Old 03-18-2010, 05:04 PM   #16
Green427
Comfortably Dumb
Green427's Avatar
Oddometer: 1,090
HF's quick grips. After sitting in my garage for 3 years, I finally used them. Plastic grips snapped easily. All three of them. Plastic became brittle from being stored in cold & hot weather.
Liquid hand suction pump. Plastic became brittle. Pump would not work after using it to suck antifreeze.
Automatic wire cutter/stripper. What a cheap piece of shit. Not even worth the sidewalk sale price of $2.99.
Multifunction tool. Works great for the application, but needs to be whacked with a hammer to keep on running.
Multimeter. Gotta keep fiddling with the probe connectors to get a reading.
All their recipro saw blades lasted 10 minutes.
I've had good luck with their pneumatic nailers, air compressors, power saws, drills, and generators.
2011 DL650A
Green427 is offline   Reply With Quote
Old 03-18-2010, 06:06 PM   #17
B02S4
Aye
B02S4's Avatar
Oddometer: 1,093
Originally Posted by DevilNinjaDog
Rubber strap wrench. Snapped the rubber off at the handle while trying to loosen a stubborn oil filter...
DOH! Next time use this!
http://www.harborfreight.com/cpi/cta...112&zmap=36778
B02S4 screwed with this post 03-21-2010 at 01:41 PM
B02S4 is offline   Reply With Quote
Old 03-18-2010, 06:35 PM   #18
DirtyOldMan
Oddometer: 1,919
4x36 belt disc sander. Burnt up quickly. I don't mean "it got hot and quit in a coupla hrs."
I mean "within 30 seconds of no load run time it burst into freaking flames!"
took it back and got another and it did the same thing. Apparently they don't run well when installed sideways.
Sandy Jackson
04 250 RFS
13 650 Terra
96 R1100R
DirtyOldMan is offline   Reply With Quote
Old 03-19-2010, 07:22 PM   #19
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,924
Tried one of the chainsaw sharpening machines. It's not that it broke, it was just so woefully inaccurate and sloppy it would ruin a decent chain with uneven grinding very quickly. Total waste. They took it back, so no harm.
A $7 hand-file is more accurate and faster with practice, I learned.
swingset is offline   Reply With Quote
Old 03-19-2010, 08:55 PM   #20
garfield
Garfield
Oddometer: 42
pipe threader
the Rigid copy power pipe threader they sell is junk! gave it away after 2 days of frustration. got the Rigid now, $700. more but it works
garfield is offline   Reply With Quote
Old 03-19-2010, 09:00 PM   #21
Mr B
Mr B's Avatar
Oddometer: 515
[IMG]file:///C:/Users/bpj100/AppData/Local/Temp/moz-screenshot.png[/IMG]Not a fan of The Harbor Freight Scam/Store. But I must admit I purchased a pair of safety wire twist pliers and us them for over three years almost everyday. (I am an aircraft mechanic) they finally broke but I sure got my $15.99 out of them, I have since used up tow pairs from Snap On but when they stop working they are always warranty!!
Mr B is offline   Reply With Quote
Old 03-19-2010, 09:01 PM   #22
B02S4
Aye
B02S4's Avatar
Oddometer: 1,093
Didn't much care for the electric impact wrench.
Old 03-20-2010, 03:26 PM   #23
DualSportDad
DualSportDad's Avatar
Oddometer: 2,448
impact driver...broke with the first wack.
i have the safty wire pliers and the rivet gun...both work for me.
Alex
Ft. Myers, Fl.
2006 Buell Ulysses
DualSportDad is offline   Reply With Quote
Old 03-20-2010, 08:11 PM   #24
Fishyhead
Eremikophobic
Fishyhead's Avatar
Oddometer: 3,144
I have the HF safety wire plies and used them to wire the grips on my three bikes. The pliers worked OK but the wire itself is absolute shyte.
My worse HF buy - the welder stand. There's nothing good about a $3000 welding setup on a $40 stand held together with bolts made of recycled tin foil.
Duy. You know, like the decimal system.
Spot shared page: http://share.findmespot.com/shared/f...FogjjtYMdOqF2n
Fishyhead is offline   Reply With Quote
Old 03-20-2010, 11:10 PM   #25
P B G
Oddometer: 10,001
LOL, something about having a 3000$ welder tells me you probably shouldn't buy a stand? Or at the very least you should buy the factory sold matched stand to that welder.
HF stand is deserving of an HF welder on it.
Personally my welding "stand" is one of those chrome wire rack carts sold by sams club, Future plans are to get another one and put a steel top between the two for a rolling welding table.
Old 03-21-2010, 07:54 AM   #26
IDScarecrow
IDScarecrow's Avatar
Oddometer: 1,354
Electric chainsaw. Lasted 15 minutes. Found a cheaper one at Lowes that works fine.
"Pain is inevitable. Suffering is optional."
IDScarecrow is offline   Reply With Quote
Old 03-21-2010, 07:58 AM   #27
Fishyhead
Eremikophobic
Fishyhead's Avatar
Oddometer: 3,144
I know it's shameful. I just needed it to get the welder off the ground to weld up an exhaust and build a rack for one of my bikes before a road trip.
Old 05-26-2010, 06:21 PM   #28
stainlesscycle OP
stainlesscycle's Avatar
Oddometer: 2,279
i figure a $3000 welder could make a pretty nice stand for a $3000 welder.
current bikes
stainlesscycle is offline   Reply With Quote
Old 05-27-2010, 10:16 AM   #29
groundrules
groundrules's Avatar
Oddometer: 1,830
Originally Posted by racermdub
Must be that I've gotten lucky, I've used the safety wire pliers and $3.99 battery tender without fail for 4 years now.
yeah, that seems to point out one of the rubs about HF. In any given stack of tools, you might get one that's fine (like my and your safety wire pliers), or you might get one that's a POS. I think if you can have a look at the specific item you're going to buy and actually try that EXACT piece out (instead of a similar cousin) you may increase your chances. But there's definitely a crap shoot element to the whole process.
groundrules is offline   Reply With Quote
Old 05-27-2010, 10:24 AM   #30
JeffD
JeffD's Avatar
Oddometer: 492
I was looking at one of the HF tire machines and I swear I could have bent it in two with my bare hands so I passed.
JeffD is offline   Reply With Quote
Times are GMT -7.   It's 08:38 AM.
