply With Quote
Old 08-14-2012, 04:06 AM   #242
mattsz
moto-gurdyist
mattsz's Avatar
Oddometer: 90
Well, for better or worse, I proceeded on my own. I grabbed my fine steel wool and set to lightly scrubbing the exteriors and aluminum surfaces that slide against or contact other surfaces. Dry-wiped everything down and blew the heck out of everything with compressed air, hopefully to fully remove any stray steel wool fibers. Finally, to protect them from the elements, I rubbed them down with a thin coating of light machine oil and buffed them dry to the touch.
Here's one - it only needs the float jet to be good to go (I hate waiting for parts!):
It cleaned up pretty well - shiny, but not too shiny... don't want it to look brand new!!!
Hoping that it'll work shiny... (shoulder-shrug smiley here)
Old 08-14-2012, 06:46 PM   #243
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,990
I've polished the slides and bores to good effect with a bit or Autosol metal polish. A smooth finish on those surfaces is reasonably critical.
That carb looks really nice.
Old 08-15-2012, 01:47 PM   #244
Lesharoturbo
Nerdly Adventurer
Lesharoturbo's Avatar
Oddometer: 1,037
Has anyone tried this on fuel injectors? I know you can use an ultrasonic cleaner for injectors, and a lot of on-line companies sell cleaning, but I was wondering if this would work just as good as it does on the carbs. I might have to give it a try.
Individuality is best expressed individually; you are conforming in your non-conformity.
Lesharoturbo is offline   Reply With Quote
Old 08-15-2012, 03:24 PM   #245
Cdaledude
Oddometer: 983
Send a message via AIM to Cdaledude Send a message via Yahoo to Cdaledude
Go to Harbor freight and buy an ultrasonic heated tank and use that for small carbs and I would try the injectors in it. I wouldn't try it on an injector that you can't replace.
MSF Military RiderCoach,'07 KTM 250 XCF-W w/ 320 HT-Racing kit, '02 Cannondale E440 (plated), '01 GasGas TXT321, '00 BMW GS1150,'95 XR100R,'84 RZ350 (in pieces )
Cdaledude is offline   Reply With Quote
Old 08-15-2012, 04:20 PM   #246
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 3,929
No, I have not tried it myself...
Fuel injector cleaning video.
BK.RD.RNR is offline   Reply With Quote
Old 08-21-2012, 02:47 PM   #247
ben2go
Stuck @ Home! >=^(
ben2go's Avatar
Oddometer: 1,171
Anyone use this on brake parts?Maily interested in cleaning the steel parts like caliper pistons and banjo bolts.
Originally Posted by crashmaster
Throw off those comfortable chains that the U.S. consumer society has burdened you with, go and ride solo into places far outside your comfort zone, and learn interesting things about yourself.
Manic Cycles=My Blog
Manic Cycles=My Facebook Page
ben2go is online now   Reply With Quote
Old 08-21-2012, 05:18 PM   #248
Moparmanpete
Support all riders
Moparmanpete's Avatar
Oddometer: 294
Talking Pine Sol Jelly Yummy
Well,
I have an XL600R head that I wanted to gently clean the ports of alot of carbon deposits and liked the Pine Sol idea, so here we go
Took about 6oz of straight Pine sol and mixed it slowly with half a packet of Ball Fruit Pectin for making jelly till it reached this consistency
Then just smeared it where I wanted it and kept it from where I didn't want it.
After a few hours it would dry so I added more, but later found that it really wasn't neccesary.
I also soaked the valves in a 50/50 mix of Pine Sol and water
Here are the before and after shots for a 24hr time period
The head before
After
The Valves before
And after
Not convinced?
Well here you go
Left side coated with the jelly for 24hrs
Right side is the control
There you go
Not bad for not really doing anything!
Brush it on and wait,
Hose it off and oil.
Expeirences may very but I like it.
Pete
"The reward is in the doing of it" "If you don't go when you to want to go, when you do go you'll find you've gone" BM
08 Wildfire 150 Scoot "The Virus"
The Virus's RR http://advrider.com/forums/showthread.php?t=826703
87 XL600R "The Cracken" deceased till further notice
Moparmanpete is offline   Reply With Quote
Old 08-21-2012, 05:31 PM   #249
mjydrafter
adventure commuter
mjydrafter's Avatar
Oddometer: 3,192
The problem with injectors and pinesol is getting the pinesol into the injector where the crud is. It should be fine but it will only clean the outside.
I toss them in the carb dip to clean up the outside, but then use a rig made out of an old injector rail to clean the inside with pressurized solvent. It hooks up to my compressor for the pressure. Just use a small wall wart transformer and a momentary switch spliced into a injector electrical connector, to run the injector.
1974 Suzuki TC-185 (The little 10 speed)
1986 BMW K75c
Yes! Whenever bicycles are broken, or menaced by International Communism, Bicycle Repair Man is ready!
mjydrafter is offline   Reply With Quote
Old 09-01-2012, 09:31 AM   #250
crackhead
Oddometer: 1,237
I've been running it in my parts washer and it works great. I don't have particularly sensitive hands, but after using for a while, it ate the skin off. Nothing bad mind you, but lost an outer layer. Looked like I dipped my hand in Elmer's and let it dry, then peeled it off. Shit works great when it's warm.
'98 1100GS - Mine
'02 F650 Dakar - Her's
'01 XR50 - Spawn's
crackhead is offline   Reply With Quote
Old 09-28-2012, 05:03 PM   #251
XS500RUS
XS500RUS's Avatar
Oddometer: 366
Word of caution
Just did a set of Mikuni VM32s from my T500, they didn't look all too terrible to begin with, the jets weren't even clogged when I took them off. But I was curious to see how clean I could get them :)
Previously I had stuck one of them in an ultrasonic bath of isopropanol, this got some of the grime off on the outside but did nothing to remove the gummed up gasoline in the bottom of the floatbowl. I put the first carb into a small container of uncut Pinesol overnight, along with the jets, slide, etc.
The Pinesol bubbled up, which I now realize was the byproduct of a chemical reaction. The PineSol worked TOO well, stripping off some of the metal, going as far as producing small pits in the bottom of the floatbowl and parts of the carb body Not bad enough to ruin the carbs but I'm glad I didn't let it sit for another day! Jets were pink colored, but cleaned up semi-okay, and look unharmed.
The second carb I'm doing in a 50:50 dilution, with the floatbowl being filled up with a slightly higher concentration. Jets I put in 50:50 for about half and hour and took out, they look good, without the pink crap.
Also, after rinsing all the Pinesol off in soapy water, I dried things off and blew out the jets (with human power lol) then liberally sprayed everything down with WD40, as to prevent a reaction with the air. No before pics but I'll get some 'afters' soon.
1977 Yamaha XS500C cross country veteran
1975 Suzuki T500 under restoration
2001 Triumph Bonneville
XS500RUS is offline   Reply With Quote
Old 09-29-2012, 01:12 PM   #252
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 5,527
Originally Posted by Moparmanpete View Post
Well,
snip.... Not bad for not really doing anything!
Pete
Brilliant! I like that jelly trick. I've soaked carbs before, but the jelly opens up more possibilities.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 10-02-2012, 07:09 PM   #253
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 1,975
Has anyone been super lazy and tried hooking pinesol up to the fuel tubing and filling the carb up with it? Just drain the bowl to fill the carb? Flush it through a few times. Rinse and repeat. Then flush gas thru a couple times and see if the old bike fires up?
Or is the key to submerge the carb so it soaks?
bikes
Yokomo is offline   Reply With Quote
Old 10-04-2012, 02:41 PM   #254
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 2,569
there are many small passages in the carb (unless it is a Lectron, perhaps) . . . . I'm not confindent that all the passages would be well cleaned by simply allowing the fluid to flow through the carb -- I would think (uh oh) that the fluid would follow the path of least resistance, and not really clean everything that needed it . . . . . .
don't bet the ranch on it, though -- ;-}
Searching for the immaculate contraption
bomber60015 is online now   Reply With Quote
Old 10-07-2012, 04:53 PM   #255
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 3,929
If I was going to use that technique, I would do it with carb cleaner. I have done it with carb cleaner. I let them sit, then ran the engine without draining them to get it through the jets. It was an improvement, but not as thorough as the process described here with pine sol.
I guess it depends how bad you think they are...
Times are GMT -7.   It's 01:23 PM.
