Old 02-12-2014, 06:57 PM   #301
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,713
Originally Posted by BrittC View Post
Has anyone filled a gunky fuel tank with Pine Sol and had good results?
I have with clear vinegar but not pinesol.I left it in for a week.I would shake it and flip it a few times a day.I made sure it got a couple nights on it top and sitting straight up.I only lost about a quart of it through evaporation and leakage.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is online now   Reply With Quote
Old 02-13-2014, 06:15 AM   #302
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,452
I have a 1966 Kawi 2 stroke that had about 1/2" of gooey, tar-like mess in the bottom. I poured in 3 bottles of PineSol and it took about a week but all the goo finally dissolved.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 02-13-2014, 07:53 AM   #303
prsdrat
Oddometer: 777
I've cleaned three different tanks so far, I always start out with PineSol to
clean out the solubles and varnish. The last one I also used citric acid, then
finished it off the remaining rust with a product called "Metal Rescue". This
stuff works! I just checked my TLR200, which has been sitting for several
months, and it is a good candidate for the PineSol/Metal Rescue method.
"Can't never could."-Grandma Belle Marie Bullock-Shuflin
prsdrat is offline   Reply With Quote
Old 02-13-2014, 10:08 AM   #304
thundercat
Meow
thundercat's Avatar
Oddometer: 18
Definitely like the after much more than before. Great Job. Have to keep pine sol in mind. Before cleaning the tank, you may want to borrow a fish eye scope and inspect it to see if it any extra work on the tank is needed.
Just finished a carb clean using Pine Sol and a toothbrush. Very happy with the results.
Before:
After:
I should have used the flash in both pics to make for a better comparo, but you get the point.
thundercat is offline   Reply With Quote
Old 02-13-2014, 12:33 PM   #305
wmako
bored in NJ
Oddometer: 655
Before:
After:
Those are from your 1984 Honda Sabre VF700S? I thought I was seeing things, as my son and I just dropped the carbs from a newly acquired 1982 Honda Sabre VF750S into a bucket on Pine Sol last night. Did you drop them in all assembled like that? Ours were a mess. We pulled the jets and everything else we could.
wmako
RRMC
1979 CX500
1990 DR350
Ride Reports
Wmako's moped army rides from Jersey to Una-F'n-dilla (August 2010)
wmako is offline   Reply With Quote
Old 02-13-2014, 05:59 PM   #306
BrittC
BrittC's Avatar
Oddometer: 304
I left the carbs assembled as a rack but removed the jets, floats, diaphragms, needles, etc. For me it was easier to keep the parts matched up for each carb if I left them assembled and I numbered them. One spot that almost got me was after I thought the jets were clear and I started installing them. I backed up a step, held each one up to a light, and found one that was plugged solid. The only way I could clear it was to use the wire twist tie from a loaf of bread (after burning off the plastic coating).
I also had a float valve stuck in its bore. After soaking for 22 hours in Pine Sol it came out easily.
All in all, it worked out well.
2002 Aprilia ETV1000 Caponord
2008 Yamaha WR250R
1992 Yamaha XT225 Serow
http://britt-motorcycling.blogspot.com
BrittC is online now   Reply With Quote
Old 02-13-2014, 06:02 PM   #307
BrittC
BrittC's Avatar
Oddometer: 304
I see that Metal Rescue is available at Home Depot so that's easy enough. Where do you pick up citric acid? Home Depot's site does not list it...
2008 Yamaha WR250R
Old 02-13-2014, 07:02 PM   #308
Soldier311
Oddometer: 2,122
Citric acid = orange juice?
2008 DR650
Soldier311 screwed with this post 02-14-2014 at 03:57 AM
Soldier311 is online now   Reply With Quote
Old 02-13-2014, 07:38 PM   #309
k-moe
Oddometer: 2,850
Originally Posted by Soldier311 View Post
Citric acid = white vinegar.
Fairly equal in that they both do the job, and are acids, but they are not the same chemical.
Mmm Mmmm. Honey, this sure is a tasty White Vinegar Meringue pie.
k-moe is offline   Reply With Quote
Old 02-13-2014, 07:45 PM   #310
Cdaledude
Oddometer: 1,142
White vinegar is acetic acid, not citric
13 KTM 350 XC-F, '07 KTM 250 XCF-W w/ 320 HT-Racing kit, '02 Cannondale E440 (plated), '00 BMW GS1150,'95 XR100R,SSR 160 TXT2, '84 RZ350 (in pieces )
Cdaledude is offline   Reply With Quote
Old 02-14-2014, 03:56 AM   #311
Soldier311
Oddometer: 2,122
Oops , perhaps that's why things taste funny around here.... The wife is probably trying to kill me.
Citric acid = orange juice? Probably not good for cleaning carbs, though....
2008 DR650
Old 02-14-2014, 08:36 AM   #312
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 24,474
Well you don't actually use OJ.
Citric acid can be bought in crystal form and you mix it up into a solution when your ready to use some.
http://www.wikihow.com/Prepare-Citric-Acid-Solution
knybanjo is offline   Reply With Quote
Old 02-14-2014, 09:56 AM   #313
prsdrat
Oddometer: 777
I bought bulk citric acid from www.hardrhino.com when I refinished the
cedar siding on my home. Turns out citric acid has many uses.
Old 02-14-2014, 03:35 PM   #314
k-moe
Oddometer: 2,850
Closer. I prefer lemon. As mentioned above you can buy crystalized cirtic acid, but lemon juice is also a good source of fairly strong citric acid, and has been a mainstay for boiling carbs for generations of motorcyclists.
Old 03-14-2014, 06:09 AM   #315
Fitero
Just One of Billions
Fitero's Avatar
Oddometer: 242
Citric Acid can be picked up in any brewer/distiller/wine maker supply store in bulk as well.
Soy un AGONIAS!!!
Fitero is online now   Reply With Quote
Times are GMT -7.   It's 08:11 AM.
